Welcome to the North American Subaru Impreza Owners Club Wednesday June 3, 2015
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Exterior/Styling
Old 02-14-2011, 08:38 AM   #1
KillerBMotorsport
Vendor Sales Rating: (43)
Member#: 198281
2005 WRX/STi
WRB of course
Default Stealth Grill Insert - Protection for your FMIC
Similar to the Prodrive WR1, this grill insert will give your Suby front end a unique look. The Black Powder Coat Paint gives a ‘stealth’ look to your oh-so-obvious FMIC. Not only does it look good, but it provides some protection from road debris. Carbon Steel and made in the USA. Requires modification to the front bumper for installation, mounting holes drilled and no hardware included.
CLICK HERE FOR PRICING***********
02-03 WRX/STi
04-05 WRX-STi
06-07 WRX/STi
Stealth Graphic
__________________
- Highly Advanced and Full of Awesomeness - Patent Pending
vs.
V2 High Performance Aluminum
Brushed & Polished Delrin Shift knobs!
KillerBMotorsport is online now   Reply With Quote
Old 02-17-2011, 01:13 PM   #2
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
In Stock
__________________
vs.
Old 02-18-2011, 09:48 AM   #3
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
I've been asked a couple times about materials used on these so here's the specs...
The Frame is CNC laster cut from .125" thick 1018 carbon steel. It's then roll formed to match the profile of the front bumper. The Frame is 1/2" wide
The Wire is .06" diameter steel that is crimped and woven. We use crimped (instead of just woven) because it keeps the wires perfectly in place keeping the openings uniform and very square. This is the same process used on the front grills of a GMC Yukon or Cadillac CTS-V. It's extrememly durable while giving the maximum amount of open area (airflow) of any product we could find.
After TIG welding the inserts are sandblasted to remove and weld or mill scale and powder coated 50% gloss to give a factory type finish.
__________________
vs.
Old 03-04-2011, 04:03 PM   #4
jordanretro1223
Member Sales Rating: (21)
Member#: 143039
2007 STI
Satin White Pearl
And pics of this installed on an 06/07 WRX or STI?
jordanretro1223 is offline   Reply With Quote
Old 03-04-2011, 08:00 PM   #5
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
I've just got the pre-powder coating ones
__________________
vs.
Old 03-14-2011, 09:14 AM   #6
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Please PM for availability. We are close to selling out on some models.
__________________
vs.
Old 03-21-2011, 01:59 PM   #7
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Back in!
__________________
vs.
Old 03-25-2011, 05:26 PM   #8
Silvir05
Member Sales Rating: (5)
Member#: 196526
2005 STi
I'll buy one. 05 STi of course!
Silvir05 is offline   Reply With Quote
Old 03-26-2011, 12:38 PM   #9
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Got your PM, and replied
__________________
vs.
Old 03-27-2011, 04:46 PM   #10
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
02/03s back in stock
__________________
vs.
Old 03-30-2011, 11:28 AM   #11
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
We came across a neat clip that lets you mount this easily even if you've completely trimmed away the black section of the bumper...
Here's a pic of the clip in action.
Basically the lip that is left after (trimming the black section away) holds the clip in place. With a dremel and cutt-off wheel you plung into the lip, then the clips slides in. The mesh is very securely fastened and you can't see the clip from the front.
__________________
vs.
Old 04-05-2011, 08:35 AM   #12
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
We can include the clips and provide stainless button head screws too.
__________________
vs.
Old 04-05-2011, 09:43 AM   #13
biodude
Member Sales Rating: (16)
Member#: 271720
I like it, but think there is any way to get the vertical curvature to match the shape of the bugeye bumper a little closer?
biodude is offline   Reply With Quote
Old 04-05-2011, 10:49 AM   #14
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
I'm not sure I'm following you.
Here's a pic of one fitted to a bugeye (before powder coating).
__________________
vs.
Old 04-05-2011, 11:23 AM   #15
biodude
Member#: 271720
I figured I probably need to explain better.
anyway, on the right and left sides the grill appears to be fairly flat/straight up and down, as opposed to the curve of the bumper. I would like it better if there was a bit of an arc so it sits more flush with the bumper shape there. If the frame is made of flat stock I could do it pretty easy, but do you think that by adding that arc it would leave a bit of an odd gap at the top and bottom?
either way, I think I'll be getting one after I finish my build.
Old 04-05-2011, 11:42 AM   #16
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
You've got an eye for detail my friend. You are absolutely correct, the follow the front profile of the car but not in the vertical. Of the hundereds of people that I've talked to and shown on our shop car no one has mentioned it.
If we were stamping these we could do that, but they are rolled. Rolling in the ventical would make the horizontal pieces distort. Even after the mesh is welded in there I'm sure it would do odd things.
Here's a real world pic from a standing position, which is how these are really viewed.
__________________
vs.
Old 04-05-2011, 01:05 PM   #17
biodude
Member#: 271720
my wife says I that I'm just to damn anal..
I still like it, and will order soon
Old 04-10-2011, 08:47 AM   #18
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
^ I feel your pain on that one
__________________
vs.
Old 04-19-2011, 11:11 AM   #19
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Here are the clips we got from our local hardware store and some pics showing how the top edges is attached if you don't have your OEM bumper beam/foam anymore.
Then trim so it doesn't hang down in front of the grill.
And here's a pic installed (looking at it from the inside).
We used a dremel with a cut-off wheel. Hold the grill in place and put the clip against the backside to see where to cut the bumper. Plunge the cut-off wheel into the bumper enough to make a slot wide enough to accomodate the clip. Put clip in your new slot and bolt on the grill.
__________________
vs.
Old 04-25-2011, 08:42 AM   #20
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
All versions in stock!
__________________
vs.
Old 05-23-2011, 08:30 AM   #21
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Sold out of 02-03... but they are back in stock today!
__________________
vs.
Old 06-06-2011, 09:13 PM   #22
Illsti
Member Sales Rating: (15)
Member#: 131183
05 STI
CGM
pm price shipped for 05 sti
Illsti is offline   Reply With Quote
Old 06-07-2011, 02:47 PM   #23
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
PM sent.
__________________
vs.
Old 06-10-2011, 09:41 AM   #24
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Thanks for the orders guys!
__________________
vs.
Old 07-11-2011, 11:06 AM   #25
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
In stock again...
__________________
vs.
Gauging Interest : my TurboXS V2 TMIC for your FMIC GottaREX Tri-State Area Forum 0 09-22-2005 02:22 PM
Cwest v.2 grill (PSM) + cash for your STi Grill (PSM) SlowPoke00 Private 'For Sale' Classifieds 1 05-14-2005 01:59 PM
WTT My Liberal grill (Painted WRB) for your authentic Sti grill con40 Private 'Wanted' Classifieds 0 03-13-2005 08:04 PM
Space Age Protection for your car speedmonkee Accessories & Misc 15 11-09-2004 11:27 PM
