Welcome to the North American Subaru Impreza Owners Club Monday September 15, 2014
Old 02-15-2011, 03:50 PM   #26
WRX WARRIOR
Member#: 267633
It's A Zombie, Bro.
So low my rotors scrape..
ok well im off to my buddies house i left my tool box there lol. as soon as i get there ill boot my lap top back on and once i am there i ill clean the BCS then give you a status update.
WRX WARRIOR is offline   Reply With Quote
Old 02-15-2011, 10:14 PM   #27
WRX WARRIOR
Member#: 267633
It's A Zombie, Bro.
STATUS UPDATE! - Ok so i took off the BCS cleaned it and replaced some of the hose an dnow i am at 11 PSI
Old 02-15-2011, 10:59 PM   #28
Haelan
Member#: 151045
2013 Subaru STI
CBP
Getting closer--did you energize the BCS and verify you can blow through it? Have you done an ECU reset yet? Remove the positive battery terminal, pump the brakes a few times, and reconnect it.
Haelan is offline   Reply With Quote
Old 02-16-2011, 07:13 AM   #29
WRX WARRIOR
Member#: 267633
It's A Zombie, Bro.
Yes i j.used a speaker wire and put it on the batt. it was hard to blow thru it tho. gotten up to 10PSI. i am getting a boost leak test done later this week. when i told the shop i only had 7 psi they were like omg your crazy. so i think if i come back to them and say im at 10 that is a little bit better.
going to reset ecu once i get some coffee in me
thinking of going ahead and oprdering that grim speed EBC with the 600 rpm faster spool.
i am getting my open source tune next month so i think that will help.
Old 02-16-2011, 10:37 AM   #30
Haelan
Member#: 151045
2013 Subaru STI
CBP
Did you hear the BCS 'click' when applying power? It shouldn't have been hard to blow through when energized.
Old 02-16-2011, 11:14 AM   #31
WRX WARRIOR
Member#: 267633
It's A Zombie, Bro.
no it did click but it was not a continuous click. evert\y time i gave/ removed power it would click. is it posed to kep clicking while power is applied? and it was hard to blow thu it lol
Old 02-16-2011, 11:16 AM   #32
Haelan
Member#: 151045
2013 Subaru STI
CBP
That behavior is correct, but it should not have been hard to blow through. That might be where your problem is. The BCS bleeds pressure away from the actuator. If it's clogged or jammed shut then you'll always be at low boost.
Try swapping the BCS out with a known good one.
Old 04-08-2013, 06:45 PM   #33
WRXturboWagon02
Member#: 200338
Originally Posted by winterwagon View Post
I've had the same problem fr awhile now, anyone know if the restrictor pill is a generic part you can ask for at autozone or has to be from the dealer?
I just ordered the restrictor pill from the dealer. It only comes with the vacuum lines with the pill installed and i think the T connector comes with too for ~$20
WRXturboWagon02 is offline   Reply With Quote
Old 05-29-2013, 04:29 PM   #34
gwilliamson
Member#: 298637
WHITE
so was this fixed with the ebc?!
gwilliamson is offline   Reply With Quote
Old 05-29-2013, 09:38 PM   #35
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
This car hasn't run right in a long time.
Old 11-15-2013, 05:30 AM   #36
WRX WARRIOR
Member#: 267633
It's A Zombie, Bro.
I **** MBC on it works just fine now
Old 05-21-2014, 09:38 PM   #37
bdrbandit
Member#: 391511
2006 Wrx Wagon
Gray
hmm im having issues just like you were... changed the bcs with another tho and it didnt fix it. also my car is stuck in open loop and running rich but throwing no codes....
bdrbandit is offline   Reply With Quote
Old 05-22-2014, 12:23 AM   #38
Scoobiesdoobies
Member#: 321546
2006 Wrx Limited
Thread is nearly a year old. Wait for some replies or search why your cars stuck in open loop. Bumping year old threads wont get help any faster.
Scoobiesdoobies is offline   Reply With Quote
Old 07-04-2014, 07:57 PM   #39
aspenwhite05
Member#: 395384
2005 STI
white
Default damn you subaru
Ive done everything that everyone has suggested on this thread, including new MAF censor. If i ecu reset, i hit target boost, its only when i shift and do multiple gear pulls that its drops itself to 9 psi. Im positive its not waste gate or turbo failure since i hit target boost when the MAF is unplugged or if i disconnect the hose to the bcs.
I activate the bcs manually and it opens fine every time. cleaned and blow through tested......... reset ecu and it will hit target boost if i stay in one gear and move to neutral, but if i do the multiple gear pulls....... it resorts to 9 psi.
ive been working on this for weeks now and im frustrated.
any ideas?
ive also heard that if your exhaust isnt mounted firmly and it taps any portion of the engine or drivetrain, it will cause the knock sensor and ecu to run the car in a "safe mode" which wont throw a CEL. Any thoughts guys? i know this thread is a year old but i dont wanna start a new one and gum up the main page with stuff thats already being covered.
aspenwhite05 is offline   Reply With Quote
Old 07-05-2014, 09:23 AM   #40
AlexWRXbruh
Member#: 373710
2002 Subaru WRX
Porsche White
Ur ebcs sounds like itneeds a good cleaning...either that or its toast
AlexWRXbruh is offline   Reply With Quote
Old 07-05-2014, 04:04 PM   #41
aspenwhite05
Member#: 395384
2005 STI
white
i cleaned the absolute piss out of it..... i can hear it click and open on both hard wire 12v and ecu 12v. checked the connection for power and it has power....... i can blow through it with ease and there isn't any more residue draining when i clean.
I ordered a hks evc5 electronic boost controller. will that eliminate the oem bcs or should i order a new oem one?
Old 07-05-2014, 08:20 PM   #42
wrrench
Member#: 394860
out of curiosity what fuel do you run? good fuel, clean injectors, fresh plugs, etc all contribute to good readings to the ecu .. resetting ecu, hitting target boost once and then limited to 9psi sounds like the ecu is seeing knock or numbers it doesn't like and maybe pulling timing or mix etc
I don't know a lot about ecu **** it's just an idea
wrrench is offline   Reply With Quote
Old 07-06-2014, 09:51 AM   #43
AlexWRXbruh
Member#: 373710
2002 Subaru WRX
Porsche White
If ur on the iem bcs it's likely dead..could also be a problem with the lines going from the bcs to the turbo. No, that aftermarket bcs will make ur situation worse unless you tune for it...its a 3 port, oem is 2..regardless, ur changing the signals that the ecu would have to process..not by much, but enough to give you problems
Old 07-11-2014, 10:52 PM   #44
aspenwhite05
Member#: 395384
2005 STI
white
91 octane no ethanol.. highest grade we have here... have done the fuel system cleaning... plugs have under 600 miles on them.
it will hit target boost multiple times..... its only when i do multiple gear pulls.
Only 5 psi as full boost??? DAN4507 Factory 2.5L Turbo Powertrain 8 09-19-2007 12:04 AM
only 7 psi and i have the little brass restrictor TmR197 Factory 2.0L Turbo Powertrain 35 02-12-2006 06:39 AM
ONLY 7 psi AGAIN but why?????? DOUBLE U ARE X Factory 2.0L Turbo Powertrain 59 01-06-2005 11:27 PM
Only 7 PSI boost with STi Tanman Factory 2.5L Turbo Powertrain 18 12-03-2004 11:26 AM
Should factory boost be only 12 psi in 3rd and 4th gears? ImportVenom Factory 2.0L Turbo Powertrain 1 08-02-2003 12:54 PM
