#1 |
Member#: 259948
W. Canada
Vehicle:MPS 510 whp GTX35R Long Rod Motor |
Hey guys, I am running a Hallman Pro RX MBC and am trying to set up my max boost. I am a little unsure of which boost reading I should be using in Romraider logger?
There are so many, which one should i have selected to know my realtime boost level? Sorry to put this in the built section but there is way way more people in this thread floating around and many with the knowledge i need!! Thanks
#2 |
Member#: 115104
Vehicle:2003 WRX Sedona Red Pearl |
Your boost gauge is a good start. The ECU doesn't know how much boost your running because your using a MBC. It can only guess.
#3 |
Member#: 259948
W. Canada
so the cars ecu does not know what boost the car is running?
oh and my boost gauge is in the mail still, delyed at customs |
#4 | |
Member#: 51961
RMIC
Vehicle:2005 STi 2012 WRX |
How do you think the ECU controls the boost if it doesn't know what it is? I'm not sure what it's called on your ECU, they're all called something different. Any of the terms that call themselves "manifold relative pressure" or similar are what you want. If you see multiple, just log them all, on some ECUs one of them will saturate at a low boost level while the others are fine. I believe the "universal" one to use is "Manifold Relative Pressure (4 byte)", if you have one by that name. |
#5 | |
Member#: 259948
W. Canada
this sounds like a much better answer!!!! haha |
#6 |
Member#: 152576
SWIC
Vehicle:2006 STI 10.8@ 129 www.Mayhemtuning.com |
#7 |
Member#: 51961
RMIC
Depends on the person controlling the knob. The only real downside to an MBC is the ECU loses the ability to cut boost when it sees excessive knock. They generally aren't recommended for stock-level setups, but once you move to big turbos, EWG, etc, many people prefer MBCs because they have less of a tendency to overboost and can be more stable/reliable.
#8 |
Member#: 115104
My apologize for my post. I guess I should have worded that a little differently than what I did.
#9 |
Member#: 108089
Vehicle:2003 WRX NF Performance |
The map sensor (on your throttle body) is used for reading boost.
Your ecu on the stock sensor can detect up to 22.xx -/+ However, with a MBC, the ecu has no control over boost, that's all. |
#10 |
Member#: 198053
Vehicle:01.5 biturbo |
you're gonna want to zero out any boost related tables, wgdc, target boost, etc etc
and the correct parameter for reading boost in rom raider is manifold relative pressure. remember the stock map sensor only reads up to ~25psi |
#11 |
Member#: 259948
W. Canada
I am currently setting up the MBC as part of a dual EBCS and MBC
setup. My tables are all maxed by my tuner for WOT so the MBC takes over but still retains the fuel cut |
| Thread Tools | |
| Display Modes | |
| Setting up Hallman MBC with RomRaider Logger?? | binjoau | Open Source Reflashes | 2 | 02-14-2011 08:00 PM |
| Need help with RomRaider logger issues | balls2dawalls | Mid Atlantic Impreza Club -- MAIC | 8 | 11-16-2010 04:00 PM |
| lm2 working with romraider logger? | rapturem3 | Open Source Reflashes | 0 | 12-25-2009 02:14 PM |
| PLX m300 with Romraider Logger? | cthor | Open Source Reflashes | 2 | 09-21-2009 02:17 PM |
| suggestions on tune on built motor with gt35r | scutzi128 | UTEC | 4 | 03-10-2008 11:14 PM |
