#1 |
Member#: 274290
import face off
bardenton fl sunny 80F, sea level 11.3@123 2004 STi street tuned by Omar Crespo @ Area 51 tuning Stock 2.5 bottom end with 98k on it, drop in CP pistons stock 6 speed red line shockproof trans fluid target boost 26psi target afr 11.5 pump gas mix with c16 and meth act clutch stock flyweel precision 6265 BB turbo custom up pipe by roque machine shop cosworth intake aem ecm aem meth kit profect boost controller blitz cat back ebay front mount with custom piping turbo smart bov precision wastegate ask for more if you want to know This pass was done with 0 boost on the two step due to stock axles and i missed 5th first attept, car has done 100mph in the 1/8th so i know that when i do a 4th gear swap it will pull 10's. http://www.flickr.com/photos/59696397@N05/5459565974/
#2 |
Member#: 133893
Vehicle:2004 JBP Lesbian XT 68HTA 12.20@113 |
#3 |
Member#: 274290
#4 |
Member#: 274290
im just nt getting this photo crap right. sorry
#5 |
Member#: 274290
#6 |
Member#: 141754
Vehicle:04 stock wrx ;) z31 project, passat dd |
pretty nice passes upgrade the rear axles get as little better 60' and enter the 10's what gear upgrade are you doing
#7 |
Member#: 192664
BAIC
Vehicle:2004 gt30r WRX STI WRB |
wat were u running that trap 100mph in the 1/8 and 124mph in the 1/4 but ran 15's
#8 |
Modest Mouse
Moderator Member#: 27323
AKIC
Vehicle:2000 RSTi |
Drop in pistons wouldn't classify you as a stock block!
Great times! |
#9 |
Member#: 64908
Vehicle:10.8 XT+ Real stock turbo record holder 11.4 |
CP pistons = Not stock block
Quite a few actual stock block STI's around here going 130-133mph traps and 10s 11.3@124 is nice though! Congrats |
#10 |
Member#: 145145
Vehicle:2006 wrx STi |
The #1 issue with running big HP on the stock block is the weak stock pistons. You have eliminated that issue by employing a non stock piston. While an effective solution to the problem the solution precludes it from being stock.
Let me help you: Built block Sti goes 11.3 thx to forged pistons, good driving and decent tune. We all love seeing subi owners and shops producing quality numbers. And we all understand that shops like to brag about these numbers. However, misrepresenting numbers does nothing to help the reputation or credibility of your shop. It makes you look like a bunch of shady wannabees. Last edited by MartinSTi05; 02-19-2011 at 10:31 PM. |
#11 |
Member#: 153880
RMIC
Vehicle:03 Evo VIII 2011 STI |
If you said 10.3 with stock rods I might be more impressed.
![]() Stage 2 block going 11.3 isn't all that awesome, especially with AEM and a 6262. |
#12 |
Member#: 64908
oh damn didnt even notice the AEM and 6262.. Should be in he high 120s low 130s with that.
#13 |
Member#: 152576
SWIC
Vehicle:2006 STI 10.8@ 129 www.Mayhemtuning.com |
Not bad. But needs to bea mid 10 at least. That turbo is more then capable to do it. I went 11.1 with drop ins on. Fp red.
#14 |
Member#: 260624
TXIC
and i got all excited for nothing
jkill be posting the first "STOCK" WRX block to run 10s very soon. . . . . JK once again 11s though is pretty nice though |
#15 |
Member#: 274290
Ok, guess that's by fault. To me if the block and bottom end are stock, I would call that stock. But as for the post I can see I'm very wrong. My bad. Still think for stock heads, cams, bottom endhaving ~ 100k on it, its doing ok. Sorry to get anyones hopes up with the subject then let them down.
#16 |
Member#: 274290
I'm doing a taller 234 with billet forks upgrade. We I go to the local 1/8 mile its always trapping right around 100 cause I let it hit the revlimit in 4th. At the quarter I'm horrible a= hitting 5th. So I think it will get me where I would like to be. I will also be iknstalling dss axles and drag radials. So far I've been using 0 bosst on the 2step and bs potenza street tires.
#17 |
Member#: 145145
Overall not too shabby.
#18 |
Member#: 223129
South East
Vehicle:2004 sti 500+whp silver |
Yea, id agee, ur pulling almost 30mph in back eight so if u don't. Have to hit 5th, should be hitting high 120's to low 130's with 10's even with out the drag radials. Sounds like 5th is ur only hold back. Its very impressive for street tires imo.
#19 |
Member#: 117862
E. Canada
Vehicle:2006 STi 10.85@129.4 96 impreza 9.55e.t.146mph |
congrats
At 26 psi with street tires, stock heads, stock cams at full weight (3300 lbs plus) you are exactly where you should be with the 04 6 speed. My car back a couple years ago with similar mods to yours(just rods and pistons, no headwork or cams) but with just 93 octane and 50/50 meth and at 25psi. |
#20 |
Member#: 274290
#21 |
Member#: 274290
#22 |
Member#: 77470
Vehicle:04 sti 10.51@138.5 on e85@ 30psi--spinning |
the car has more in it the way it sits with the 04 6spd,you just need to practice and bring your driving skills up.Also just relax and and take your time and the shift to 5th will not be a problem.
#23 |
Thanks Sir Alex!
Moderator Member#: 88606
Vehicle:2011 GMC Sierra 1990 Miata |
Please update your 1st post with the required format found here. Thanks.
http://forums.nasioc.com/forums/show....php?t=1858764 |
| Thread Tools | |
| Display Modes | |
| Agile built and tuned w/ FP Red goes 11.3 | Agile Auto | Proven Power Bragging | 33 | 07-29-2009 11:42 PM |
| Stock Turbo STi goes 12.02 @ 113 | STi Mikey | Proven Power Bragging | 112 | 12-14-2008 04:39 PM |
| STi goes 13.3 in 1/4 @ 4100ft. | AnthonyC.01 | Proven Power Bragging | 5 | 03-22-2006 03:14 PM |
| F1DYNO STI Goes 11.66 @ 125.66 On 93 Octane With Water Injection ! | F1DYNO | Proven Power Bragging | 26 | 10-24-2005 11:41 AM |
| Vishnu STAGE 2 STI goes 11.8@116 in the HEAT | MARKGSTI | Proven Power Bragging | 45 | 09-16-2004 01:39 AM |
