Old 02-17-2011, 09:06 PM   #1
maruksai
Member#: 233276
2009 2.5i Hatch
Default 2.0 Oil Filter on 2.5?
I ended up getting a few Purolator PL14660 from advanced auto parts because they only had 3 PL14612 filters in stock. They had a good sale, so I wanted to stock up.
Is it ok to use the PL14460 on the 2.5 motor? I have read several threads about this particular filter, but I did not come across anyone stating no to use it on 2.5 engines. Apparently... the PL14460 doesn't have a ADBV and the PL14612 does.
I have a PL14660 on my motor now and all seems well. Fitment wasn't an issue and there are no exhaust clearance issues. It seems like the PL14460 could be better since the filter is larger which in turn means larger filter media.
Is it safe to use the PL14460 that's meant for 2.0 and 2.2 motors on my 2.5?
maruksai is offline   Reply With Quote
Old 02-17-2011, 11:26 PM   #2
GrundleJuice
Member#: 165749
To add to the oil filter questioning... If the stated filet above is not suitable for the 2.5,.are there any other larger capacity filter for the 2.5?
Old 02-17-2011, 11:59 PM   #3
kakarotoni
Member#: 156240
02 WRX
06 Impreza
It will fit, just different part numbers. I wouldnt imagine a huge difference if your not taking your car to the track everyday for 3000 miles. Im sure someone else can chime in.
kakarotoni is offline   Reply With Quote
Old 02-18-2011, 07:28 PM   #4
GrundleJuice
Member#: 165749
My push mower has a larger oil filter than my car and that is stupid. Its not because the filter on the mower is bigger than it needs to be, either. The more capacity the more dirt it can hold without changing the pressure diff. across the filter and the longer it will flow in the case of something catastrophic failing. There is only good to be had from a larger filter.
Old 02-18-2011, 09:24 PM   #5
Wrencher86
Member#: 250463
2010 Impreza 2.5i
Go back to advanced auto and ask for a detailed list of specs for each filter. They should be able to print that out for you and you can compare side by side. It will tell you things like max flow, bypass pressure, and burst pressure (fun!).
I'm assuming ADBV is a bypass valve? Somebody who has more experience with these motors internal workings might be able to tell you if that is going to be an issue.
Wrencher86 is offline   Reply With Quote
Old 02-21-2011, 09:08 AM   #6
motohippy
Member#: 225882
2000 OBS
'88 BMW K75S
ADBV= Anti Drain-Back Valve. Totally separate from the bypass valve. IF you had a car where the top of the filter (threaded side) was pointing down or at least horizontal, this would keep the filter from draining whenever the engine was stopped---then needing to be refilled before the engine could get oil pressure---really bad on startup. Given that the filter is hanging down on our motors and can't drain (unless you invert the car, at which point I think you might have other more pressing issues), I don't think it's something you need to worry about.
motohippy is offline   Reply With Quote
2.5 liter oil pan on 2.0 liter, oil pickup cabe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 09-07-2008 11:31 AM
JDM 2.0 TMIC vs. USDM 2.5 TMIC jmeltzer4 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-08-2008 01:22 PM
2.0 valve covers on 2.5 heads? upjeeper Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 10-02-2007 07:33 PM
2.5L Oil Pan on 2.0L WRX theostubbs Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-20-2006 09:02 AM
H6 3.0 and 2.5liter oil filter difference? BoMbErMAn Legacy Forum 16 07-13-2002 12:35 PM
