Old 02-18-2011, 12:49 AM   #1
taterguy05
Member#: 273191
2002 Impreza OBS
Forest Green
Default NEED HELP, will this cat fit my 02 2.5
Will this work on my 02 Impreza 2.5 outback sport, with no CEL problems?
http://www.performanceexhaustplus.co...cyoutback.html
taterguy05 is offline   Reply With Quote
Old 02-18-2011, 06:12 PM   #2
kero
Member#: 94299
2000 2.5 RS Sedan
SRP
I don't see why not, it is a cat pipe and it says for impreza matching your year range
kero is offline   Reply With Quote
Old 02-19-2011, 01:09 AM   #3
taterguy05
Member#: 273191
2002 Impreza OBS
Forest Green
just wandering if there were an o2 after this cat?
Old 02-19-2011, 02:55 PM   #4
Sir-Knight
Member#: 73636
2007 Impreza 2.5i SE
newport blue pearl
just have an exhast shop weld in the rear o2 bung if there isn't one.
Sir-Knight is online now   Reply With Quote
Old 02-24-2011, 03:16 PM   #5
02darkRS
Member#: 80918
02-7 MBP RS/i hybrid
now w/ AVLS!
Yes, the 02 has an o2 after the cat it is just after the last bend before the midpipe & should be cocked slightly toward the drivers side of the car. just lay down beside your drivers side of your car & look.
02darkRS is offline   Reply With Quote
Old 02-24-2011, 05:11 PM   #6
aclver1
Member#: 114177
2004 Impreza 2.5rs
70 Datsun Fairlady
I thought they changed the cat section in 02 so there was 2 cats? my 04 is had 2 cats and a 90 degree bend where it meet the headers. I would look around to verify that is is right. That cat looks like the pre 01's. I may be wrong but i thought they changed it. It's not uncommon that they are wrong. I saw a set of headers today for a 2.5rs that said they fit the wrx and sti and any 2.5 subaru engine.
aclver1 is offline   Reply With Quote
Old 02-24-2011, 05:23 PM   #7
aclver1
Member#: 114177
2004 Impreza 2.5rs
70 Datsun Fairlady
93-05 2.5rs have the same cat section with 2 cats and a 90 degree bend. Going by their picture it is wrong but maybe that is a a stock image and not the actual product. I would call and check before ordering.
Old 02-24-2011, 05:42 PM   #8
taterguy05
Member#: 273191
2002 Impreza OBS
Forest Green
ok thanks guys,
Old 02-24-2011, 11:23 PM   #9
rhino6303
Member#: 181314
2005 Impreza OBS SRR
05 Legacy GT RBP
If it isn't correct, try here: rockauto.com
You can find one for not much more money.
rhino6303 is offline   Reply With Quote
Old 02-24-2011, 11:50 PM   #10
T Wrex--OH
Member#: 179478
2000 Impreza 2.5 RS
Sedona Red Pearl
If your stock cat pipe is two seperate sections (flanged in between pre-cat and second cat), that cat posted will work. It does not replace the first cat, only the second one. My cat pipe is only one piece and each of the individual cats cannot be seperated, so it would not work for my car. I would not recommend buying a new cat pipe from the dealer, it's around $550.
Boxer4racing has some cat pipes:
http://boxer4racing.com/exhaust.htm#Exhaust Catalytic
Good luck.
EDIT: The cat you posted replaces the first cat in the pipe.
T Wrex--OH is offline   Reply With Quote
Old 02-25-2011, 01:41 PM   #11
02darkRS
Member#: 80918
now w/ AVLS!
OP, I have an 02 so before you go chasing rabbit trails from members with other year cars..... just lay down beside your car & look at the pipe. It'll be the same as mine & it goes:
Header - Cat pipe (front o2 & rear o2) - Midpipe - Axleback
Your cat pipe should look the same as the one pictured (bend wise) & that pipe will fit. However, I do not see the rear o2 bung on that pic. To get an idea of the year range & pipe you are looking for search MS3 HFC on rs25dotcom. I just put that pipe on mine last week. same bends as teh one you linked.
