Old 02-21-2011, 05:37 AM   #1
AVANTI R5
Member#: 73805
2016 Cayman GT4
black
Default 2012 Mazda 3 Gets 158-HP Sky-G Engine, On Sale This Fall / Driven Diesel
http://blogs.insideline.com/straight...this-fall.html
A refreshed 2012 Mazda 3 hatchback quietly debuted this past week in Toronto... well, maybe not quietly, but we Americans don't exactly have our finger on the pulse of current events in Canada. In any case, the car is subtly restyled, but still maniacally happy. The much, much bigger news is that the 3 will have Mazda's new direct-injected "Sky-G" 2.0-liter inline four-cylinder gasoline engine when it goes on sale this fall.
Said engine will make 158 horsepower at 6,000 rpm and 151 pound-feet of torque at 4,000 rpm while running on North American-grade 87 octane. That's with a 13:1 compression ratio. (On higher octane European fuel, the engine will run at 14:1 compression and make 163 hp and 155 lb-ft.)
This engine will initially be offered with the new Sky-activ six-speed automatic transmission that's lighter and more efficient than the current five-speed automatic. We'll see Mazda's new 6-speed manual transmission, too, but availability will be delayed in North America (where manual-gearbox take rates are low compared to Europe). Still, says Mazda spokesman Jeremy Barnes, "there is every intention that there's a manual coming though."
Engineering Editor Jay Kavanagh has already sampled both the Sky-G and the 2.2-liter Sky-D diesel engine (headed our way in early 2013) in Euro-spec Mazda 6 prototypes, so check out his driving impressions after the jump.
Driving Sky-G
At a briefing in Berlin, Germany, we drove various development mules (TPVs or Technology Proveout Vehicles in Mazda-speak) of the next-generation Mazda 6 equipped with the 2.0-liter Sky-G coupled to the new six-speed automatic and manual gearboxes. These were the higher-compression ratio versions, not the U.S.-spec ones.
Right away, the thing you notice is that this is not an engine that needs revs to deliver the goods. Torque is ample even at the low end of the tach, and it is delivered brightly all the way through the midrange and near the upper reaches.
In its current guise this is not intended to be a performance-car engine, but for everyday use it provides the right kind of motivation -- solid and linear thrust from low revs. The combination of direct injection and high compression provides sharp throttle response, too. It's the kind of engine that will serve Mazda's workaday applications quite well.
It could use a bit more personality like a more mellifluous intake note as today it sounds fairly prosaic. Final calibration and NVH work is still underway, though, so maybe there's a chance Mazda can fruitify the engine note. Yes, fruitify. -- Jay Kavanagh
Driving Sky-D
Mazda handed us keys to yet more Mazda 6 development mules, these ones sporting the Sky-D diesel engine. And believe us when we say that this 2.2-liter diesel is poised to make a splash when it shows up here in the U.S. in the brandy-new 2013 CX-5 cute-ute (basically a tall Mazda 3 hatchback).
Mazda benchmarked Europe's best diesels in the development of Sky-D and reckons they've got the establishment beat all around.
Torque is the calling card of a diesel, and the Sky-D delivers. In U.S.-spec guise it will churn out 310 lb-ft of torque at approximately 1,800 rpm and generate a peak of 167 horsepower at 4,500 rpm. It'll rev all the way to 5,200 rpm, which is pretty darned high for a diesel, permitting gearing that doesn't necessarily have to be super tall.
Sky-D said to return 43 mpg on the U.S. highway cycle in these cars. Mazda hasn't confirmed the existence of the CX-5, so take your best guess on its fuel economy.
Our driving route in Berlin included an unrestricted portion of the autobahn. Here, the Sky-D pulled with authority. Its powerband is broad and immediate and there was really no need to downshift to get back up to speed after a bit of light traffic materialized ahead. We could just leave it in 6th and give it wood. With little effort, we were cruising at just shy of 140 mph.
Around town the Sky-D similarly impressive. There's precious little waiting around for boost to arrive. Sure, you can force it below its boost threshold by laying into the throttle at 1,500 rpm in 4th, but even then the engine doesn't exactly go flat. In actual practice, a meaningful swell of thrust is always just a toe-dip away.
This engine doesn't feel like a boat anchor in the nose of the car since the block is aluminum. It's quite smooth, too, thanks to a counter-rotating balance shaft. You can, however, tell this is a diesel by the way it sounds. Not because it is clattery -- it isn't. Thrummy is a better description. In the diesel-averse United States, Mazda would do well to spend some more time on the Sky-D's aural signature. This diesel's got the kind of power delivery and response that will win over skeptics, so why not make it a trifecta of win? -- Jay Kavanagh
Old 02-21-2011, 06:15 AM   #2
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
This is good news.. and will probably steal a ton of the market from VW.
IBOMGhurr310lb-ftMazdaspeed3TDIdurr
Old 02-21-2011, 08:49 AM   #3
Einzelherz
Member#: 73922
Blue 97 Civic thingy
I thought the point of the Sky-G was a significant bump in fuel economy. Not one single mention of it.
Einzelherz is offline   Reply With Quote
Old 02-21-2011, 09:37 AM   #4
shikataganai
Member#: 92634
'07 Land Cruiser
'12 RAV4 EV
Many new possible practical + efficient vehicles for my wife come 2013 or so:
Mazda CX-5 Sky-D
Ford C-Max Energi
Toyota Prius v
VW Jetta SportWagen TDI
Volvo V60 diesel PHEV, should it ever come to fruition, assuming it isn't cramped in the back…
shikataganai is offline   Reply With Quote
Old 02-21-2011, 09:41 AM   #5
ej20ajk
Member#: 113223
08 WRX NB R180
It appears Civic will have very stiff competition.
ej20ajk is offline   Reply With Quote
Old 02-21-2011, 10:25 AM   #6
Sideshowbob
Member#: 50304
97 TJ Wheeler
12' TSX Wagon
God I want that diesel NOW!
