Old 02-18-2011, 11:25 AM   #1
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Default The Hella SuperTone Thread
SuperTone, and "What are those things behind the grill," threads, are becoming the new "Why wont my lights turn off" thread.
What:
-Hella "SuperTone" horns. These come as a pair, 1 of each frequency. The most popular set are rated @ 118dB. There are also sets rated at 113dB. Formerly, the 118dB sets were "Made in Germany," and the 113dB sets were "Made in India." Now, I believe they are all "Made in India"
-Typical Twin setup:
-Typical Quad setup:
Why:
-They're loud. And the tone they make is obnoxious.
-Like Replica V-Limited Lips and painted headlights, they're the "in" thing on NASIOC. The NASIOC community has the highest Hella SuperTone usage per capita.
How:
-Mounting
--The SuperTones are supplied with flat brackets. In a typical installation, these are mounted to pre-existing holes in the core support with M6x1.0 Bolts and Nuts (Alternatively, 1/4-20 can be used), or to an existing bolt on the hood latch support.
--Custom Impreza Specific brackets are available. SubieMods makes one such bracket.
--Custom options have been done. Get creative.
--Have an aftermarket alarm? Really want to piss off a car theif? Mount a pair under the dash and wire it to your alarm's siren.
-Wiring
--On the SuperTones, the Copper Terminal is +12V. The Silver Terminal is Ground. The SuperTones are also supplied with a Relay. (Note the pin configuration on this relay is different from the Industry Standard. The numbering is the same, so pay attention to those if you're using it!)
---4 ways to do this.
----a. Remove original horns. Make extensions using 1/4" Male and Female spade connectors. Male end plugs into the original horn wiring. Female end plugs into the SuperTone's +12V terminal. Ground the SuperTone's Ground Terminal using a Female spade connector and a ring terminal.
----b. Remove original horns. Using a standard automotive 12V SPST relay (Like the one Hella provides...), wire as follows: (Pin 30 - Battery positive terminal. Make sure to fuse this with a 15A fuse) (Pin 85 - Connect to original horn wiring. Recommended way is using a Male-Female extension like in Option A) (Pin 86 - Ground) (Pin 87 - SuperTone's +12v terminal). Ground the SuperTones like in Option A
----c. Leave original horns. Create your wiring like Option B, but instead of the extension from the original horn wiring, use either a wire tap or make a Y on that extension to plug into the original horn.
----d. Purchase a wiring harness. Harnesses are available from IAG Performance, SubieMods, and other NASIOC vendors.
Where:
-As always, we recommend supporting our great Vendors here on NASIOC. Almost all of them stock the SuperTones. Pricing ranges from $55-70.
EDIT: Mods I wasnt sure if this should go here in the Interior/Exterior or the Newbie forum. Feel free to move/link as you see fit. Thanks
vision.dynamix is online now   Reply With Quote
Old 02-18-2011, 11:26 AM   #2
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Placeholder.
Old 02-18-2011, 11:29 AM   #3
paradox4286
Member#: 237858
2002 Impreza WRX
WRB 20g PPG 346/279
love mine.
they really add a bit of contrast behind a normally bland grill and can be painted or powdercoated to add a bit of customization on a car
paradox4286 is offline   Reply With Quote
Old 02-18-2011, 11:44 AM   #4
FL4TFTW
Member#: 256953
2014 WRX Hatch
I <3 my supertones.
FL4TFTW is offline   Reply With Quote
Old 02-18-2011, 12:23 PM   #5
pDubs
Member#: 149317
'95 BMW M3 (E36)
'05 Kawi ZX6R, '73 CB350F
pDubs is offline   Reply With Quote
Old 02-18-2011, 12:26 PM   #6
subaru_steve
Member#: 219426
2004 Subaru WRX
WRB Stage II
I have mine....but they are still in the box waiting to be installed
subaru_steve is offline   Reply With Quote
Old 02-18-2011, 12:37 PM   #7
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Lets please not turn this into a Hella SuperTones photo gallery.
Old 02-18-2011, 01:53 PM   #8
myklwrx
Member#: 150791
2012 wrx sedan
good write up man, should have been done a looong time ago hahaha
myklwrx is offline   Reply With Quote
Old 02-18-2011, 04:09 PM   #9
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
Lol I think most people here know what hella supertones are.
xabre1200 is offline   Reply With Quote
Old 02-18-2011, 04:10 PM   #10
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Thanks for the contribution. Have you seen the no less than 5 threads in this forum and the Newbie forum this week alone? Not to mention it gets asked in every other thread that has a picture with SuperTones?
