Old 02-13-2011, 11:08 PM   #1
humboldt2.5rex
Member#: 192264
2001 2.5RS
Sedona Red Pearl
Default Jdm Ver 8 Sti Swap stumble/surge when warm- Help
So just finishing up with my 2001 2.5rs--> Ver 8 JDM STI EJ207 swap and just got it up ad running and am having a little stumble once the engine warms up.
The car will idle at 2000 rpms when you cold start it and after a few minutes of running and warming up the car will stay at 2000 rpms and then dip to 1500 rpms, then back up to 2000, over and over.
Before the surging starts I can rev up the engine but after warm and surging starts if I hit the accelerator it will stumble and drop revs. As far as I can tell I believe it is either a problem with the TPS sensor or the idle solenoid but would like to get some feedback to see if anyone has had this type of problem before or how I could test for it?
Any help would be much appreciated-- Thanks-- Lars
humboldt2.5rex is offline   Reply With Quote
Old 02-17-2011, 03:26 PM   #2
humboldt2.5rex
Member#: 192264
2001 2.5RS
Sedona Red Pearl
anyone?
Old 02-17-2011, 03:47 PM   #3
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
sounds like you have the right idea (hardware) and not swap related.
Snag a spare TPS and slap it on...or idle solenoid. That's the easiest way to check it in my opinion. Have a buddy with a WRX come over, grab his TPS (two seconds) and slap it on. See if the issue goes away.
Old 02-17-2011, 10:26 PM   #4
humboldt2.5rex
Member#: 192264
2001 2.5RS
Sedona Red Pearl
That is basically what I was thinking of doing- Are the TPS and IACV the same parts on all 02-07 Wrx and STI's? As far as I know they are, just checking though?
JDM Ver. 8 STi swap in 04 WRX...Able to pass CA Smog or BAR? i2cou4u2 Subaru Conversions 16 01-26-2012 05:54 PM
JDM Ver. 8 STi swap questions DavidisaCult Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 10-06-2010 03:52 PM
'01 2.5rs to Jdm Ver.8 STI conversion, wiring help please? humboldt2.5rex Subaru Conversions 2 08-06-2010 01:43 PM
FS CA: JD STi Ver. 8 Seats, 02 WRX Seats, 02 MoMo Wheel, JDM Ver.8 STi Gauge Cluster ViperWRX Interior/Dressup/Audio & Security 144 04-14-2010 05:20 PM
jdm ver. 8 sti heads vs usdm sti heads Peeblesmx445 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 56 12-17-2005 09:00 PM
