Old 06-07-2010, 11:19 PM   #1
emsmap
Member#: 159334
02 WRX, 99RS, 96L
AP3,PPG,FMIC, Big turbo
Default How to raise turbo with Perrin rotated uppipe
Hello, I just bought a Perrin rotated uppipe and I have seen the Perrin kit in pics. The turbo sits to hidden and low for my taste. How could I raise the turbo a little bit with the uppipe? Maybe somekind of an adapter plate? Maybe get longer studs for the top of the pipe where the turbo sits and get an exhaust shop to make a spacer for it so the turbo can sit on the spacer making it sit higher? Im up for suggestions, thanks
emsmap is offline   Reply With Quote
Old 06-08-2010, 01:16 AM   #2
tobylazur
Member#: 150289
2006 SV650N
1972 Travelall
I haven't seen the kit, but you more than likely could have a steel spacer made for your up-pipe. You'd more than likely have to change the inlet, downpipe, and outlet piping as well.
tobylazur is offline   Reply With Quote
Old 06-08-2010, 06:39 PM   #3
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
it sits like that so you get faster spool...i wouldnt change it... just redo the angle and/or intake system to make it a bit cleaner if thats what you're going for...
the turbo on the WRC car actually sits a bit lower and points upward... i wish more companies would mimic this... but good job going rotated! The car will but more faster and easier to work on
All4bSpinnin is offline   Reply With Quote
Old 06-08-2010, 06:46 PM   #4
emsmap
Member#: 159334
02 WRX, 99RS, 96L
Thanks guys! I really like some of the rotated kits that sit higher and you can actually see the turbo when you open the hood like turbo xs's kit. I need to get a 44mm wastegate and turbo first lol
Old 06-08-2010, 11:05 PM   #5
emsmap
Member#: 159334
02 WRX, 99RS, 96L
Ill get pics tomorrow of the uppipe, downpipe and 4 inch inlet. I basically just want to move the turbo up about 2 inches so when I pop the hood, you'll be able to see it way easier
Old 06-09-2010, 12:51 AM   #6
fobiawrx
Member#: 91074
04 sti
white
you can add a 2 inch pipe to you up pipe and get it higher. you have to change your dp to fit also. everything else should fit. a good shop should be able to do this for you.
fobiawrx is offline   Reply With Quote
Old 06-09-2010, 11:12 AM   #7
emsmap
Member#: 159334
02 WRX, 99RS, 96L
Thanks fobiawrx! When I get a turbo and wastegate, I will take it to a shop to get welded
Old 06-09-2010, 12:18 PM   #8
PERRIN_Chris
Member#: 186665
2014 BRZ
To raise the turbo, you will have to do a lot of modification, raising the turbo will also mess with the alignment of the intake, since it's designed to be a cold air intake, moving the turbo will cause the cold air intake to not line up and go through the hole in the fender. You may have to make a new pipe to connect to the first boost tube coming off the turbo. Theoretically it can be done with machined spacers on the up pipe, but the downpipe will have to be cut and extra length added.
PERRIN_Chris is offline   Reply With Quote
Old 06-09-2010, 10:22 PM   #9
1fly05sti
Member#: 151009
05 STI OBP
under construction
this is the adapter im using for my rotated set up, bolts up to any stock location up pipe and the other flange was rotated, simple and cheap
1fly05sti is offline   Reply With Quote
Old 06-09-2010, 11:19 PM   #10
emsmap
Member#: 159334
02 WRX, 99RS, 96L
Thanks for the input man! I actually am not going to run the cold air intake. I have the Perrin short ram 4 inch inlet. Also I am custom cutting my existing intercooler pipes to work with it, so thats not an issue.
Old 06-09-2010, 11:20 PM   #11
emsmap
Member#: 159334
02 WRX, 99RS, 96L
1fly05sti--- that is pretty awesome man! I like that alot. Where did you get the 2 flanges at?
Old 06-09-2010, 11:27 PM   #12
emsmap
Member#: 159334
02 WRX, 99RS, 96L
also! I might actually be going to this towing business tomorrow to look at Holset turbos off some older trucks. Does anyone know if they will bolt up to the Perrin pipes and what is the smallest one? Thanks
Old 06-10-2010, 02:48 AM   #13
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
go for the hy35 if you go for a holset off of an old diesel. they have the small housing, so you will get quicker spool
olsen726 is offline   Reply With Quote
Old 06-10-2010, 09:14 AM   #14
emsmap
Member#: 159334
02 WRX, 99RS, 96L
Thank you!!