Old 02-18-2011, 04:11 PM   #11
Teh Police
Member#: 246204
My Subaru Forester
is White.
fixed that for you. Not all people...
http://forums.nasioc.com/forums/show....php?t=2136478
Teh Police is offline   Reply With Quote
Old 02-21-2011, 05:09 PM   #12
boxer fanatic
Member#: 255153
'02 Corn fed bugeye
'11 forester 2.5X SWP
^^This^^
Nice write up
boxer fanatic is offline   Reply With Quote
Old 02-21-2011, 05:21 PM   #13
problematic
Member#: 270526
2013 STI
had my pair sitting in my room for too long. i really need to put them in to bad its 20 degrees out and the garage is full of junk because we are finishing the basement.
They are some of the loudest horns ive seen that don't need an air compressor, that being said they are nothing compared to my friends truck with two train horns on it. If the noise from those dosent wake you up idk what will.
problematic is offline   Reply With Quote
Old 02-29-2012, 12:12 AM   #14
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
How about how to wire up two sets of the supertones?
SubaruImpreza_power is offline   Reply With Quote
Old 02-29-2012, 01:38 AM   #15
omz
Member#: 232060
if you want them to all go off at the same time, split the wire off 87 4 ways, in stead of 2. then ground all 4 of the horns. Its the same concept still.
omz is offline   Reply With Quote
Old 02-29-2012, 02:49 AM   #16
GhostSenshi
Member#: 279449
2004 8.78 E/T WRX
Platinum Silver
Originally Posted by FL4TFTW View Post
I <3 my supertones.
A side note, it would be in your best interest to put an inline fuse holder for the wire coming off the battery and place in a 20amp fuse.
Also, the installation thread already exists in the Electrical forum..
http://forums.nasioc.com/forums/show....php?t=1133994
GhostSenshi is offline   Reply With Quote
Old 02-29-2012, 09:27 PM   #17
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
One thing I noticed I had the inside of my relay corrode which prevented the horn from working.. if possible try to spring for some sealed relays.
And yeah put a inline fuse between the battery and 30.
Old 02-29-2012, 09:42 PM   #18
FL4TFTW
Member#: 256953
2014 WRX Hatch
I've had 2 relays fail on me already.
Old 02-29-2012, 09:44 PM   #19
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
yeah I gotta order the sealed one but worth the hassle of wondering if it's going to work or not.
Old 02-29-2012, 10:47 PM   #20
arn4726
Member#: 192574
2015 STi
ISM
here's my set up... purchased through subimods, they have a nice bracket and wire relay set up for direct pnp and have color matched horns as well but i decided on painting mine myself to save a few dollars...
arn4726 is offline   Reply With Quote
Old 03-01-2012, 01:41 PM   #21
FL4TFTW
Member#: 256953
2014 WRX Hatch
[IMG]http://i187.photobucket.com/albums/x297/srtdan4726_photos/309561_2421660226300_1395286962_2843468_708305873_ n.jpg[IMG]
The contrast of black would look much better.
Old 03-07-2012, 10:18 AM   #22
wrxtcy379
Member#: 292716
Subimods is having a group buy for horns like 49 dollars I got in there this morning
wrxtcy379 is offline   Reply With Quote
Old 03-07-2012, 10:24 AM   #23
brew02wrx
Member#: 259970
2002 wrx cobb stg2+
psm proper fitment
to each his own i like the color match blue on blue since the grille provides some contrast already
brew02wrx is offline   Reply With Quote
Old 03-07-2012, 11:51 AM   #24
ppayer38
Member#: 234407
04 Self-tooned
STi
Can't decide what color I want to make them. I know they won't stay red cause everybody has red...
ppayer38 is offline   Reply With Quote
Old 03-07-2012, 12:29 PM   #25
bz24
Member#: 309515
2012 Subaru WRX Prem
WHite
There is not a better cheap mod.
bz24 is offline   Reply With Quote
Hella Supertones with custom (RPF1) machined grilles quadtard Exterior/Styling 9 10-17-2009 12:33 AM
The Official Hella Supertones Thread Ryanpm939 Member's Car Gallery 0 11-14-2008 01:47 AM
* HELP Hella Supertones Rubbing on my STi Grille ultraspdWRX Interior & Exterior Modification 13 10-14-2007 10:14 PM
What is the two red things behind the grill on some subys?? BBBsti LTD Member's Car Gallery 16 12-28-2005 08:34 PM
('93-'01) What the heck is this thing behind the wheels? Andrew Impreza Forum 18 07-08-2001 10:58 AM
