Old 02-14-2011, 03:26 AM   #1
DaBigs11
Member#: 262750
12 WRX
Default Strange noise with ac/heat on.
Hey guys sorry of this is the wrong place to post this. Still new obviously.
Here's the deal, after searching on here and Google with no results I figured it was time to throw in the white towel and ask.
07 2.5i only mod is a hybrid intake. Car has 153xxx miles on it ( I know). What happens is when I turn the ac/ heat on I can hear a weird sound (almost like the sound you hear from a regular after-market intake when you rev it). That sucking in air sound. Its only for a split second followed by a short bog in power, again for a split second. Didn't really notice it with the stock intake but then again I didn't have that on very long.
Happens with wot, with consistent rpms, whatever.
I've never noticed this in any other vehicle so it kind of throws a red flag for me.
Thanks in advance for any help.
DaBigs11 is offline   Reply With Quote
Old 02-14-2011, 10:21 AM   #2
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
When you say with "ac/heat on" do you mean when a/c button is selected or when defrost is selected on the vent control? If so, the a/c compressor clutch engages and can make a squeak or sudden woosh noise (my 07 does both depending on outside temp). And the quick change in load on the engine through the a/c compressor may cause a momentary drop in rpm (mine has done this since it was new).
GrundleJuice is online now   Reply With Quote
Old 02-14-2011, 06:17 PM   #3
DaBigs11
Member#: 262750
12 WRX
Sorry for not specifying. Pretty much any time air is coming out of the vents lol. Ac on, heat on, outside air, anything.
So its normal for subies than? That's comforting thank you
Old 02-14-2011, 07:08 PM   #4
Rudgers73
Member#: 141433
2006 Impreza 2.5i
Obsidian Black
Well, it doesn't make much sense that it happens all of the time when the fan is on, but if it only happens when the A/C or defroster settings are on, it shows signs of just another random scooby quirk. The A/C compressor on our cars don't have any kind of "trim". They are either full on or full off. So the drop in power and change in noise is probably the duty cycle of the compressor (since the A/C compressors on scoobys suck the life out of the engine for some reason haha).
If it happens all of the time, then I have no idea whatr it could be other than a parasitic draw from something in the fan circuit like a shorted wire.
Rudgers73 is offline   Reply With Quote
Old 02-14-2011, 07:39 PM   #5
DaBigs11
Member#: 262750
12 WRX
Could be a wire too I guess. I'll see what I can do about confirming what's up.
Thanks for the help guys
Old 02-14-2011, 07:49 PM   #6
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
Well, I think you might not get what I am trying to differentiate between as far as the climate controls. The air conditioning can be on and the vent set to outside air, and the heat can be "on" by turning the temp control dial to the red area, and all these things can occur at the same time.
If the symptoms you described in the first post occur when either the a/c button is NOT depressed or the vent selection dial is NOT set to defrost (the little wavy lines on the windshield icon) then I would not consider it normal behavior and would at least attempt to determine if there is a problem you should address.
Old 02-14-2011, 07:58 PM   #7
Clin10
Member#: 150666
2007 2.5i SE 4EAT
do you have manual, or Auto Climate control? if Auto, I will try this with my car in the morning to see if I have the same effect. The A/C DOES draw alot of power on our cars though. drops gas mileage a great deal also. I usually have it off as much as I can.
I have 110k on my car now, lol. good god you drive alot though man! hahaha!
Clin10 is offline   Reply With Quote
Old 02-14-2011, 08:33 PM   #8
thymighty
Member#: 253198
2006 9-2x
How severe is your "bog in power"? I ask because it is completely normal to feel your heat and a/c pull a bit of power out of any 4 cyl. engine. The sound you hear is probably the blower motor kicking on. The bog in power is the extra draw on your alternator. Pretty normal stuff. People on this forum tend to assume the worst right off the bat, but it makes more sense to start with the obvious.
thymighty is offline   Reply With Quote
Old 02-14-2011, 09:16 PM   #9
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
there is no way a correctly working alternator (more accurately, something your alternator is supplying voltage to) could draw enough current to cause a detectable loss of power while driving. At idle it might drop a few rpm if you suddenly demand some current.
Old 02-14-2011, 10:25 PM   #10
DaBigs11
Member#: 262750
12 WRX
Okay I see what you mean. I'll try turning ac and heat on, both using outside air and see what happens. I'll update in the morning when I get off work.
I have auto climate control so I'm not sure if it'll do it for you, guess we'll find out. Ya I do but It was the first owner that racked them up. Bought the car with 146xxx so I can build some credit because I had none. Getting a wrx in April or may hopefully
Not severe but noticeable. Enough to just BARELY jerk me forward, I mean BARELY. I'll go to autozone or pepboys and get my alternator tested just to rule that out.
Strange Shifting when AC is on Nitrous Newbies & FAQs 27 06-07-2008 03:57 AM
strange noise with new pitch stop... blahhblahh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 10-21-2007 07:42 PM
Strange noise with cold engine tlip1119 Normally Aspirated Powertrain 3 02-01-2007 08:36 PM
AC/Heat on gas mileage matt man Service & Maintenance 3 11-12-2003 10:46 PM
Humming noise with AC on. kkozma Legacy Forum 5 09-18-2001 02:59 PM
