Old 03-08-2013, 09:41 AM   #1176
SoapBox
Member#: 204578
S54 E46, N54 E82,
N55 E84, AKA REX8
Originally Posted by juanmedina View Post
Is only 70lbs... it may aid traction. If someone want to make tons of power 5-speed suck.
The car is 2wd, and a fraction of the weight. That's a LOT LESS traction, and thus a lot less stress on the trans.
You won't be breaking 5 speeds at anywhere near the power levels you do in a 3100 lb, RWD Subaru.
SoapBox is offline   Reply With Quote
Old 03-08-2013, 09:42 AM   #1177
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
But CJ, I want to shockload the poor gears of an AWD car by shifting like a jackass!
OrbitalEllipses is offline   Reply With Quote
Old 03-08-2013, 10:20 AM   #1178
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
If you're making "tons of power" in this car, then I think you can afford the solution- PPG!
Frank A is offline   Reply With Quote
Old 03-08-2013, 10:22 AM   #1179
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
Iknowrite?!
Old 03-08-2013, 10:30 AM   #1180
spaceywilly
Member#: 174268
Yeah PPG 5 speed and front LSD makes a lot more sense than an STI 6 speed to me. You would be shifting way too much in a 6 speed I think. But hey it's your car, build it however you want.
spaceywilly is offline   Reply With Quote
Old 03-08-2013, 09:29 PM   #1181
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
LOL my car weights 3000lbs with me in it and I broke my Albins tranmission.
If I am making real tons of power PPGs will break
Old 03-08-2013, 10:43 PM   #1182
TwinscrollGT35R
Member#: 256810
Well I have been tossing around the idea of buying a kit and building one up similar to my wrx. But I know a 5spd, wide sticky tires, 500whp 35r is going to break a 5spd. If the skid pad numbers are correct that might also oil starve the 5spd and the motor. But least the older six has the oil pump and you can dry sump the engine.
And for the record.... my 5spd lasted 100k miles at gt30r levels. I know a lot is the driver. But this car has some potential.
TwinscrollGT35R is offline   Reply With Quote
Old 03-10-2013, 12:37 AM   #1183
hkerekes
Member#: 66310
2015 korean muscle
Morons + power = broken parts.
hkerekes is offline   Reply With Quote
Old 03-11-2013, 12:20 AM   #1184
mhoward1
Member#: 9481
1832 Steam Buggy
Wood
OK, still 1,000 lbs heavier.
mhoward1 is offline   Reply With Quote
Old 03-11-2013, 09:02 AM   #1185
SoapBox
Member#: 204578
S54 E46, N54 E82,
N55 E84, AKA REX8
And presumably AWD. He's just not grasping it.
Old 03-11-2013, 09:44 AM   #1186
KC
Member#: 442
13 Crosstrek XV
00 S2000
The tires will break free and spin up before anything breaks. Remember, they're not pushing power through an AWD drivetrain. It's RWD (FWD, but in the rear of the car if that makes any sense)
With no resistance, the gears don't take the same levels of abuse as they did in an AWD and ham-fisting.
--kC
KC is offline   Reply With Quote
Old 03-11-2013, 09:55 AM   #1187
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I broke my 5spd at 220 lb-ft (very low reading Mustang) in my 2600 lb Imprea L when I was RWD. I actually broke my 4.11 and 4.44 rear ends first. When I went to the 3.9 r180, second gear gave up.
I was on 215 width Azenis...not the most tractive force.
Old 03-11-2013, 11:01 AM   #1188
TwinscrollGT35R
Member#: 256810
--kC
Have you ever launched a car? I see a s2000 and a g8 listed so maybe. But both those have better drivelines then a 02-06 wrx
You launch a car at a autocross lets justsay.. The load shock is going to eat that 5spd. The resistance goes up with wider/sticky tires. And the load goes up on the gearbox. So where is the fuse in the system? Axle or Clutch?
We still have not addressed the oiling issues of a car that can pull 1.8? g's
The 5spd is going to have oiling problems, The 6spd 04-07 has the internal pump. And the engine can be dry sump.
Anyone that buys a stock bugeye donor car to build this, is going to get screwed on the glass gearbox 5spd.
Old 03-11-2013, 11:07 AM   #1189
KC
Member#: 442
13 Crosstrek XV
00 S2000
*snip*
Yes. 2002 WRX Wagon. 2003 ProSolo National Champ. (Among other ProSolos over the 2001-2004 years with the car).
