Old 02-14-2011, 06:25 PM   #1
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Default Anyone have experience with Engine Mounts?
I need to rebuild the engine mounts for my FF-1 (I know, its not an impreza, but the mounts are actually more simple than Impreza mounts) but I haven't had any good suggestions or know anyway or anyone who can do it.
I was originally going to use urethane for the mounts, but I was told its IMPOSSIBLE to adhere it to the metal for the mounts. You can see them in this photo:
So, If anyone has any suggestions for what to do, I could really use some help.
For reference, here are the original mounts:
#6 are the "engine" mounts, #7 is the main transmission mount.
Note: I'm also in a pickle with #3, since I either have to use the original transmission to use that mount, or use the transmission I built (with better gearing) with a CUSTOM rear transmission mount... Not sure what to do there either, as I also have to do a custom clutch for the modified transmission I built.
Old 02-15-2011, 10:29 PM   #2
TIGWERKS
Member#: 256615
I might be able to help you, I just made these- I'm also local
TIGWERKS is offline   Reply With Quote
Old 02-16-2011, 10:40 PM   #3
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
VERY NICE!
speedyHAM is offline   Reply With Quote
Old 02-21-2011, 06:44 PM   #4
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Those seem a bit too complicated and expensive, and not enough give for my application...
Old 03-01-2011, 06:38 PM   #5
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
I think I'm going to try some 3M super-sticky tape... Or is that a stupid idea?
Old 03-04-2011, 02:01 PM   #6
jordieb213
Member#: 169663
I don't like the idea of the super-sticky tape. The engine is creating a bit more torque than that tape can handle. I also understand you just want to keep the mounts in place, but you would be much better off with a mono-system rather than three pieces, ie top of mount, bushing, bottom of mount. Weld a piece up and have solid mounts. The vibrations would probably be similar to that of the mounts you are attempting to create anyway. One motor mount sees much more compressive force than the other, and the other mount sees much more tension than the other.
good luck!!
::EDIT::
I just read that you need something with more 'give for you application'...what is the purpose of this application anyway?
jordieb213 is offline   Reply With Quote
Old 03-05-2011, 03:32 AM   #7
teiva-boy
Member#: 22825
Could you pour your own? I think I recall you looking into that too?
teiva-boy is offline   Reply With Quote
Old 03-06-2011, 03:28 PM   #8
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Well I filled in a transmission mount once with Urethane. That won't work in this instance though.
I'm at a loss right now, and I'm concerned I shouldn't have tried to take the mounts apart in the first place...
Old 03-06-2011, 08:23 PM   #9
69subaru360
Member#: 159682
1995 WRX
2015 F150
Cut the stud off. Drill a hole through both plates and the urethane piece you cut in line with where the stud was. Use a long grade 8 bolt with a self locking nut to hold it together. That's how I set up the 72 GL racecar I did a few years ago. Except it was a solid aluminum block instead of your urethane. You can weld the bolt to the plate that bolts to the engine to make it easier to tighten.
Old 03-08-2011, 07:43 PM   #10
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Thats a good idea, I might do that.
Old 04-26-2011, 10:39 PM   #11
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Got my engine/transmission mounts sorted out finally. I ended up just putting bolts straight through as suggested in order to attach the rubber along with some sticky stuff to hold the bushings in place just enough. Its pretty sturdy, I stood on the motor and jumped up and down to make sure it was solid, LOL!
Old 04-27-2011, 07:13 PM   #12
alx8283
Member#: 225024
2002 wrx
i thought that proper surface prep as well as a proper primer would allow polyurethane to bond to metal, at least when you pour your own. ive done it with different poly-something or other coatings and adhesives, which of course do not see the same environment as mounts. am i wrong?
alx8283 is offline   Reply With Quote
Old 04-29-2011, 07:52 PM   #13
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Well if you pour your own, thats a different story. I've seen lots of references to that, and I even did it once on a transmission mount but that was just filling in the gaps.
Old 05-08-2011, 02:58 PM   #14
sackytar
Member#: 149262
03WR Rallycar/FXT/OB
PrimerGrey
Interesting.
sackytar is offline   Reply With Quote
Old 03-22-2012, 03:06 AM   #15
scandiflick
Member#: 297798
2011 WRX Stage 1
WR Blue
okay///
scandiflick is offline   Reply With Quote
Anyone have experience with Engine Logics? ekyub Texas Impreza Club Forum -- TXIC 1 12-30-2010 05:40 PM
OT: anyone have experience with an Acura C32A engine swap? mpaone South East Region Forum 4 09-24-2004 04:33 PM
Anyone have experiance with AudioBahn? Turk Car Audio, Video & Security 5 04-17-2001 07:32 AM
Anyone have experience with Hercules tires? kevinsUBARU Technical Forum Archive 1 09-15-2000 11:09 PM
Anyone have experience with Yokohama AO32R road race tires JDM5LugHatch Technical Forum Archive 10 06-13-2000 06:41 AM
