Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 07-11-2002, 04:22 PM   #1
adamsrs
Member#: 3768
Question HKS Fuel Cut Defender:
As you know i have a 2000 2.5 RS with an EJ22t shortblock and 2.5 SOHC heads....running a stock ECU with a JC sports Torque Chip 2....as of right now the JC TC2 is controlling my Fuel cut using a voltage clamp, but in a few weeks i am going to install the Greddy E-Manage and i will be removing my JC sports TC 2 at that time.......with the HKS FCD will it still controll my fuel cut by tricking the MAP sensor? Or will i have to get something else? Any info would be GREATLY appreciated! thanks! How hard is it to install also!
adamsrs
adamsrs is offline   Reply With Quote
Old 07-11-2002, 05:07 PM   #2
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
That GReddy unit only controls fuel, right? Does it do so by manipulating the load (MAP voltage)? If so, then you'll still need to worry about timing. If it doesn't control it by altering the load, then you may need to run a second MAP sensor to that unit to control just the fueling since the stock one will only read to just barely over atmospheric pressure. How it'll alter fuel without playing with the load of the engine, I have no idea...
FCD's are nothing more then voltage clamps, with a resistor built in to cut the voltage by percentages (depending on adjustment). *shrug*
Old 07-11-2002, 05:14 PM   #3
adamsrs
Member#: 3768
The Greddy E-Manage controls Fuel and TIming, and comes with an optional second MAP sensor to controll the map on aftermarket turbo cars!
adamsrs
Old 07-11-2002, 05:24 PM   #4
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Controls or alters to make your stock ECU control it? If it controls, you're good to go, if it alters, then you will most likely still need it.
Old 07-11-2002, 06:02 PM   #5
Jewbaru
Member#: 1994
2013 Impreza WRX
from the Greddy Site:
e-Manage is an inexpensive programmable fuel management system that allows you to properly tune your factory fuel system, without having to change the entire factory ECU system to an expensive "stand-alone" unit. The e-Manage system is a universal "piggy-back" type unit, which taps into most factory ECU wiring and it still utilizes the existing sensors. Basic functions will allow the user to slightly alter factory injector duty-cycle( 20% at 5 preset RPM points), by intercepting and altering airflow or MAP sensor signals. For VTEC cars you can adjust the VTEC shift point.
Additional features that are built into the system, but are only accessible though the use of our PC-Windows based "e-Manage Support Tool" communication software (Please see our Authorized GReddy Support Dealers for more information) are a 16x16 Airflow Adjustmemt Map, Larger Main Injector correction adjustment, Upgrade Air Flow Meter adjustment, Boost Limiter Cut, Anti-engine Stall, VTEC-fuel adjustment, Real-time Map Trace, Real-time Display, Real-time Communication, and basic Data-logging.
With the use of our "Optional Injector Harness" and the software, the unit has the ability to control an additional 16x16 Injector duty cycle Map and the Controls for adding up to 2 Addional Sub-injectors. If the "Optional Ignition Harrness" and the software is used the unit has the ability to control a 16x16 Ignition Timing Map. All of the above Maps can also be Map-traced in Real-time as well. If the factory range of Map or Airflow meter is surpassed, you can incorperate our "Optional GReddy Pressure Sensor and Pressue Harness" to set larger scales of ajustment.
Jewbaru is offline   Reply With Quote
Old 07-11-2002, 08:28 PM   #6
jeffg
Member#: 2958
2001 WRX (GC8)
Have you had any luck getting the Ziener Diode? I think that is all you need. Nothing fancy, just the Diode.
Let me try and find the specs for what you need.
J
EDIT how about his?
http://forums.nasioc.com/forums/show...=voltage+clamp
jeffg is offline   Reply With Quote
Old 07-12-2002, 01:51 AM   #7
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
It's an S-AFC! *shrug* Just look for engine management in regards to tuning with an S-AFC and you'll find out everything you need to know.
