Welcome to the North American Subaru Impreza Owners Club Wednesday May 6, 2015
Old 03-04-2011, 12:27 PM   #276
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Jeff,
With the medium wastegate actuator and max preload you where only able to acheive 20psi with the electronic boost control? What are you able to acheive with the boost reference plumbed directly to the wastegate?
What I understood from the EFR document is the 20 psi max that you can apply to the wastegate is the max boost reference not the max pressure the turbo should be able to run with said actuator. If your boost target is 30psi and your wastegate duty cycle is 50% the effective pressure sensed at the wastegate should be about 15psi which is below the 20psi max right? Maybe the EBCS is leaking. Also do you know what the PWM frequency is that you are sending to the EBCS?
Old 03-04-2011, 08:15 PM   #277
PERRINJeff
NASIOC Manufacturer
Member#: 74110
I little present from Geoff and Raffi!
This thing is huge!!
PERRINJeff is offline   Reply With Quote
Old 03-04-2011, 08:50 PM   #278
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
^What's that? Ts?
TDagen is offline   Reply With Quote
Old 03-04-2011, 08:54 PM   #279
azn2nr
Member#: 35276
2006 2.5i clone
438/420 whp
8374 woooootttttt
please make me an uppipe and down pipe PLEASE!!!!
azn2nr is offline   Reply With Quote
Old 03-05-2011, 02:52 AM   #280
jkopinga
Member#: 220799
2006 Impreza WRX
WRC Blue
^^^ If you click your right mouse button on the picture and click "Save picture as" it says 9180.......
Jasper.
jkopinga is offline   Reply With Quote
Old 03-05-2011, 09:47 AM   #281
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
turbo looks awsome, it still concerns me that you cant run over 20psi, most anyone replacing a turbo with the size of a 30 or 35r one your gunna run over 20psi makes me happy im running TS EWG
seanathanq83 is offline   Reply With Quote
Old 03-05-2011, 12:48 PM   #282
PERRINJeff
NASIOC Manufacturer
Member#: 74110
Fedex should be here any moment with my heavy WG actuator! Car is on dyno patiently waiting.....
Old 03-05-2011, 12:51 PM   #283
monkiboy
Member#: 202958
2008 wrx
stellar, this weekend is going to be a good one...
monkiboy is offline   Reply With Quote
Old 03-05-2011, 12:53 PM   #284
jkopinga
Member#: 220799
2006 Impreza WRX
WRC Blue
Jeff.....I've already turned purple holding my breath
Looking forward to the data and dyno comparisons. Good luck to you during the tests!
Cheers,
Jasper.
Old 03-05-2011, 12:54 PM   #285
juanmedina
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
Sweetness, gtx3076 vs EFR 7670 and gtx35 vs EFR 8374 comparisons FTW
Old 03-05-2011, 01:47 PM   #286
Boosted WRX STi
Member#: 116731
2003 KB Cobra
Subaru Stars
Cannot wait for the results, this will decide which turbo I'm going to upgrade to! Good luck with the tuning Jeff, you know you always make us proud!
Boosted WRX STi is offline   Reply With Quote
Old 03-05-2011, 02:26 PM   #287
blakjak00
Member#: 225046
2000 2.5RS
Blue Ridge Pearl
*hits the imaginary 'Like' button*
blakjak00 is offline   Reply With Quote
Old 03-05-2011, 03:13 PM   #288
Dutch Devotion
Member#: 145985
taps with fingers on table
tromtromtrom
Dutch Devotion is offline   Reply With Quote
Old 03-05-2011, 04:35 PM   #289
MrLith
Member#: 274895
Awesome, good luck! This will be one of those definitive things that people will be referring to for ages, so nice work
MrLith is offline   Reply With Quote
Old 03-05-2011, 05:00 PM   #290
ASU
Member#: 164551
2006 Brotastic STi
Land of beer and laws
Waiting on the results, going with either the new GTX3076r .63 or the EFR7670 based on these results. Will give up a few WHP for a faster spooling turbo IMO that equals more fun.
ASU is offline   Reply With Quote
Old 03-05-2011, 05:52 PM   #291
LittleBlueGT
Member#: 96204
2013 STI GR
From the evidence I have seen the .63 on a GTX3076 may not be the best.
Until the GTX came out, my all time fav turbo was Jeff Sponagle's 08 STI w/ .63ar GT3076. He had logs up in all the gears.
I kinda think that the GTX3076 is too big for the smaller turbine housing. I also think that a GTX3071 might do very very well w/ the .63 ar housing. It does flow about the same as the old 3076, so maybe it would have a slight boost threshold advantage, and possible better spool and response (when above boost threshold) due to smaller lighter comp wheel.