Didn't blow up anything. Never hamfisted/jammed gears either. Never had an issue and the owner after I that still has the car, hasn't either. Said it still shifts like new a few years ago. (And he bought it to autox, knowing its history, but then got into karting).
--kC
Old 03-11-2013, 11:08 AM   #1190
KC
Member#: 442
13 Crosstrek XV
00 S2000
And what was the reason for that? IIRC the 818 will be using the front drive and not rear output.
--kC
Old 03-11-2013, 11:32 AM   #1191
mhoward1
Member#: 9481
1832 Steam Buggy
Wood
--kC
correct.
Old 03-11-2013, 12:00 PM   #1192
Swine
Member#: 16197
05 LGT 18G-beater
12' Coyote Stang M6
So how does the center/front dif work on this car? The center diff locked to run 100% power to the front?
Swine is offline   Reply With Quote
Old 03-11-2013, 12:20 PM   #1193
mhoward1
Member#: 9481
1832 Steam Buggy
Wood
The engine is mounted in the rear, so they drive the rear wheels instead on the front.
Old 03-11-2013, 12:38 PM   #1194
TwinscrollGT35R
Member#: 256810
Yes I am sure there will be a center diff lock or removal.
Its a shame as most will not opt for a good lsd and be driving a one legger.
Old 03-11-2013, 12:53 PM   #1195
Homemade WRX
Member#: 33782
96 bastard child
--kC
What was the reason it broke? Fatigue. It actually broke while I was rolling into second gear.
However I was also pointing out that shorter final drives reduce the torque loading on the trans.
Old 03-11-2013, 03:43 PM   #1196
TwinscrollGT35R
Member#: 256810
But if I understand correctly, Those loads will increase when a 1.5 lsd is installed. So if you are using a 02-05 wrx donor car. 5spd you can run open front diff or upgrade to the 1.5 lsd and increase the chance 10 fold to popping the 5spd. Not adding track grade tires to the mix.
Not sure why you would spend all the time building a car from a kit form to put a weak gearbox in. I'm surprised F5 has taken this route. As if 5spds begin to fail, It will only hurt their product line.
And if 70 lbs is all the weight gain for having a reliable gearbox. I'll take the 70lbs. I can easily get the back in other areas anyways. Wheels, Flywheel, Seats and a Diet..
I'm just saying its not the best route. And like myself and a few others that have made a 5spd last... The guy off the street that doesn't know the history like we do is going to have issues. Even more so when the open diff is swapped out.
I better start buying up 5spds for resale..
Old 03-11-2013, 06:20 PM   #1197
Homemade WRX
Member#: 33782
96 bastard child
Your LSD argument doesn't differ from my scenario. I had a mechanical LSD in my car. Besides which, I'm in your corner. A stock 5-spd is fragile and oiling issues will need to be addressed. As stated, I'd still rather drop the getrag in there.
Old 03-11-2013, 07:22 PM   #1198
mhoward1
Member#: 9481
1832 Steam Buggy
Wood
Well since the car doesn't with any transmission you can put in what you want.
Old 03-11-2013, 08:01 PM   #1199
Mechie3
Member#: 120152
Ffr wanted a single donor vehicle and a $15k pricepoint. Sti's are harder to come by and cost more. My 02 wrx has 188k miles with a vf39 and original motor and trans. My 06 had 351wtq and the gearbox lasted 50k miles with 4 years of hard launches with wide r comps. The 818 will be fine.
Mechie3 is offline   Reply With Quote
Old 03-11-2013, 08:49 PM   #1200
KC
Member#: 442
13 Crosstrek XV
00 S2000
I would be concerned with the ease at which the tranny can be removed and repaired.
--kC
06 WRX powered mid-engine TR-42 track/street car build hipowernut Subaru Conversions 1779 03-24-2016 10:12 PM
FS 1965 COBRA Factory Five Racing replica : Arlington Texas MotorCity Private Vehicle 'For Sale' Classifieds 0 05-23-2010 10:55 AM
Factory Five Racing GTM supercar NYCshopper Non-Subaru News & Rumors 7 12-12-2007 03:57 PM
Factory Five Racing roo21 Off-Topic 72 09-13-2007 11:26 AM
Factory Five Racing Shelby Cobra Lucky Loser Private Vehicle 'For Sale' Classifieds 0 08-03-2006 06:00 PM
