Old 07-11-2002, 10:17 PM   #1
clashman
Member#: 20115
2002 wrx wagon
Angry rough idle on wrx
Does anyone else experience a rough idle in a wrx? The dealer told me that it was because of the "radical" cam.
clashman is offline   Reply With Quote
Old 07-11-2002, 10:22 PM   #2
JenisonWRX
Member#: 6049
02 WRX & 99 RS
Default Re: rough idle on wrx
DUUUUUUDE! My cams are totally radical....
we should hang out...
W- T - F does that mean...
JenisonWRX is offline   Reply With Quote
Old 07-11-2002, 10:32 PM   #3
dandbest
Member#: 1885
2015 Evo
Yes. These cars do idle a bit rough. It has to do with the boxer design. Nothing you can do about it. No big deal.
Danny
dandbest is offline   Reply With Quote
Old 07-11-2002, 10:51 PM   #4
clashman
Member#: 20115
2002 wrx wagon
I had a 2.5rs (2000) with the boxer motor and it idles super smooth.
Old 07-11-2002, 11:05 PM   #5
jmott
Member#: 6713
2007 Prius
brown
and the 2.5rs does not have as big of a cam
jmott is offline   Reply With Quote
Old 07-12-2002, 01:46 AM   #6
WRX Joe
Member#: 14196
Blaze Yellow
It does run a little rough.
When I was working under the hood I accidently pulled a vacuum line out and it ran really rough.
You should check all your connections.
WRX Joe is offline   Reply With Quote
Old 07-12-2002, 02:55 AM   #7
wReXeRw
Member#: 19542
05 GSX-R 1000
02 WRX Gold
Default Re: Re: rough idle on wrx
HAHAHA
wReXeRw is offline   Reply With Quote
Old 07-12-2002, 03:44 AM   #8
TSINightFall
Member#: 17980
2007 STI Limited
Urban Grey
When i first got my WRX, I thought it idled extremely rough. Apparentley I've gotten used to it.
Used to seem worse with the AC on.
TSINightFall is offline   Reply With Quote
Old 07-12-2002, 03:56 AM   #9
TerenceT
Member#: 9510
04 FX35
Pearl White
it gets worst when you notice the hood scoop flatter when the a/c compressor kicks in
TerenceT is offline   Reply With Quote
Old 07-12-2002, 04:28 AM   #10
BROADWRX
Member#: 21286
02 wrx
white
try using a thinner turbo approved oil. 10w30 or 5w30? Depends where you live?
BROADWRX is offline   Reply With Quote
Old 07-12-2002, 08:55 AM   #11
clucania
Member#: 16002
07 Forester
XT Sport
clashman-
this happen to me.
check the vacuum lines... or have the dealer check them for you.
~Chris Lucania
clucania is offline   Reply With Quote
Old 07-13-2002, 03:24 PM   #12
WTypeRogerX
Member#: 20968
2005 WRX Sportwagon
World Rally Blue
Default Boxer Engine
I thought the boxer design is supposed to be more balanced than other designs.
I noticed the rough idle the second day I drove my WRX! I can feel it through the seats and it seems to reverbate through the entire chassis. I mentioned it to a friend that also owns a wagon, and we started his up, and it does the same thing. It happens even when the engine is warm. The sensation is like an occasional massive ***** passes through the exhaust and some shaking afterwards.
My Type-R manual mentions something like "because of design of the high performance engine, you may experience rough idle", but I've never experienced it in that car. I haven't read through my entire Impressa manual yet, but I haven't seen any mention of rough idle.
WTypeRogerX is offline   Reply With Quote
Old 07-13-2002, 03:31 PM   #13
IgotWRXed
Member#: 14868
2002 wrx
well it could also be that the ej20 shakes like hell inside the engine bay. and while the shaking could be a more radical cam, next time, start your car and open up your hood. thats why sti engine mounts have so much of an effect.
IgotWRXed is offline   Reply With Quote
Old 07-13-2002, 07:56 PM   #14
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Cams with a single profile can only be tuned for a specific rev range. On the WRX this is fairly high up. This is a GOOD THING for power, but it makes it idle a bit rougher.
Old muscle car guys used to get big lobes with radical profiles that would cause the car to practically die on idle, even with increased idle RPMs.
The Hondas get around this by having multiple cam profiles tuned to different RPM ranges. If you were to idle on the big lobe, the car would probably stall itself
The rough idle of the WRX is normal.
Concillian is offline   Reply With Quote
Rough idle on 04 Turbo motors (2.5L) TSB Peaty Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 145 03-29-2009 08:50 PM
Questions on Rough idle on 06 STI with the following mods... origonalp Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 04-07-2006 12:34 PM
low/rough idle on warm starts raginbull74 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 01-23-2006 07:23 PM
Rough Idle on 2.5 Short Motor my99maddog Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 01-12-2005 05:50 PM
Rough Idle on new car? Alfaneggio Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 05-06-2004 05:39 PM