Old 06-10-2010, 12:01 PM   #15
fobiawrx
Member#: 91074
04 sti
white
i don't think that turbo is a 4 bolt. si you would need a new flange on your dp.
why don't you just sell your kit and buy one you like or have one made. i make kits for people all the time because they want things a certain way or want to use a certain turbo. you might be able to break even if you get a good price for everything
Old 06-10-2010, 01:45 PM   #16
emsmap
Member#: 159334
02 WRX, 99RS, 96L
Its always a possibility man. I am new to rotated setups so I found this perrin setup and thought it was the way to go but I found out how low the turbo sits with the perrin uppipe and I was kinda disappointed lol. I just want it to set up like the turboxs or other kits (not so hidden) I dont have a external wastegate uppipe so that is mainly why I bought it. I guess I will buy a t3t4 turbo and wastegate and then worry about how it sets when I get to that dilemma lol
Old 06-11-2010, 11:37 PM   #17
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
EMSmap... imo this is a waste of money. I know you want the turbo to bling but i would seriously be more concerned with where it sits behind the head for ease of installation and getting a metal intake/piping made
A car with clean/polished intake and fmic piping tends to bling pretty good. If I were you, I would get custom made intercooler piping that fits specifically to your car and run piping specifically sized for your turbo. Fmic kits like APS, turboXS, etc often use piping that is too large... P&L makes a good kit.
But ya, get your piping customed and shortened for faster spool and get it polished for bling. The turbo sitting low shouldnt be a concern. Again, this is my opinion based on technical data
If you are really stuck on raising it, the pic posted above is a possible fix... remember, you will have another gasket to worry about and more bolts.
Old 06-12-2010, 12:44 AM   #18
emsmap
Member#: 159334
02 WRX, 99RS, 96L
I am actually just going to get an adpater plate to put between the uppipe and the turbo and put longer studs in. I will have 2 T4 gaskets for this. This should work no problem
Old 06-19-2010, 02:18 AM   #19
piddster
Member#: 144285
1993 UHEV Legacy
Get rid of the Perrin garbage and have someone fab something that works.
piddster is offline   Reply With Quote
Old 06-20-2010, 08:44 PM   #20
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
CGM
Funny^^ My gt35 has never complained? It was a easy install both tines I have had it apart.
Sinister redlines is offline   Reply With Quote
Old 06-21-2010, 12:42 PM   #21
PERRIN_Jarid
Member#: 214449
Why is our rotated kit garbage? The fit and finish is excellent and we have have had near zero problems with their performance.
PERRIN_Jarid is offline   Reply With Quote
Old 06-21-2010, 01:37 PM   #22
69subaru360
Member#: 159682
1995 WRX
2015 F150
Want to sell just perrin up and downpipes? I might buy them off you for future projects if you want to sell. Then you could buy txs pipes.
Old 06-21-2010, 02:08 PM   #23
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
You can't use a spacer like you are describing. The top flange for the turbo sits at an angle. Putting a spacer on it would only get it closer to the strut tower.
Just some food for thought...have you ever asked yourself why TXS is the only kit with a turbo 20ft in the air?
CKxx is offline   Reply With Quote
Old 06-21-2010, 02:28 PM   #24
emsmap
Member#: 159334
02 WRX, 99RS, 96L
LOL Why is that? WHy does TXS kit sit higher than anyone else?
Old 06-21-2010, 07:24 PM   #25
CKxx
Member#: 33458
93 RX7+09 Forester
I was simply hinting that maybe there is a performance reason, like having a shorter up-pipe, or a downpipe without such an extreme bend coming off the turbo.
FS - VF30 Turbo with Perrin uppipe WRenXhaven Engine/Power/Exhaust 5 09-18-2009 09:57 AM
FS: Brand new Perrin Rotated Uppipe/gt3076r kmurphy Engine/Power/Exhaust 13 11-12-2008 12:15 PM
Perrin Rotated Uppipe/Downpipe/Intake nick32 Engine/Power/Exhaust 32 11-11-2008 04:04 AM
Help with Clocking turbo in Perrin Rotated Setup Install roybfr Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 05-31-2006 08:17 AM
How to raise mid-range with Alpine il96 Car Audio, Video & Security 10 11-02-2003 08:53 PM
