Old 02-17-2011, 12:29 AM   #1
kewlboxer2
Member#: 161322
06 2.5i
Regal Blue
Default Oil smoke on startup
Just noticed this today. I know for 100% sure my HG is on the way out on my 06 2.5i. Almost 107k on the ODO. I wanted to do HG in spring time along with timing belt, tensioners, regrind cams and oil pickup.
BUT! now the smoking on startup has me wondering. Could it be back valve guides? or worn rings from 107k miles of beatings. I used it very hard for 3 years. Working out of my car. Starting it 7-10 times a day and 100+ miles a day.
Any help would be appreciated!
Mark
kewlboxer2 is offline   Reply With Quote
Old 02-17-2011, 09:52 AM   #2
bmobs06
Member#: 252783
i had some issues a month ago and thought it was the hg but ended up being the camshaft and crankshaft seals.
bmobs06 is offline   Reply With Quote
Old 02-17-2011, 12:17 PM   #3
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
Seems like it would make more sense for the smoke to occur while the engine is running (oil under pressure) than just on start up if it was HG.
Old 02-17-2011, 12:31 PM   #4
kewlboxer2
Member#: 161322
06 2.5i
Regal Blue
Well my HG has an external leak. But puff of oil smoke on start up has me concerned.
Old 02-18-2011, 12:47 PM   #5
kewlboxer2
Member#: 161322
06 2.5i
Regal Blue
bump?
03 bugeye blue smoke on startup, oil on hot side of turbo 03blackwrx02yellowsv Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 33 10-19-2010 04:27 PM
Smoke on startup question SeaRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 07-09-2005 05:48 AM
Puffs of white smoke on startup David03WRX Service & Maintenance 4 04-25-2003 03:11 AM
Puffs of white smoke on startup David03WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-20-2003 01:46 PM
('93-'01) white puff of smoke on startup? MrMojo Impreza Forum 1 09-26-2001 12:32 PM
