Old 02-14-2011, 11:54 AM   #1
hunter15
Member#: 151168
99 OBS
Default wrx swap into 99 obs..radiator help
so, i bought a GMS radiator in november 2009..im gone for six months, i get back and find out my "perfect for a swap" radiator isnt so perfect..it wont fit because the beautiful ac condensor is in the way. does anybody have a fix for this? i know i can take the a/c out.. but not sure i wana die from heat exhaustion while driving, so does anybody know of a radiator that WILL fit? i need one that can keep up with my set up. 18g turbo'd 2003 wrx, injectors, sti intercooler..etc
thank you!!
hunter15 is offline   Reply With Quote
Old 02-14-2011, 08:38 PM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
A WRX radiator (which is what you've got, I'm assuming), whether it be stock or aftermarket, should sit right where the stock radiator did. The condenser shouldn't be in the way at all. I'm not sure I understand how you're trying to install it - if you tried to mount the radiator where the condenser is, the radiator core support would get in the way.
Old 02-14-2011, 08:54 PM   #3
KONKILR
Member#: 3190
2004 Impreza TS and
the Suxass racing mobile!
A wrx radiator will fit right in, even an oversized aluminum one. I have on in my 94 with the stock fans. I had to trim the hoses a little to prevent rubbing on the upper hose. The original mounts for the condenser are undisturbed, however I dont have one. The stock one will bolt right in with no issues. I did use the wrx upper radiator mounts, but this should be of no concern for the condenser.
jake
KONKILR is offline   Reply With Quote
Old 02-15-2011, 05:57 PM   #4
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
1. This is why you don't buy GMS parts.
2. I'm using an N/A radiator, just a Griffin radiator for an RS, that I had in the car before I swapped. I had to trim the fan shrouds, but it fits.
XanRules is offline   Reply With Quote
02 wrx swap into a 99 GC. Tranny issue.. scubydrew414 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-04-2011 09:52 PM
Swap Wrx Motor Into 99 Impreza Scottylack Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-14-2008 06:55 PM
usdm 03 wrx swap into 00 rs, stock radiator/fans? AzNStiImpreza Subaru Conversions 1 07-29-2005 05:10 PM
02 Wrx Swap Into A 99 2.5 Rs What Cani Use What Cant I GODSON Subaru Conversions 10 10-12-2004 03:56 PM
WRX shifter assembly into 99 OBS? k2snow Transmission (AT/MT) & Driveline 1 11-09-2002 01:17 PM
