Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 02-12-2011, 11:53 PM   #1
subiewrx001
Member#: 193591
04 WRX VF34
water/meth, spt intake
Default installed coolingmist water/meth trunk kit
It was easy to install I recommend you buy one if you have an extra $250 shipping included cause the trunk mount kit is on sale. I tapped the top of my intercooler and it was way simple also I am just running windshield washer fluid and my motor feels better already I have it spray at 10psi but I will take pics and I am going to take some datalogs tomorrow to see how the motor is handling everything
subiewrx001 is offline   Reply With Quote
Old 02-13-2011, 12:06 AM   #2
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
pics of install?
bhhamblin is offline   Reply With Quote
Old 02-13-2011, 12:36 AM   #3
wantsti
Member#: 134764
04 sti
java black pearl
Don't you need a tune to run meth?
wantsti is offline   Reply With Quote
Old 02-13-2011, 12:50 AM   #4
subiewrx001
Member#: 193591
04 WRX VF34
Well I am running windshield washer fluid just so the lines wont freeze and I think there is 30% methanol in it so right now it is just preventing knock but I will take pics and datalogs tomorrow
Old 02-13-2011, 12:53 AM   #5
subiewrx001
Member#: 193591
04 WRX VF34
Its basically what race teams do when they flood the cylinder with fuel just to help cool eveything and prevent knock but in the summer I may get the coolingmist gauge with failsafe and tune for meth but the pump can only handle a 50/50 water/meth mix so you can't go 100% meth
Old 02-13-2011, 01:07 AM   #6
subiewrx001
Member#: 193591
04 WRX VF34
Just a pic of the tank after mounting it to the floor of my trunk. I didn't have any lines ran.
Old 02-13-2011, 08:35 PM   #7
subiewrx001
Member#: 193591
04 WRX VF34
Pic of the injector I tapped onto my stock intercooler.
Old 02-13-2011, 08:36 PM   #8
subiewrx001
Member#: 193591
04 WRX VF34
Pic of the line and injector
Old 02-13-2011, 09:01 PM   #9
08WhiteRex
Member#: 187453
2012 Mulletmobile
Hmmm..... Interesting placement of the injector. Care to elaborate on that decision?
08WhiteRex is offline   Reply With Quote
Old 02-13-2011, 09:08 PM   #10
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
It looks fine to me. Right before the throttle body where it should be.
Old 02-13-2011, 11:48 PM   #11
subiewrx001
Member#: 193591
04 WRX VF34
That's how coolingmist installed it onto an APS topmount IC as long as the mist a few inches from the opening it will suck into the motor it only sprays at 10psi so it will suck it in
Old 02-13-2011, 11:51 PM   #12
subiewrx001
Member#: 193591
04 WRX VF34
Pic of my datalog my phone doesn't take a wide enough pic to get it all but my knock advance added 4 degrees of timing
Old 02-13-2011, 11:54 PM   #13
subiewrx001
Member#: 193591
04 WRX VF34
K is boost
L is wastegate duty cycle
M is throttle opening angle
N feedback knock
O finelearning knock
Old 02-13-2011, 11:57 PM   #14
subiewrx001
Member#: 193591
04 WRX VF34
This was a second gear pull
Old 02-25-2011, 07:51 PM   #15
subiewrx001
Member#: 193591
04 WRX VF34
Its been 2 weeks and everything is working flawlessly. This is the best thing I have bought for my car so far, I am getting better gas mileage don't really know how, I am very happy with the kit :-).
Old 02-26-2011, 03:52 PM   #16
JokerDMX
Member#: 175664
03 WRX
FP Green/Built&Cam'd 2.5L
I have the exact same Tank/Pump setup, ran 80/20 mixture with no problems. How big is your injector? Do you have any kind of gauge to make sure its still flowing?
JokerDMX is offline   Reply With Quote
Old 02-26-2011, 04:23 PM   #17
subiewrx001
Member#: 193591
04 WRX VF34
I am not sure the size I just did the 200 to 300 hp range when you order it. I don't have a gauge but I am going to wire a light in to turn on when the switch is activated. I had a few air bubbles still in the line so I did a pull then checked to see if the air bubbles were gone and they were. I am just running it at 10psi which the switch comes set at 10psi.
NJ: Coolingmist Water Meth Kit. CHEAP! rockle3 Engine/Power/Exhaust 15 06-03-2010 01:24 AM
F.S. Lamco boost gauge and coolingmist water/meth kit sunnyniazi SWIC Private Classifieds 8 10-10-2007 08:48 PM
Blitz icolor and Coolingmist meth trunk kit...asap bloopsta26 Engine/Power/Exhaust 14 07-30-2007 07:05 PM
Perrin Blowout, Engine Build Essentials, Turbos, Coolingmist Water/Meth Kits & MORE!! Innovative Tuning Engine/Power/Exhaust 30 06-27-2006 07:17 PM
