Old 02-16-2011, 11:56 PM   #1
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
Default sohc valve sizes
i have an 07 2.5i. and i bent a few valves from a bad timing belt tensioner bolt...
anyways, i was wonderin what the valves specs are, because i figured while i am replacing them i might as well put in some aftermarket valves... i was looking at the supertech +1mm valves...
but i cant figure out what the sizes are for my stock valves to see if they will fit or not.
olsen726 is offline   Reply With Quote
Old 02-18-2011, 01:19 AM   #2
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
to answer my own question incase someone else is looking for aftermarket valves sometime. i found them... supertech makes them. it is part number
SIVN-1015 for the +1mm intake
SEVN-1015 for the +1mm exhaust
SIVN-1016 for the standard size intake
SEVN-1016 for the standard size exhaust
Old 02-18-2011, 01:40 AM   #3
Back Road Runner
Member#: 60082
2004 Forester STI
Unless you intend to run race cams in the car, P&Ped heads, full exhaust, and possibly a modified intake manifold, there's little point to the plus sized valves. These heads flow really well and very appropriately for the stock configuration, and there is no purpose to oversize the valves simply to oversize the valves.
Old 02-18-2011, 07:54 AM   #4
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
Doesn't one need to oversize the seats also? If so then it would be silly to not mildly p&p.
Old 02-18-2011, 09:26 AM   #5
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
yes. i am getting the seats cut... also i already have bigger cams, dual valvesprings/ titanium retainers.
and a rotated turbo setup...
here is a link to my build.
http://forums.nasioc.com/forums/show....php?t=1753564
Old 02-18-2011, 07:21 PM   #6
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
So why are you sweating the valve size details? Whoever is doing the angle job and cutting the seats should be able to replace the guides also. Length shouldn't be an issue if you get valves for that engine.
Old 02-18-2011, 07:34 PM   #7
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
i was wondering what the specs were because i was having a hard time finding the ones for the sohc heads. so i was going to see if the specs were the same as the wrx or sti valves, and just order a set of those.
but good ole supertech saved the day, and responded to my email almost instantly with part numbers.
Old 02-19-2011, 03:56 AM   #8
Back Road Runner
Member#: 60082
2004 Forester STI
^^^useful to tell us this stuff.
Old 02-19-2011, 12:39 PM   #9
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
it was completely irrelevant to my original question. but then people started coming in telling me how it would be pointless to put over sized valves on a stock 2.5i lol.
Old 02-20-2011, 10:46 PM   #10
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
What a silly assumption to make. It's not like you came to the normally aspirated forum, asking questions about the valves in a normally aspirated engine.
Oh wai...
BAN SUVS is offline   Reply With Quote
Old 02-20-2011, 11:04 PM   #11
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
last time i checked this wasn't the normally aspirated forum for only stock subarus... i came here because my heads are from a naturally aspirated car...and the question i asked had nothing to do with weather or not my car has a turbo.
SOHC valve springs 970subaru Normally Aspirated Powertrain 3 06-13-2006 09:44 AM
stock 99rs sohc valve springs/retainers/probably all the keepers White 2.5rs Private 'For Sale' Classifieds 7 02-28-2006 05:44 PM
EJ25 SOHC Valve Springs... tgusyn_2 Private 'Wanted' Classifieds 0 07-23-2005 02:14 AM
Self-made SOHC valve spring compressor White 2.5rs Private 'For Sale' Classifieds 5 06-29-2004 02:56 PM
Interest in SOHC valve springs? 8Complex Normally Aspirated with bolt-on Forced Induction Powertrain 24 06-19-2002 06:40 PM
