Welcome to the North American Subaru Impreza Owners Club Sunday March 1, 2015
Old 02-14-2011, 09:49 PM   #1
almostJDM
Member#: 163239
2013 STI
Default Strange chriping
Ok so as of last night, after I changed my exhaust mani gaskets I now hear a chriping sound when ever the car isn't idling, it's coming from the drivers side twords the rear of the engine compartment anybody have any ideas as to what it could be?
Thanks
almostJDM is offline   Reply With Quote
Old 02-14-2011, 10:19 PM   #2
GrundleJuice
Member#: 165749
this happens when you are stationary and the engine is above idle speed or only when the car is moving and the engine is above idle speed. what else did you touch/disconnect/adjust/move/etc when changing your exhaust gskts?
Old 02-14-2011, 10:41 PM   #3
almostJDM
Member#: 163239
2013 STI
both when stopped and moving, and the only other thing I touched was the rear sparkplug wire on the drivers side I took it off to show my friend it was all rubber that's it
Old 02-15-2011, 01:54 AM   #4
almostJDM
Member#: 163239
2013 STI
anyone else have any ideas as to what it could be? another thing to note is it chirps faster as the engine speed goes up, I am going to go outside to see if its only when I rev it quickly or even if i just lightly press the gas and slowly bring the revs up
Old 02-15-2011, 12:09 PM   #5
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
Check your belts.
XanRules is offline   Reply With Quote
Old 02-15-2011, 12:11 PM   #6
LouderPlease
Member#: 214427
Sounds like pulley bearings to me.
LouderPlease is offline   Reply With Quote
Old 02-15-2011, 01:03 PM   #7
almostJDM
Member#: 163239
2013 STI
yea it does to me too but it sounds like it's coming from the rear of the engine compartment
Old 02-15-2011, 03:34 PM   #8
renob123
Member#: 41986
'06 STI/'85 Brat
I had a cricket once, and it turned out to be the throwout bearing. I'd say it's a long shot in your case, but does the clutch being in vs. out change the chirp?
Jacob
renob123 is offline   Reply With Quote
Old 02-15-2011, 04:01 PM   #9
almostJDM
Member#: 163239
2013 STI
no it doesn't change Chirps even with clutch engaged, also if I gradually rev higher it doesn't chrip but if I mildly or quickly rev it, it will
Old 02-15-2011, 07:43 PM   #10
kero
Member#: 94299
2000 2.5 RS Sedan
SRP
Could it be a loose baffle in your muffler, I know that can cause chirps.
kero is offline   Reply With Quote
Old 02-15-2011, 07:56 PM   #11
almostJDM
Member#: 163239
2013 STI
it might be, but I have an after market exhaust and uel header, but it could be the shield over the second cat since I don't have the oem header hmmm I'll look all around under the car to see if anything is touching
Old 02-15-2011, 11:02 PM   #12
GEE-OTTO
Member#: 201277
2009 Legacy GT
You have a exhaust gasket leak. The chirp is what it sounds like if you worked on your header there is a chance there's a leak and it in conjunction with engine speed. Did you reuse your old gaskets? Did you knick a gasket ? Did you tighten them all down ? Your chirp has to be rotational or ehaust in nature.
GEE-OTTO is offline   Reply With Quote
Old 02-15-2011, 11:08 PM   #13
almostJDM
Member#: 163239
2013 STI
yea, I put new gaskets on the header because they were leaking before but I will double check that side in the morning
Old 02-15-2011, 11:56 PM   #14
acemyles2.5i
Member#: 151012
2007 impreza 2.5i
urban
could be your motor mounts, mine are already bad at only 44,000 miles, that my transmission mount and something called a torque mount lol never even heard of it
acemyles2.5i is offline   Reply With Quote
Old 02-16-2011, 10:49 AM   #15
GEE-OTTO
Member#: 201277
2009 Legacy GT
Sometimes new gaskets have flaws so that could be a issue and sometimes the nuts back off after after the initial tightening. I know on my car when ever i swap manifolds i drive for about 20 miles then check and tighten as needed usually one or two that are loose
Old 03-05-2011, 07:12 PM   #16
almostJDM
Member#: 163239
2013 STI
finally got new gaskets, they are multiple layered metal ones instead of the paper in-between 2 metal holy pieces
Old 03-06-2011, 02:41 AM   #17
almostJDM
Member#: 163239
2013 STI
yay fixed leak, now time to do other stuff like a timing belt job come next week
Strange Relay Chatter Type Sound, I hate it too...I have a strange sound post! sigma69pi Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 03-07-2008 12:31 AM
Strange boost problem with a strange dealer diagnosis. Help? Computergeek24 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 10-09-2006 01:34 PM
chriping-creaking sound from exhaust? jimtweet Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 07-28-2005 03:02 PM
Strange BOV behaviors and strange noises from turbo tr3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-09-2004 08:06 AM
Chriping Sound From Exhaust Chris04WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-01-2003 07:04 PM
