Old 02-13-2011, 03:07 PM   #1
pspryu101
Member#: 273198
Default OEM wrx catback on NA wagon
Should I get it? He's selling it for 50. Would it fit mines though? Also would it be any louder than my stock right now? Also would it be bolt on mines?
pspryu101 is offline   Reply With Quote
Old 02-13-2011, 03:08 PM   #2
dtfdanyo
Member#: 195365
2005 WRX Wagon
youre going to have to either...
a)rotate the flange on your stock piping so it will bolt uo
or
b) buy and adapter. there were some "ms3 adapters" on rs25.com. you should check there.
dtfdanyo is offline   Reply With Quote
Old 02-13-2011, 03:53 PM   #3
T Wrex--OH
Member#: 179478
2000 Impreza 2.5 RS
Sedona Red Pearl
Well OP, if you searched instead pulling a N00b move, you would have found that the WRX will be little, if any louder than your stock exhaust.
T Wrex--OH is offline   Reply With Quote
Old 02-13-2011, 03:54 PM   #4
pspryu101
Member#: 273198
Hmmm.. how bout the sound? As far as the boxer rumble and whatnot? Is there a difference at all? I seen sti cats on NAs that sounded pretty good but this cat is from a wrx
Old 02-13-2011, 04:36 PM   #5
ryuheixys
Member#: 242708
2008 Impreza 2.5i
I have a WRX exhaust on my 08 2.5i and it definitely is smoother at the top.
You will notice that you have to press the pedal a bit more on the low end.
It is definitely not louder, but just enough so you can listen to the RPM and not look down at the tac.
Worth it if you don't have to do any pipe work. Bolt on in my case.
ryuheixys is offline   Reply With Quote
Old 02-13-2011, 06:14 PM   #6
Ogden
Member#: 1748
'09 Outback Sport
OBP over DGM
First, you should fill out your profile so that we can tell what kind of car you have. Different answers for different years.
You will not get the rumble from a cat-back. You have to change the headers.
This topic has been covered many, many, many times. You can find all the answers you are looking for if you do a little searching. You will also save yourself a lot of flames if you come back and offer a bit more information about what you are looking for, your car type, etc.
Ogden is offline   Reply With Quote
Old 02-13-2011, 07:13 PM   #7
smokeyandthebandit05
Member#: 219940
2012 Forester
I have a cat back for a wrx and I didnt do anything special, it just bolted right up. Everything was the same between the 2010 OBS and 2010 WRX exhaust
edit: This is NOT my video but it is the one that convinced me to buy it
http://forums.nasioc.com/forums/show....php?t=1976588
smokeyandthebandit05 is offline   Reply With Quote
Old 02-14-2011, 03:54 PM   #8
royalnewjersey
Member#: 250954
2013 WRX Hatch
^^^ You do realize that the video you posted is NOT an OEM stock wrx catback. It's an aftermarket company called Tsuedo.
The original post was specifically asking about OEM wrx catback, and the fitment onto his "N/A wagon" of unknown model and generation. Posting up a link to a Tsuedo catback (which is not even your car), doesn't help answer the question.
Why do you think people don't search anymore? Because no one takes the time to even read the original questions and reply correctly.
royalnewjersey is offline   Reply With Quote
Old 02-14-2011, 08:35 PM   #9
thymighty
Member#: 253198
2006 9-2x
What is "mines"?
thymighty is offline   Reply With Quote
Old 02-15-2011, 06:44 PM   #10
kero
Member#: 94299
2000 2.5 RS Sedan
SRP
^^ His car LOL!
I don't think he meant land mines ROFL!
kero is offline   Reply With Quote
Old 02-19-2011, 06:23 PM   #11
Suby<3777
Member#: 192178
99' Impreza wagon
All red!
If you want better sound go with an OEM STI axle back. Thats what I have on my 99 Impreza L. I just cut the flange off the axle back, rotated it, and it bolted right on.
I have a related question for those of you out there. Would putting an oem sti exhaust on my NA 99 Impreza L get rid of the back pressure in the exhaust system. I am having a little hesitation in my excelleration in first and second and am wondering if this exhaust is contributing to the problem?
Suby<3777 is offline   Reply With Quote
oem wrx catback, h-brace, oem swaybar FS! scarsofterror SCIC Private Classifieds 12 08-19-2009 12:18 PM
Turbo Sedan Front Sway Bar on NA Wagon mslstixx Brakes, Steering & Suspension 0 02-16-2008 12:54 AM
WRX catback on 04 OBS wagon ?? boost4life Normally Aspirated Powertrain 4 06-07-2006 10:40 AM
Houston: Anyone want an OEM WRX Catback? NeoteriX Texas Impreza Club Forum -- TXIC 6 03-25-2004 07:51 PM
OEM sedan lip on a wagon? wrxxed Interior & Exterior Modification 1 12-07-2002 11:13 PM