Old 07-12-2002, 02:47 AM   #8
jeffg
Member#: 2958
2001 WRX (GC8)
8, the greddy Emanage is like an SAFC on crack. While it is modification of the stock ECU signals it does not do so by tricking the MAP sensor signal (it can in base form, but with the additional harnesses it does not). The injector harness actually lengthens and shortens the injector pulses directly.
You have a fairly adjustable 16x16 fuel map based on throttle postion and rpm.
and a timing 16x16 map based on rpm and MAP voltage. With the use of the additional presure sensor Adam is using he can wire in a 3 bar MAP and have adustment for boost.
Old 07-12-2002, 04:19 AM   #9
adamsrs
Member#: 3768
So the Optional pressure sensor will not only read boost, but it will read nomal off boost pressure? Cool!!!!!!!!!! This means it doesnt tap into me MAP sensor at all?
adamsrs
Old 07-12-2002, 07:57 AM   #10
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Default Thinking
I was considering going this route, is there anyone who has already done it on any year of car? Or anyone in addition to you?
Joshua
yebokmj is offline   Reply With Quote
Old 07-12-2002, 05:38 PM   #11
Z1 Performance
Member#: 9327
Wht I don't get about the GReddy is why go through the time/expense of getting it with all the additional harnesses needed, and then tryiong to find a tuner who knows it well enought to mapo it for you, when you could do a LINK2 so much easier? or better yet a TECII if the budget allows?
Granted either the LINK2 or TEC are more money, but they are so much more ecu that teh E-Manage and the knowledge base is already there to tune them on these cars...why reinvent the wheel?
And at the end of the day, it is just a more adjsutable SAFC..the SAFC actually adjsuts the IPW of the injector as well..by altering the MAF signal, it tells the computer it is richer or leaner than it actually is, casuing the ecu to respond with more or les fuel depending on if you are making + or - corrections with the SAFC. There are only 2 ways to control fuel...IPW (lengthen or shorten) and pressure). Pressure is the easy way...a nice RRAFPR., and every turbo RS should have this already. 2:1 if you are on stock injectors, 1:1 if upping the ante to 550's and the parrallel rails (we did ur own version of it on an RS and works GREAT)
adam
Z-1
Z1 Performance is offline   Reply With Quote
Old 07-13-2002, 01:06 PM   #12
jeffg
Member#: 2958
2001 WRX (GC8)
Adam,
While a full stand alone unit is very much the way to go, price is the big difference here. The greddy Emanage is not meant to compete with Link and TEC Ecu's. It is meant to compete with SAFC's and Field Fuel Contollers, and the price point make that clear. A unit that normally retails for $379 should not have to compete with a $1000 Link unit or a more expenisve Tec3. Just no the same ball park.
Sure if you can afford it, get a TEC or a Link.
Please there is the tuning part. Since the Emanage is modification of the stock fuel and timing map, it is easier for beginning tuners to set it up. I am sure I could pull off a base Tec map, but I would be nervous for like hte first 6 months.
It all comes down to what you need. Basic fuel and timing control and nothing else, get an Emanage, if you need more get a Link or a TEC.
Thats all, no real competetion.
J
Old 07-14-2002, 01:45 AM   #13
Z1 Performance
Member#: 9327
I agreee, but the E Manage witht the optional sensors to do timing, etc,. bring the cost up ALOT.
Not to mention that the optional features whihc make it a halfway decne tpiece can only be tuned by an authorized dealer. At that point I think the LINK2 becomes the CLEAR winner, plus it is plug and play for the RS!
adam
Z-1 Performance
www.z1auto.com
Old 07-14-2002, 01:57 AM   #14
KillerTHC
Member#: 4942
01 SRP 2.5 RS-T
Ludespeed Stage 3 Link'd
how much do dealer's charge to tune them? if you plan to mod your car (more i guess), it's gonna be a PITA to go to a shop everytime you want to get your car tuned.
KillerTHC is offline   Reply With Quote
Old 07-14-2002, 03:49 AM   #15
Ethan
Member#: 246
i saw the Emange system today for a little bit less then $200 and the software to go with it was right there too for another $90. Seem's pretty cheap.
