Old 02-16-2011, 11:30 PM   #1
Ride1226
Member#: 201483
2010 WRX
WRBM
Default 08+ HKS ssqv and Process West TMIC
So, after installing everything last night I ran into an issue. The PW tmic is wider, therefor moving the bpv over. Thus, moving it further away from the recirc line. Now, with the way HKS thought so smartly about routing the 08+ SSQV, its like 6 inches even further to the right away from the recirc line. Nowhere near reaching. Is there a flange I can replace the goofy setup that it came with to just bolt it right to the intercooler, that way the recirc line can hook up, or am I SOL and have to just go ahead and order a FORGE and cut my losses? Anyone have an idea? I have to get rid of the stocker, because on my way home from getting tuned today I managed to hear it start to leak and chatter when I put my foot on the floor in forth or fifth to build full boost.
Ride1226 is offline   Reply With Quote
Old 02-17-2011, 12:49 AM   #2
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
yeah, stockers kinda suck on ours...I'm interested in finding out as well, most likely I'll be doing something similar soon
drewvdw is offline   Reply With Quote
Old 02-17-2011, 01:44 PM   #3
Ride1226
Member#: 201483
2010 WRX
WRBM
Yea Id like to get this sorted out because Im not really too fond of having a leaky BPV right now haha. Its literally right on the edge. Sometimes if I put my foot down it will hold the boost, sometimes at the same boost level and the same putting my foot down itll start to leak and chatter.
Old 02-17-2011, 01:57 PM   #4
Cards2323
Member#: 142868
2014 BRZ LIMITED
Satin White Pearl
Why not set it up similar to how a FMIC flange would be. Get the flange to bolt on the TMIC, then use a silicone hose to connect to teh HKS, that would give you enough play to move the unit over.
Cards2323 is offline   Reply With Quote
Old 02-17-2011, 02:07 PM   #5
bonky
Member#: 220806
2004 Honda
S2k
You can also try to find a longer hose. Perhaps something from home depot or a radiator hose.
bonky is offline   Reply With Quote
Old 02-17-2011, 03:21 PM   #6
ericsson
Member#: 208672
2013 WRX STI Limited
Obsidian Black
can you post a pic of your engine? i'd like to see it
ericsson is offline   Reply With Quote
Old 02-17-2011, 03:37 PM   #7
Ride1226
Member#: 201483
2010 WRX
WRBM
Ill get a pic when I get back home. That would probably help big time. Haha.
Old 02-18-2011, 12:09 PM   #8
Ride1226
Member#: 201483
2010 WRX
WRBM
Due to work I have been having a hard time getting under my hood to get a pic, but I did find this...
http://www.ultimate-racing.com/xcart...1&bestseller=Y
When I looked up the ssqv a couple times for my year, it shows it with that type of flange on it from the start. Why did mine come with this goofy flange, to rubber hose, to valve setup?
Old 02-18-2011, 12:14 PM   #9
rockle3
Member#: 167573
09 spec B
I don't get why you cant just find a longer hose?
rockle3 is offline   Reply With Quote
Old 02-18-2011, 12:52 PM   #10
Ride1226
Member#: 201483
2010 WRX
WRBM
Just seems rediculous to me to put a long hose between my intercooler and valve, and then have to make the recirc hose longer to reach it all when It should Just bolt right to the intercooler, plug together, and be done.
Old 02-18-2011, 02:24 PM   #11
bonky
Member#: 220806
2004 Honda
S2k
then spend more money and get another bov.
Old 02-18-2011, 07:19 PM   #12
Ride1226
Member#: 201483
2010 WRX
WRBM
I bought this one for a reason. Its a pull type which I wanted. The money is already spent I just didn't get what was pictured and I'm trying to find the correct flange. Thanks for Your help though.
FS : Process West TMIC Duct for 08+ system60 Engine/Power/Exhaust 12 10-14-2012 03:20 PM
Process West TMIC and Air Splitter for '06 STi scoobienoobienoo Car Part Reviews 20 02-03-2009 02:04 PM
Process West TMIC and APS TMIC comparison maramaralula Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 06-01-2007 03:30 PM
