Old 02-12-2011, 01:02 PM   #1
Chico Nakajima
Member#: 151506
2000 Forester
Default Fix head gasket leak with Ceramic Coat product?
My 2000 Forester has had a head gasket leak for oh, 6 years or so. Someone told me they had success fixing a head gasket leak in another vehicle using a product called something like Ceramic Coat. Directions were:
drain cooling system; add Ceramic Coat and water and run car a few days with it in the system; drain cooling system; flush; then put coolant back in.
Has anyone heard of this product, or something similar?
Thanks!
Chico Nakajima is offline   Reply With Quote
Old 02-12-2011, 01:37 PM   #2
sol_tegra
Member#: 259406
02 WRB WRX
do u have a coolant leak or oil leak? if its a coolant leak it will seal the leak but if its oil leak it wont help since your putting the chemical in the cooling system and not the lubrication system. on top of that, its only a temporary fix not permanent.
sol_tegra is offline   Reply With Quote
Old 02-12-2011, 01:42 PM   #3
feint05
Member#: 152984
2004 jewbaru
jewbuilt, polish tuned
ive heard of many band aid patch systems like this, and some of them certainly do work, however when the band aid comes off its autrocious, basically alot of those products clog up your entire cooling system, so when you finally replace your head gaskets, you have to replace your radiator and hoses, and then your heater core is suspect. M Forester saw its fair share of crap products, i bought it after it gave way and was fully repaired, now even with an all new cooing system, im still flushing out chunks and grossness that have dislodged from the heater core
feint05 is offline   Reply With Quote
Old 02-13-2011, 10:27 PM   #4
Chico Nakajima
Member#: 151506
2000 Forester
Thanks for the replies-
It's a coolant leak, but it doesn't seem too bad, and it's been running OK for years.
Old 02-13-2011, 11:21 PM   #5
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
6 year long HG leak? wow
Old 02-13-2011, 11:29 PM   #6
Wrencher86
Member#: 250463
2010 Impreza 2.5i
Radiator stop leak products are trash. Keep them away from your car.
Wrencher86 is offline   Reply With Quote
Old 03-13-2011, 03:43 PM   #7
ncgal
Member#: 276680
Read some good things about Bar's products. Anyone tried them?
ncgal is offline   Reply With Quote
Old 03-13-2011, 04:34 PM   #8
blackfang
Member#: 131347
2007 Legacy 2.5i SE
98 Z/28, VN 900 custom
Put that stuff in man, it will fix the leak. After it screws up the engine and you have to replace the engine, then your leak is fixed.
Bar's just like any other stop leak is garbage. I personally have seen people put that into an engine and ended up still having to fix the leak, or replacing the engine.
blackfang is offline   Reply With Quote
Old 03-13-2011, 11:14 PM   #9
wizzle-stick
Member#: 160534
2002 impreza rs
im in the middle of a full rebuild due to a hg leak. tried the stopleak and it slowed the leak for a little...then it went back to leaking as normal.
wizzle-stick is offline   Reply With Quote
Old 03-13-2011, 11:18 PM   #10
Jessekrs123
Member#: 236927
2015 BRZ, 93 Legacy,
1984 BRAT
I wouldn't half-ass bandaid a headgasket leak especially if it means dumping foreign liquids into your engine.
If I were you, I would replace the headgasket asap, along with timing components etc... I'm sure your car is due for one anyway seeing how it is 10+ years old.
Jessekrs123 is offline   Reply With Quote
Old 03-14-2011, 09:49 AM   #11
Bluefoton
Member#: 141373
2008 2.5i-hatch -
It's similar to treating a nosebleed or a finger cut by eating a huge trans-fat saturated burger. Might clog the wound, but chances are it will clog your heart and arteries as well
Old 03-14-2011, 06:53 PM   #12
Wrencher86
Member#: 250463
2010 Impreza 2.5i
I'm stealing this example next time I have to tell someone why stop leak sucks so much.
turbo blanket with ceramic coating? spritefiend Newbies & FAQs 4 07-31-2007 11:11 PM
Friends wants to buy 2.2L Outback with head gasket leak... poison Normally Aspirated Powertrain 5 10-14-2006 11:30 PM
Brand NEW PDE catless DP - with Ceramic coating 2cati Canada Region Forum 0 10-20-2005 09:55 PM
Yay!!! next time you know you have a head gasket leak.. fix it, don't wait! RiftsWRX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 39 08-22-2005 03:12 PM
AVO450 with ceramic coating DarthChicken Private 'For Sale' Classifieds 3 05-25-2005 02:05 AM
