Old 02-18-2011, 04:49 AM   #1
blckout7
Member#: 189845
Default E85 question
Does anything need to be installed to run e85? Or a straight tune for it will do the trick, I ask because for the first time a gas station near by is offering it and for cheap!
Tuned on 93 octane it's costing me $3.55/gallon
E85 Is $2.49/gallon
I've started reading the e85 thread is it confirmed that it is really a 5% engine power increase on N/As?
Thank you
blckout7 is offline   Reply With Quote
Old 02-18-2011, 04:51 AM   #2
SleepinSubie
Member#: 271669
2005 Legacy gt sti
Gun metal
Also remember E85 burns twice as fast..
SleepinSubie is offline   Reply With Quote
Old 02-18-2011, 04:53 AM   #3
blckout7
Member#: 189845
From what I read in the FAQ it burns 27% quicker, however it takes less throttle for same performance
Old 02-18-2011, 05:38 AM   #4
xatnys
Member#: 271829
2011 WRX STI 5-dr
Generally speaking you need a fuel pump and fuel injectors. Also, what's already been said is that yes, it will burn faster and you will get less MPG.
xatnys is offline   Reply With Quote
Old 02-18-2011, 07:16 AM   #5
gmullin
Member#: 271800
e85 is about 105ish octane, but essentaly your usine ethonal with gas as a lubericant. ethonal is like using a less potent methonal... 100% methonal= 120 octane... 100% ethonal is around 110 octane if i rember correct... when using e85 as a primary fuel make sure you smell test your oil offen ethonal will get in their and ruin the oil
gmullin is offline   Reply With Quote
Old 02-18-2011, 02:20 PM   #6
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
No you do not need anything except a tune that increases your fueling by about 30%. You'll probably need at least a bigger pump. There's a group buy in the classified section for a walbro 255 if you want to go get one.
E85 Stoich: 9.765 AFR
Gasoline Stoich: 14.7 AFR
The math comes out so that you need about 33%-39% (depends on who you ask) more fueling. So just take your fueling chart and multiply everything by 1.33.That's the basics anyway. You'll want to change timing if you want to get the most out of it as well.
What they say is true, it burns "faster," (in ideal conditions, which i assure you an engine is not) but that's a good thing. Burning faster doesn't mean less mpg. Keep in mind ethanol atomizes less easily, so in reality your fuel will probably be burning slower. After all, what does octane stand for? Resistance to knock. The resistance to atomization is the reason for this. What really translates to mpg is the AFR as you see above. You need more fuel per unit of air. Your o2 sensor will see no difference as long as you are stoich, and you'll be fine. If you have a wideband, you can change for the type of fuel. HOWEVER, if you get your timing up, you can minimize MPG loss greatly. More timing means more torque and better gas mileage.
You also do get a SLIIIIGHT power increase. Not much.
http://forums.nasioc.com/forums/showthread.php?t=803341
This thread has everything you need to know.
formula91 is offline   Reply With Quote
Old 02-18-2011, 03:46 PM   #7
blckout7
Member#: 189845
Yeah formula that's what I started reading, but unsure if I should switch over to it and then retune, hmm a bigger fuel pump is all I need...
Old 02-18-2011, 06:33 PM   #8
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
The thing is, if you take it on a trip and there's no E85 available, you better have your laptop with you. If you have another car for long trips, and stuff, I'd just do it.
I think the 5% increase in power is really an overestimate. You won't feel anything unless you really take advantage of that 105 octane and boost like mad.
Old 02-18-2011, 07:40 PM   #9
Rudgers73
Member#: 141433
2006 Impreza 2.5i
Obsidian Black
and injectors. Also, do some reading about what E85 can do to rubber and plastic parts...
Rudgers73 is offline   Reply With Quote
VF39 + E85 = Questions I Have for You! All4BeSpinnin Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 11-29-2009 12:27 AM
e85 question.. davidsti1 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 08-11-2009 12:14 AM
E85 Questions Spike_916 Water/Methanol Injection, Nitrous & Intercooler Cooling 3 05-15-2009 10:47 PM
e85 questions. roloc31 Newbies & FAQs 14 09-17-2008 03:50 PM
E85 Question. Boxer112 General Community 26 05-22-2007 10:17 PM
