Old 02-18-2011, 12:58 PM   #1
dux10
Member#: 235338
2002 Faggin Wagon
srp
Default And I Thought Ringland Failures were for the 2.5 motors...
well, within 24 hrs of spining a bearing in my 02 wagon, Dads sedan lost all compression on cylinder #3. We took our time over the last couple weeks pulling it out and apart (school + work = little free time) and this is what we found:
the car has 125k miles and is a typical stage 2 setup (UP, TBE, K&N, crank pulley, Walbro 255) on a conservative tune. While tuning it was requiring an unusually large amount of fuel to keep the motor happy. About a week after tuning (getting ready for a wideband install and re-tune) it started running horribly, blowing lots of smoke, and throwing misfire CELs. Compression test showed ZERO psi in cylinder #3 and the spark plug was covered in oil. We suspect an injector failed and caused a lean condition and this was the result.
He's in the process of deciding what he wants to do, but in the meantime, we all love destruction (especially when its somebody elses motor. lol) so i thought I'd share...
dux10 is offline   Reply With Quote
Old 02-18-2011, 01:32 PM   #2
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
That's too bad! Are you both getting rebuilds then?
Mike
GrimmSpeed is offline   Reply With Quote
Old 02-18-2011, 01:48 PM   #3
dux10
Member#: 235338
2002 Faggin Wagon
srp
hahaha I am and hopefully he will too. I'm doing a brand new 257 shortblock/hybrid. He will either do a 205 short block or just another 205 motor.
I just placed my first order for my build the begining of the week. Oddly enough it was with you guys. lol
Old 02-18-2011, 04:16 PM   #4
mneste8718
Member#: 51562
2004 WRX Sedan PSM
EJ205 [email protected] 300whp
so were you getting tuned without a wideband present?
mneste8718 is offline   Reply With Quote
Old 02-18-2011, 04:32 PM   #5
dux10
Member#: 235338
2002 Faggin Wagon
srp
Yes. it was a mild tune. We thought the wideband would've been delivered before the tune, but it didn't happen.
Although not having a wideband did not cause this, it could have prevented it. Tuned or not, the injector was failing either way and it would've happened anyway.
how strong/well built is the 2.5 motor? Scott_2.5TS Normally Aspirated Powertrain 14 11-15-2007 04:35 PM
Will intakes for the 2.5 fit the 2.2? Husker05 Normally Aspirated Powertrain 3 11-11-2005 10:46 AM
What's the best color and MY for the 2.5 RS? -=C=- Off-Topic 34 03-19-2003 08:11 PM
I NEED: Anybody have the clutch alignment tool? I need this for a 2.5 motor.......... mcu81 Tri-State Area Forum 2 08-27-2002 11:01 PM