I am also starting to think that the 7064 may be a better comparison to the the GTX3071 .63, or old 3076 .63, then the 7670.
I was always using MB using conservative numbers for WHP, and staying well within the efficiency islands. I did spedn some time looking at the old GT charts, and demand curves for our 2.5 engines, and found that Jeff is quite right, we do go past the efficiency islands on the GT turbos as well.
So the 400ish whp club might be best served by the GTX3071 .63 or the EFR7064.
I guess we will know fairly soon.
LittleBlueGT is offline   Reply With Quote
Old 03-05-2011, 06:39 PM   #292
PERRINJeff
NASIOC Manufacturer
Member#: 74110
More in a few....
Old 03-05-2011, 06:43 PM   #293
ozzimark
Member#: 273634
Looks like it's spooling about the same as the GT/GTX3076
What is the red line from?
ozzimark is offline   Reply With Quote
Old 03-05-2011, 06:44 PM   #294
monkiboy
Member#: 202958
2008 wrx
thank you, now more, haha.
Old 03-05-2011, 06:44 PM   #295
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
I take it the blue line is boost?
aboothman is offline   Reply With Quote
Old 03-05-2011, 06:51 PM   #296
PERRINJeff
NASIOC Manufacturer
Member#: 74110
Ok, so the story goes like this.
Full-Race really stepped up and hooked me up by getting me the high pressure WG canister, and at the same time let me barrow that monster 9180, which was awesome! Well BW drop shipped the wrong WG canister and was shipping me the correct one for today. Well Raffi and i are guessing they forgot to check off Saturday delivery on their machine. So no high pressure WG canister was installed.
So since the car was ready to dyno, i cranked up the preload to 10mm on the WG and did some runs. First pull with 0% WGDC was a whopping 10psi! That didn't seem right, but whatever, i set my target to 1.2 bar and continued. I had to run about 45% climbing to 70% to hit a perfect 1.2 bar of boost. Runs were looking really good and power seemed pretty good also. I loaded the GT3076R w/.82 and 1.2 bar of boost and started to compare.
Before i go further, this is with the Medium WG canister, not the correct high pressure one, which should be better.
The blue line is the GT3076R w.82, the Red line is the EFR7670.
Comparing HP, you can see the EFR start to kick butt at 6000 over the GT.
At this point, this turbo is comparing closer to the GT35R not the GT30R. I will put up some GT35 comparos in a few.
Old 03-05-2011, 06:51 PM   #297
PERRINJeff
NASIOC Manufacturer
Member#: 74110
I am working with my iphone so pics are not super awesome but give me a few more minutes.
Old 03-05-2011, 06:56 PM   #298
PERRINJeff
NASIOC Manufacturer
Member#: 74110
Gt3582 stuff
Old 03-05-2011, 07:01 PM   #299
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
make sure some one look at WG arm to make sure its not opening before it should, awsome man waiting for more data
Bariga is offline   Reply With Quote
Old 03-05-2011, 07:04 PM   #300
PERRINJeff
NASIOC Manufacturer
Member#: 74110
Ok, here is the GTX3582R with .82 running 1.2 bar of boost against the EFR7670. It for sure responds better than the GT3582R.
Here is the HP graphs compared now this is a GTX3582R not a GT3582R. As we know the GTX compressor map is way more efficient than this one. The GT3582R is probably HP wise closer to the EFR.
The EFR runs actually have slightly less timing (maybe 1.5 degrees) and if i push it, i know i can make more HP at the same boost level as the GTX.
The crappy thing is, i can't run more than 18psi of boost at redline with this actuator.
I did a few runs trying to run 1.5bar and it does it right up until 4500 then is just drops like a rock. So i have comparisons, but they are not good. Poop happens and it sucks it happened today!
The 9180 i have sitting here would have the same boost control issues and i am going to wait to throw that on until i get the correct actuator.
The boost i am seeing, with no WGDC really makes me wonder...... Why so low??
Borg Warner Registry, post your BW setup & #'s here. UpSideDownDesi Proven Power Bragging 2923 12-07-2014 11:20 PM
Borg Warner S256 and S362 Turbos AXA Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 41 11-12-2014 01:18 PM
PERRIN's 2011 STI Sedan is HERE!! PERRIN_Jarid Perrin Performance 62 10-01-2011 10:22 PM
Borg Warner Turbos. Who is running them? DemiSlayer Built Motor Discussion 48 03-22-2010 11:50 PM
small borg warner turbo vid. mattjk Off-Topic 13 07-05-2006 04:25 PM
