Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 02-19-2011, 07:05 PM   #1
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
Question doughnut gasket question
So it took me 2 years to noticed why the car i got from a private sale had a larger then normal gasket on it.. long story short the little pipe extension from the flange on the stock cat was I guess gone.. So when I went to replace the gasket one day it never sealed.. OK
So I ordered my cat converter and I have a question should the gasket slip over this part or is it correct shown here?
SubaruImpreza_power is offline   Reply With Quote
Old 02-19-2011, 08:47 PM   #2
Subyroo2.5
Member#: 168129
2013 WRX
WRBP
It should slip over that part. those gaskets suck. if you can have a muffler shop weld a flat flange on each side so you can just use a flat exhaust gasket.
Subyroo2.5 is offline   Reply With Quote
Old 02-19-2011, 08:53 PM   #3
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
it's odd I'd hate to have to cut it up because I'm not really looking to spend extra money on something so small.
in this case the gasket is about 2 mm too thick to fit around the pipe.
Old 02-20-2011, 01:30 PM   #4
Sir-Knight
Member#: 73636
2007 Impreza 2.5i SE
newport blue pearl
yeah those chicken wire gaskets are terrible... they never seem to compress properly, I've gone through about 3 of them and every time I had to use some muffler cement to seal it up. You can get a set of calipers and measure the interior diameter, the thickness and the outer diameter... that looks like a 2.5" gasket, in which case the solid graphite gasket from the STI might work. They're pretty cheap to. Also vibrant makes a few donut gaskets as well that might fit.
Sir-Knight is offline   Reply With Quote
Old 02-20-2011, 02:09 PM   #5
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
it should be a 2.5" gasket but I will check with the calipers it's just crazy.
Old 02-20-2011, 02:30 PM   #6
7L Autosport
Member#: 236270
2011 Impreza WRX STI
Check with your local Subaru dealer parts department. Subaru changed the size of those donut gaskets a few times in the 90's. Just order up a correct one. It's cheaper than having a new flange welded on, and will seal perfectly.
7L Autosport is offline   Reply With Quote
Old 02-20-2011, 03:07 PM   #7
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
I gasket i have is the part number they have for a 95 legacy L.. only thing is I take a little a little off the gasket so it will fit.
wtb cat back exhaust gasket, and doughnut gasket Jeenyus MWSOC Private Classifieds 0 10-27-2007 05:03 PM
Q: What is inner diameter of WRX doughnut gaskets? DreddRS25 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-29-2005 10:09 AM
Doughnut gasket part numbers Jsunn Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 08-04-2005 10:06 AM
Squeaky doughnut gasket wall of tvs Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-23-2005 05:16 PM
Where can I get 3 inch doughnut gasket? waitandbleed92 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 03-10-2004 12:08 PM
