Old 07-12-2002, 12:41 AM   #1
flat4NA
Member#: 16173
1999 Legacy
Default How do I adjust the handbrake
like what it say on the subject. Let me know peeps.
Peace
Anthony
flat4NA is offline   Reply With Quote
Old 07-12-2002, 01:07 AM   #2
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Default well
you got to remove the console cover in the car. You will see the parking brake cables coming through the floor. There is an adjustment shaft with two nuts on it. break them apart using box-end wrneches. Adjust the adjusting nut (it will be obvious which one this is) until you get an eight or nine click fully engaged brake. Retighten the secind nut down on the first. If you cant achieve a fully engaged brake after nine clicks at full adjustment, your parking brake cables may be stretched and need replacement.
HTH
subysouth
subysouth is offline   Reply With Quote
Old 07-12-2002, 03:09 AM   #3
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
Alternatively, if you are at 8-9 clicks fully lifted, and your cables aren't stretched, then your e-brake shoes could be shot (i.e, driving with the e-brake in the "on" position will cause premature wear of your shoes and hot spots on your e-brake drum which leads to glazing. That leads to smooth contact surfaces mating and that's not what you want in your e-brake system.
Br, Dale
Subietonic is offline   Reply With Quote
How do you adjust the light on the DIY projector bugeye? qualityracer Interior & Exterior Modification 2 10-14-2008 02:29 AM
How do I adjust the colors of the forum? Braga_Dub Newbies & FAQs 7 08-09-2006 07:37 PM
how do you adjust the max height of the window? halogen Interior & Exterior Modification 3 03-15-2004 10:49 PM
how do you remove the handbrake? wrx182 Interior & Exterior Modification 2 01-21-2002 05:16 PM
('93-'01) How do you adjust the hand brake? 2yLiTe Impreza Forum 3 06-11-2001 06:50 AM
