Welcome to the North American Subaru Impreza Owners Club Saturday March 28, 2015
Old 02-16-2011, 08:03 PM   #1
Coop1103
Member#: 162063
2007 STI FR TS 8374
UGM
Default PLEASE Help...AEM Oil Pressure Gauge Install
Guys im having a hell of a time figuring out this oil pressure gauge install. I removed the gally plug under the TMIC and the sending unit AEM sends does not fit....So...I picked up the OEM subaru galley plug that tapers to the 1/8....no luck. Seems like it is standard to metic and the threading is not coming together. How are you guys doing this?? Please help..pics below.
Coop1103 is offline   Reply With Quote
Old 02-16-2011, 08:12 PM   #2
xluben
Member#: 261612
2002 WRX Sedan
10.9s @ 128mph
The AEM Oil Pressure sender has 1/8NPT threading. The OEM Subaru galley plug has 1/8PT (aka BSPT). Basically the AEM part has US threading, and the galley plug has metric threading. You will need an adapter like this:
Amazon.com: Auto Meter 2269 1/8" NPT to 1/8" BSPT Oil Pressure Metric Adapter: AutomotiveAmazon.com: Auto Meter 2269 1/8" NPT to 1/8" BSPT Oil Pressure Metric Adapter: Automotive
xluben is offline   Reply With Quote
Old 02-16-2011, 08:15 PM   #3
Coop1103
Member#: 162063
2007 STI FR TS 8374
UGM
Can I simply change the threading of it?? Just pick up the right tap?
Old 02-16-2011, 08:15 PM   #4
Kentrik
Member#: 125937
03 WRX I do not
like your tweed, chap.
This is probably also better posted in the technical area than the general area.
Just a friendly FYI.
Kentrik is offline   Reply With Quote
Old 02-16-2011, 08:34 PM   #5
xluben
Member#: 261612
2002 WRX Sedan
10.9s @ 128mph
Can't change the threading of the sender. They're too close in size.
Your other option would be to drill out and tap the galley plug. You might have to get one that's not already drilled out in order to have enough metal to work with.
Old 02-16-2011, 10:13 PM   #6
Coop1103
Member#: 162063
2007 STI FR TS 8374
UGM
Guess Im purchasing that link you sent me to? That will work? I wont need anything else? And can I return/resell the oem adaptor I picked up?
Old 02-17-2011, 07:21 AM   #7
xluben
Member#: 261612
2002 WRX Sedan
10.9s @ 128mph
The OEM plug at that hole doesn't have any threading, does it? You will still need the galley plug you bought with the 1/8PT hole. You will install that, then install the adapter, then install the sender. Hopefully there is enough room. If it looks like it's going to be a tight fit, you might want to look into something like this:
http://www.daddysscp.com/product_p/opnpt-npt.htm
That one sounds like you will still need the galley plug you bought, and the adapter I linked before. The extended hose would just move the sender out from under the TMIC. Here is another option:
http://prosportgauges.com/remote-oil...ation-kit.aspx
That one comes with the OEM galley plug, so you could return the one you have. I also believe it would have the right threading to work with the galley plug, so you wouldn't need to buy the adapter either.
Old 02-17-2011, 10:16 AM   #8
Coop1103
Member#: 162063
2007 STI FR TS 8374
UGM
Thanks for your help. I run a fmic so there should be no clearance issues with both of those in the location correct. I just ordered the one from amazon.
AEM Oil pressure gauge brand new in box- few autometer gauges - Pioneer tv (pics 02Wagon11 Interior/Dressup/Audio & Security 8 06-23-2010 01:10 AM
AEM oil pressure gauge... lennybootzz Electrical & Lighting 0 05-17-2009 11:21 PM
Oil Pressure Gauge Install Help Blurvision Normally Aspirated Powertrain 4 06-03-2004 10:40 PM
Need help - oil pressure gauge install Faulk Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-11-2004 02:30 PM
need oil pressure gauge install help Ken 02 Electrical & Lighting 4 10-21-2003 08:37 PM