Old 02-25-2011, 04:17 PM   #12
aclver1
Member#: 114177
2004 Impreza 2.5rs
70 Datsun Fairlady
^ did you have a 90 degree bend between the first cat and your header? I can't imagine they would change the cat section between 02 and 04 then again in 06 when they went to the el header. The only differnece i know of is the 2.2 with the single port.
Old 02-27-2011, 05:44 PM   #13
taterguy05
Member#: 273191
2002 Impreza OBS
Forest Green
the reason i need to replace the cat is i got a p0420 code...blahh...i need a cat asap lol, just dont wanna but the wrong thing, im about to go look under my car
Old 02-27-2011, 05:58 PM   #14
taterguy05
Member#: 273191
2002 Impreza OBS
Forest Green
ok i just looked up under neath and it looks like they were replaced at one time....
there are 2 cats, one hooks to the headers, and its very little ?, the 2nd one looks like a reg cat...could it be the o2 sensors or could it be both the cat and 02's
heres the post cat aka 2nd one
heres the pre cat aka 1st one
Old 02-27-2011, 08:35 PM   #15
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
A bad rear O2 can cause a problem that would trigger that code (catalyst efficiency code) but if performance seems the same as always and fuel mileage has not changed the front O2 sensor is less likely to be the problem causer. If the front O2 has more than 100k miles, replacing it is due anyway.
Old 02-27-2011, 09:33 PM   #16
taterguy05
Member#: 273191
2002 Impreza OBS
Forest Green
theres an 02 in the second cat.....
Old 02-28-2011, 10:19 AM   #17
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
The O2 in (after) the second cat is just for monitoring the cat efficiency on 04 and earlier imprezas. I was referring to the first O2 sensor that senses mixture and gives the ecu data to control the EFI system. I was a little unclear so I have edited accordingly.
Old 03-01-2011, 02:07 PM   #18
02darkRS
Member#: 80918
now w/ AVLS!
the routing of the 2002 cat pipe looks identicle to the picture linked. there's an o2 pre cat & an o2 post cat. hard to believe maybe but it's true. I don't understand what the misunderstanding is though as it's supposed to be the same as the 98-05.
Old 03-01-2011, 07:01 PM   #19
aclver1
Member#: 114177
2004 Impreza 2.5rs
70 Datsun Fairlady
That's not what i'm talking about, they all with have a pre and post O2 but the picture is wrong. It is not a direct fit, i was questioning you because you kept telling him it will work. It doesn't matter if the routing looks to be the same, where it connects to the header it's facing the wrong direction and it needs a 90 bend. Here is a picture of a stock cat section on top, notice the difference.
Old 03-02-2011, 11:11 AM   #20
02darkRS
Member#: 80918
now w/ AVLS!
you're right but I would check with them. that pic might not be actual. if it is then they need to take down that ad. sorry, i was not catching what you meant without the visual. What I was getting at though is true. If you find one that is really made to fit 98-05..... it will fit your 02. OP go look at the MS3 HFC. That's another angle/view of the pipe you need.
Old 03-03-2011, 08:51 AM   #21
taterguy05
Member#: 273191
2002 Impreza OBS
Forest Green
thats pretty nice, but ive heard good things from the random technology high flow ?
Old 03-03-2011, 12:47 PM   #22
02darkRS
Member#: 80918
now w/ AVLS!
i remember looking at it awhile ago but have no other knowledge on it.
Will this header fit my 2.5i ? tjq5 Normally Aspirated Powertrain 14 05-05-2012 12:53 AM
Will this exhaust fit my 2.5i NON-Turbo?? AltairFox Newbies & FAQs 0 02-14-2011 10:38 PM
Will 04-07 USDM Sti seats fit my 2008 2.5? Brian Broz Interior & Exterior Modification 10 10-01-2009 04:58 PM
need help with ej20 swap in my 99 2.5 rs jonnyquest Newbies & FAQs 12 05-28-2008 02:00 PM
Help- Will GC8 spoiler fit my 02 wrx? fastwec Interior & Exterior Modification 2 08-06-2005 04:32 PM
