Welcome to the North American Subaru Impreza Owners Club Wednesday November 25, 2015
Old 02-19-2011, 11:45 PM   #1
Member#: 164172
87 GL
Default Power failure question URGENT
i have a 97 OBS 2.2
it all starting last night, my car just would not have ANY power(voltage) after i filled gas. i pulled up to the gas station and after i was done, turned the key and i noticed all my lights were NOT lighting up, or cranking, or anything...
when i initially turned off my car, i heard a relay clicking multiple times, with key out, it stopped and didnt think anything of it. (the relays on the firewall near driver.)
after about 5 mins, my car lights just turned back on, i started it and off i went. I drove about an hour and my radio shut off for a spilt sec, it did this every 10-15 mins or less...
while driving i notice my lights get dim (interior and exterior). AND my radio shuts off for a spilt sec...this is intermittent...
i work at an auto parts store so i tested the battery and alt. both are fine. BUT when i tested the battery the first time it show .98v, NOT 9.8v, but i started it up fine. i tested it again like 2 mins later, and it showed 12.8v, which it perfect. alt is fine as well..
it seems as if this problem is intermittent...could it be one of my relays? i thought if relays go out, they are OUT.. i didnt think they work sometimes...
please help?
azn0boi04 is offline   Reply With Quote
Old 02-20-2011, 11:32 AM   #2
Member#: 274521
Default Possible loose batt connection
OK I would CLEAN the battery connections Then re test batery Possible shorted battery internally.
Good Luck
CarDOC7 is offline   Reply With Quote
Old 02-20-2011, 12:47 PM   #3
Member#: 165749
Some relays can be intermittent if they become burned or the mechanism inside fails. I have seen both things happen.
DTEC BC Power failure Kastley85891 Electrical & Lighting 4 08-07-2007 10:12 PM
Phase I 2.5L Head Gasket Failure Question Hovmerlin Warranty Issues & SOA Problems 1 02-12-2007 08:03 PM
Phase I 2.5L Head Gasket Failure Question Hovmerlin Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 02-11-2007 08:20 PM
motor failure question (building up) DoctorNick Normally Aspirated with bolt-on Forced Induction Powertrain 24 10-28-2002 01:03 PM
Uppipe & EGT sensr failure question. Sandkicker Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 10-14-2002 08:07 PM
