Old 07-11-2002, 07:46 PM   #1
sidewayz
Member#: 5810
2001 S366 2.5RS
Default does this sound right???
just ran the good 'ole g-tech,
full interior = stereo, Cobb intake, Apexi exhaust, UR pulley
Magnecor wires and Denso Iridium plugs.
15.1 @90mph as usual.....BUT
I ran a HP run, 145hp Does this sound right???
what are you guys hitting for hp figures ????
sidewayz is offline   Reply With Quote
Old 07-11-2002, 09:39 PM   #2
KillerTHC
Member#: 4942
01 SRP 2.5 RS-T
Ludespeed Stage 3 Link'd
145 sounds right. on a real dyno, some NA 2.5's were putting down 150's and they had headers/intakes/exhausts and other goodies. the WRX's only put down 180.
KillerTHC is offline   Reply With Quote
Old 07-12-2002, 02:34 AM   #3
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
that time seems RATHEr optimistic to be honest...the power i might be able to believe, but then again i don't trust a G-TEch too much...one of the guys g-tech his RS and pulled 14.3...went to the track and the best time he pulled was a 14.7
jeremy
Old 07-12-2002, 09:38 PM   #4
joefocker20
Member#: 13745
2015 STI
Because G-Tech measures an EXACT 1/4 mile and the traps at the track are slightly more than a 1/4 Mile.
joefocker20 is offline   Reply With Quote
Old 07-15-2002, 02:07 PM   #5
kickin_81
Member#: 16679
2004 Forester XT
Also, if you had any more wind resistance or if the temp is warmer, your hp figures will drop. Try the G-Tech in the winter with a cold engine... When I do my runs, I put down 3100 lbs (myself and 40 lb spoiler) and get around 135 in 90 degree weather.
kickin_81 is offline   Reply With Quote
does this sound right to you?? Scoobs Warranty Issues & SOA Problems 14 07-16-2002 08:50 PM
Does this sound right? Jademonkey Normally Aspirated Powertrain 0 05-06-2002 11:42 AM
does this sound right for stock time? dub976 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-12-2001 02:31 PM
Installed Boost gauge -- does this sound right? 2.0 guy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 10-02-2001 09:43 AM
Powdercoating info...does this sound right? JasonRan Interior & Exterior Modification 5 08-01-2001 07:13 PM
