Old 02-15-2011, 11:41 PM   #1
zephyr2oo5
Member#: 273251
Default Hard start after fuel fill up
So I've Been experiencing an issue after filling up each time when I go to leave the pump and the car won't fire. It only doesn't the first time I go to start it and on the second attempt it starts up every time. I've got 800cc injectors and a walbro 255 any ideas? Thanks
zephyr2oo5 is offline   Reply With Quote
Old 02-16-2011, 01:17 AM   #2
pnuts1986
Member#: 269594
02 wrx stage 2
i think fuel vapors are going into your intake during fill up. Making it very rich, do you have a air/fuel gauge?
i bet your evaporative purge solenoid is stuck open some how.....is ur check engine light on?
pnuts1986 is offline   Reply With Quote
Old 02-18-2011, 09:52 AM   #3
BKscooby
Member#: 163601
evap isn't the culprit of this issue. Most likely a clogged fuel filter, or a bad fuel pump. What year is the car, miles, mods?
BKscooby is offline   Reply With Quote
Old 02-19-2011, 12:56 AM   #4
pnuts1986
Member#: 269594
02 wrx stage 2
evap isnt the cluprit??? little do you know.
u think a fuel filter can make a car not start? even if the filter was clogged fuel will still flow, if the pump was bad it would be acting up on WOT not during starting.
Well maybe the check valve might be bad, but he said only after filling up.
so lets not just jump on the filter idea cuz thats not the issue.
Old 02-25-2011, 06:24 PM   #5
zephyr2oo5
Member#: 273251
any ideas?
Old 02-26-2011, 01:33 PM   #6
02_blue_u_away
Member#: 99375
2002 Subaru WRX
World Rally Blue
Check all of your vacuum lines and especially around the evap lines near the manifold. mines did this and found bad connection, more so, a bad line. Hard start would happen to me right after i fuel up. but it'll be find until the next fill up. hope this helps.
02_blue_u_away is offline   Reply With Quote
Old 02-26-2011, 05:45 PM   #7
maloz129
Member#: 242227
04 impreza wrx
san ramo red
run some injector cleaner thru it
maloz129 is offline   Reply With Quote
2000RS--Odd Starts directly after fuel fill-up snoopyone8 Normally Aspirated Powertrain 17 06-08-2015 09:34 PM
Hard Starting after fueling up zedman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 12-09-2010 02:00 PM
After I filled up some gas, the car won't start zac5 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 11-17-2009 06:19 PM
won't start after a fill up John Kerr Normally Aspirated Powertrain 5 07-15-2008 01:12 AM
Car wont start after tank fill up!! SSsleeper96 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 12-22-2005 10:05 AM