Ethan is offline   Reply With Quote
Old 07-14-2002, 04:02 AM   #16
adamsrs
Member#: 3768
No matter what i will go to a shop to have my car tuned because i have a MAC and not a PC......PLUS i dont trust myself to tune it!
adamsrs
Old 07-14-2002, 05:25 AM   #17
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
mmm link2 is plug and play for RS? how is this... system...
HOK is offline   Reply With Quote
Old 07-14-2002, 05:26 AM   #18
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
how much too...? didn't see it on your page... Z1
Old 07-14-2002, 09:39 AM   #19
inpreza kid
Member#: 3334
link2 plug and play? last time i checked there was no plug and play for 2.5RS. only wrx. the first link i think there was a plug and play version for the 99RS. not link 2 anyways.
i did some research on the e-manage. i agree with Z1. its not worth it. with ignition and fuel harness it brings the cost up. also it has to be tuned by a greddy dealer. IMO this is like the uni chip.
inpreza kid is offline   Reply With Quote
Old 07-14-2002, 11:38 AM   #20
seven881
Member#: 8828
01 BRP 2.2T Hybrid
10 VW Grocery Getter
It looks like AMR has the plug in play Link2 for 99-02 GC8's now, but it's an additional harness that'll plug in. At least you won't have to hack wires.
http://www.carmodifications.com/Link...ink-plugin.htm
seven881 is offline   Reply With Quote
Old 07-14-2002, 12:39 PM   #21
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
mmm this is new right? who makes the plug and play harness? AMR or LINK? also how would the ecu see boost? going to research now...
Old 07-14-2002, 03:52 PM   #22
jeffg
Member#: 2958
2001 WRX (GC8)
Adam,
retail for the optional wire harnesses to add functionality is $40 each. That is not a lot f money.
For a turbo car you are looking at
$279 +$120 = $399. Then if you are installing yourself you need the software $140
That is $539 for eveything you need.
Now Link prices, using WRX prices, since there is no Plug and Play for the RS.
$1250 for link, plus $70 for serial link
That is $1320, more than double the price of the entire greddy unit.
Again, I will stress that these are not competing products. There is no way the Emanage will compare the features and ability of any fully stand alone product.
to be more effective you would have to compare it against the SAFC+ITC+ some way to read boost pressure for your tuning.
retail for an SAFC is $419 and ITC is $399.
again you see the savings.
If what you need fits in this piggy back category, then the Greddy Emanage is another choice to consider.
J
Old 07-14-2002, 04:25 PM   #23
scubaracer
Member#: 4909
1992 legacy 2.2Turbo
silver sports sedan
Arrow
FYI jeffg, at www.modacar.com you can get an s-afc and Itc for a little under $600.
just some extra info
scubaracer is offline   Reply With Quote
Old 07-14-2002, 10:17 PM   #24
jeffg
Member#: 2958
2001 WRX (GC8)
I was going purely off of suggested retail parts.
I saw a quote for an Emanage, with harnesses installed and tuned for $500.
So there are deals to be had anywhere.
J
EDIT: really nice site by the way, thanks for the link.
Old 07-15-2002, 02:07 AM   #25
Chav
Member#: 3269
2001 2.5RS Sedan STM
RSTi
There IS a plug and play harness for the Link 2 for the gc8. Go to www.carmodifications.com and call them. They source the harness from a person here in the US that builds the harness. The harness simply plugs into the Link and plugs into the existing ECU harness.
-Chav
Chav is offline   Reply With Quote
Apexi Super Afc2 Controller And Hks Fuel Cut Defender For Sale!! Waking The Fallen Engine/Power/Exhaust 2 09-14-2006 12:33 PM
hks fuel cut defencer 387hardcore Mid Atlantic Impreza Club -- MAIC 1 11-26-2003 06:15 PM
HKS Fuel Cut defencer FCD neversatisfied Private 'For Sale' Classifieds 0 11-02-2003 09:09 PM
HKS fuel cut defender?? are you using it? trboCIVIC&WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 08-07-2003 08:09 PM
looking for hks fuel cut defender wiring diagram boogerwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-13-2002 11:16 PM
