Old 07-11-2002, 08:34 PM   #1
Bobby321
Visiting NASIOC Timeout
Member#: 19774
Exclamation wrx intercooler on GC8
Has anyone installed the wrx intercooler on a GC8 Preza?
If so any fitments problems?
OR do they straight up not work?
I wanted to use one on my 95 preza?
Bobby321 is offline   Reply With Quote
Old 07-11-2002, 08:38 PM   #2
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
kastle is offline   Reply With Quote
Old 07-11-2002, 08:43 PM   #3
Bankheist
Member#: 2237
2000 GC8 STi
2015 Ford Mustang GT
not to be an ass... but I couldnt find any info on that either.
Bankheist is offline   Reply With Quote
Old 07-11-2002, 09:05 PM   #4
Avenger
Member#: 1234
From what I read the wrx IC will fit but you need to shave the throttle body shorter.
Avenger is offline   Reply With Quote
Old 07-11-2002, 09:36 PM   #5
Bobby321
Member#: 19774
Yes kastle i did do i need to state that in every post
Old 07-11-2002, 11:00 PM   #6
akcel
Member#: 10268
gc8 I ride ride 24s
with the top down low.
yep i looked there also...didnt see any info on WRX ic on the gc8 rs engine....i see engine transplant...but thats all
akcel is offline   Reply With Quote
Old 07-11-2002, 11:23 PM   #7
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
From what I know about the people that put one in, you need to cut off about 8-10mm of the intercooler outlet. This will allow you to squeeze the intercooler between the TB and firewall.
Impreza Rider is offline   Reply With Quote
Old 07-11-2002, 11:40 PM   #8
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Yes, just cut the IC outlet a bit, it will fit.
wcbjr is offline   Reply With Quote
Old 07-11-2002, 11:47 PM   #9
Bankheist
Member#: 2237
2000 GC8 STi
i dunno about all that... I put a stock IC on my throttle body just for the hell of it one day.... closed the hood... everything fit fine... but I'd rather hack off some of the IC than some of the throttle body
Old 07-12-2002, 02:26 AM   #10
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
take a 1/4" off the Outlet of the intercooler and a 1/4" off the throttle body and you are set.
jeremy
Old 07-12-2002, 03:13 AM   #11
Imprezha
Member#: 6818
2002 NSX
2010 Gen Cpe,2016 Outback
The intercooler will fit between the throttle body and the firewall without shaving the intercooler. Trust me it fit. Just look under my hood.
Imprezha
Imprezha is offline   Reply With Quote
Old 07-12-2002, 05:35 AM   #12
akcel
Member#: 10268
gc8 I ride ride 24s
Imprezha
but you blocked of the dual entrance in the back and made a single side entrance...the reason we need to cut some off the outlet is because we retained the dual entry...which is mainly the fitting problem
Old 07-12-2002, 08:18 AM   #13
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
if you didn't shave the IC hehehe don't go over any big pumps... any of that end up in your manifold and its game over... i have pics... shave 1/4 off IC outlet should be enough..
HOK is offline   Reply With Quote
Old 07-12-2002, 12:55 PM   #14
Bobby321
Member#: 19774
Thanks alot for all your help i didnt want to buy one and then not have it fit.....
but what do u mean by Dual entry???
Old 07-12-2002, 01:22 PM   #15
Bankheist
Member#: 2237
2000 GC8 STi
the underside of the IC has to entry inlets that allows the forced air from the turbo to enter.
Intake... turbo.... intercooler... throttle body... etc.
Relocating the brake fluid tank down a few inches is a possibility as well.
Old 07-12-2002, 02:12 PM   #16
Bobby321
Member#: 19774
ok ic now.... thanks everyone
Old 07-13-2002, 12:07 AM   #17
Imprezha
Member#: 6818
2002 NSX
Maybe I will shave the intercooler a little bit. I thought u guys meant the distance from the throttle body and the firewall. But yeah, you will have to have the air enter from the side.
Imprezha
Old 07-14-2002, 11:59 PM   #18
seven881
Member#: 8828
01 BRP 2.2T Hybrid
10 VW Grocery Getter
I was doing the fitting for the WRx intercooler and here's some pics.
It'll fit after shaving off some of the outlet of the IC, but it's not a great fit. You should move the AC cooling line (I think that's what it is) to get a really good fitting.
seven881 is offline   Reply With Quote
Old 07-15-2002, 12:00 AM   #19
seven881
Member#: 8828
01 BRP 2.2T Hybrid
Another PIC. Hehe I got a new digital camera, but I need a tripod to get really good pics.
Old 07-15-2002, 12:13 PM   #20
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
Default How much did you cut Seven881
What did you use to cut it? Can you get a pic of the shave IC outlet?
Coo man,
Kevin
latinskllz is offline   Reply With Quote
Old 07-15-2002, 05:08 PM   #21
seven881
Member#: 8828
01 BRP 2.2T Hybrid
I put the clamp on the outlet as close to the IC as possible and used that as my line to cut. Leaving me with just enough room for the clamp. I hacked it up though using a saws all. You're better off with a hac saw and a fine blade. Also, put a rag in all the IC holes to keep the shavings from getting inside, and you're going have to cut the rubber too to match the IC.
Old 07-15-2002, 05:44 PM   #22
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
Default Cool. This will be my weekend project...
Thanks dude,
Kevin...any more pics??
Old 07-16-2002, 05:06 PM   #23
jdmimpreza
Member#: 10644
2001 impreza
Blue Ridge Pearl
I just ran the a/c line underneath the pitch stop on the tranny everything is fine and it fit. No cutting please. Also I had to push the brake lines on the fire wall back a little bit so its flush. gave the intercooler more play.
jdmimpreza is offline   Reply With Quote
Old 07-16-2002, 05:27 PM   #24
seven881
Member#: 8828
01 BRP 2.2T Hybrid
Is the pitch stop the large arm connected to the engine bay and the engine, or the metal that the ac cooling line is originally bolted too? You got it to fit without cutting the IC?
Old 07-17-2002, 01:23 PM   #25
jdmimpreza
Member#: 10644
2001 impreza
Blue Ridge Pearl
yes the pitch stop is the arm attatch to the motor.
02-05 WRX intercooler on an 06 WRX justinpool2000 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 03-17-2006 05:50 PM
Modded WRX intercooler for GC8 on Ebay CUNNINGHAM Private 'For Sale' Classifieds 0 01-23-2005 06:01 PM
WRX02 Intercooler on GC8 01 Ghost Normally Aspirated with bolt-on Forced Induction Powertrain 5 08-27-2002 11:07 AM
WRX springs on GC8 shocks gypsymoth Brakes, Steering & Suspension 2 03-13-2002 09:33 AM
WRX rims on GC8 KillerTHC Member's Car Gallery 6 09-30-2001 02:31 AM
