Welcome to the North American Subaru Impreza Owners Club Monday October 24, 2016
Old 02-12-2011, 12:08 PM   #1
Member#: 231049
Default Upcoming Clutch Replacement...Other Stuff to fix While In there?
1996 Legacy Brighton Wagon 5 Speed w/156k on it and the clutch is needing replacement badly. Anything else I should be replacing/checking while I have the tranny out?
Muffler gaskets? Center Bearing? Shifter bushings? That Dogbone thingy between the tranny and the engine under the hood? Motor or tranny mounts?
Yeah, I know, this could get kinda expensive, but we're gonna keep the car for the foreseeable future.
dimwittedmoose is offline   Reply With Quote
Old 02-13-2011, 09:54 AM   #2
Member#: 208727
2004 sti
Reseal the rear cover on the right side of the motor. This is behind the flywheel. If plastic, there is a replacement metal cover, if you go this path get the new cover with new screws. Look at the piston pin cover on the left side for leaks also.
oldmansti is offline   Reply With Quote
Old 02-14-2011, 03:39 AM   #3
Member#: 172522
1998 Legacy GTB Ltd.
I'm a fan of taking engines out. When my clutch is due, I'll be lifting it and dealing to all my seals that look old or are leaking, do spark plugs, clean engine bay, maybe do some performance mods like new intake, check up on my split fuel rail and turbo, chuck in some group N engine mounts. that sorta ****.
ReubenH is offline   Reply With Quote
Old 02-20-2011, 01:18 AM   #4
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
If you can, just drop the tranny, and go through the backside for the clutch job. Replace the rear crank seal, and do what oldmansti said. The plastic ones are crap, subaru switched to those for a couple model years then went back to a solid aluminum piece. Make sure you have an impact driver type thingy, the type you hit with a hammer., to get the screws out. They are a #3 phillips IIRC.
Clutch install - what else to do while I'm in there? azscooby Transmission (AT/MT) & Driveline 2 05-03-2010 05:01 PM
Rear Main seal replacement, what else while in there? ScubaruImpreza05 Transmission (AT/MT) & Driveline 5 03-22-2010 11:25 AM
Replacing Clutch, anything else to replace while in there? optntrader Transmission (AT/MT) & Driveline 1 04-28-2009 12:01 PM
Installing clutch very soon, while in there what else should I upgrade? Drew888 Transmission (AT/MT) & Driveline 3 12-16-2006 11:45 PM
Is there PVC Pipe Glue? Need to fix leaks in some PVC pipe. Cjchaps Off-Topic 14 12-28-2004 08:40 PM