Sideshowbob is offline   Reply With Quote
Old 02-21-2011, 10:42 AM   #7
Kenjan
Member#: 27894
Civic hasn't been competing in quite some times already.
Kenjan is offline   Reply With Quote
Old 02-21-2011, 10:56 AM   #8
ptclaus98
Member#: 87888
1998 Jetta VR6
Wheres my vape, bruh?
I've just found my first car.
ptclaus98 is online now   Reply With Quote
Old 02-21-2011, 03:17 PM   #9
Lantec
Member#: 48685
2010 Prius
http://www.autoblog.com/2010/09/01/r...ets-30-40-mpg/
Unofficially but that's what is being reported
Lantec is offline   Reply With Quote
Old 02-21-2011, 08:26 PM   #10
JuggernautTCW
Member#: 169223
you aint got a car now?...
JuggernautTCW is offline   Reply With Quote
Old 02-22-2011, 01:24 PM   #11
Einzelherz
Member#: 73922
That works for me
Old 02-22-2011, 01:28 PM   #12
Smdavis27
Member#: 219455
2009 WRX Sedan
Satin White Pearl
so pathetically weak, even for a daily.... toyota/yamaha was able to extract 180hp from the 1.8l 2zz motor... although using premium fuel, thats a LOT more performance per/liter than this boat.
Smdavis27 is offline   Reply With Quote
Old 02-22-2011, 01:41 PM   #13
LoveMyCoupe
Member#: 257123
The diesel option is the part that interests me.
LoveMyCoupe is offline   Reply With Quote
Old 02-22-2011, 01:46 PM   #14
Sideshowbob
Member#: 50304
97 TJ Wheeler
12' TSX Wagon
Yeah, at like 25 mpg.
Old 02-22-2011, 01:54 PM   #15
rexster
Member#: 22863
2015 WRX Premium CWP
and with no torque...
rexster is offline   Reply With Quote
Old 02-22-2011, 02:01 PM   #16
FaastLegacy
Member#: 11671
Meanwhile, Honda sold 260k of them last year, second only to the Corolla in that segment which only sold 6k more. The third place Ford Focus sold nearly 100k less than Honda did Civics.
But uh yeah, you're right, not competing, sure.
FaastLegacy is offline   Reply With Quote
Old 02-22-2011, 09:14 PM   #17
Skunkers
Member#: 115480
Was wondering when someone else was gonna say it.
Skunkers is offline   Reply With Quote
Old 02-22-2011, 09:30 PM   #18
Skunkers
Member#: 115480
Of course the 2ZZ was the performance model engine in the likes of the S-model Toyotas (Celica GT-S/Matrix XRS/Corolla XRS), so really the 140hp 1ZZ was the engine you should compare this to. And there is a premium-only performance motor for this car... it makes 260hp. So maybe you can stop making stupid comparisons now.
Old 02-22-2011, 09:31 PM   #19
Celery GT-5
Member#: 98210
2016 Forester XT CWP
2002 WRX SRP
lol
2zz is a lot of fun, I miss mine
Celery GT-5 is offline   Reply With Quote
Old 02-22-2011, 11:08 PM   #20
kage
Member#: 25101
Chapter/Region: HIIC
2002 PSM WRX Wagon
1999 Twilight Blue Miata
That 180hp was at stratospheric RPM (about 8000 as I recall), and below 6000 rpm the motor was completely gutless. It also had crap fuel economy. Not what you really want out of a daily driven family hatchback, especially in the days of $3+ gasoline. As the new Miata's motor, on the other hand...
kage is offline   Reply With Quote
Old 02-22-2011, 11:12 PM   #21
Celery GT-5
Member#: 98210
2002 WRX SRP
it had great fuel economy...best of any car I've owned
if you want easy on it you could get 24-25 around town and 33+ on the highway. it did have a crap stock tune but it was still quite amusing. great interior too. my bro picked up a beat 03 vibe gt 6 speed for 2200 with 170k on it, just rolled past 200k and it still pulls hard in lift
Old 02-23-2011, 06:26 AM   #22
dedrooster
Member#: 32278
2000 2.5RS SRP Sedan
MB 190E 2.3-16v
The only thing that concerns me about this article is that it implies that we are only getting the diesel in the CX-5, and not in the 3 or 6.
dedrooster is offline   Reply With Quote
Old 02-23-2011, 06:40 AM   #23
chitownwrx
Member#: 203065
2016 Golf R
Lapis Blue
Bring the diesel four! BMW has been hogging theirs all to themselves in Europe for quite a while. Didn't think I'd see a non-Euro automaker stepping in. Interesting that it's an Al block, should help handling quite a bit. Now Jetta TDI Cup will have some competition. Sorry all I can manage this time of am is disjointed phrases. And they said, "give it wood."
chitownwrx is offline   Reply With Quote
Old 02-23-2011, 07:49 AM   #24
Jessekrs123
Member#: 236927
2015 BRZ, 93 Legacy,
1984 BRAT
High compression ratio and nothing to show for it?
Jessekrs123 is offline   Reply With Quote
Old 02-23-2011, 09:42 AM   #25
Einzelherz
Member#: 73922
Umm, efficiency?
008 Infiniti M35 to get 303-hp V6 VQ35HR engine AVANTI R5 Non-Subaru News & Rumors 27 09-04-2008 06:13 PM
Scanmaster 3 Scan Tool / Datalogger in stock and on sale! Full Throttle Engine/Power/Exhaust 18 08-07-2008 12:58 AM
Mazda RX-8 'True Red Style' Special Edition on Sale in Japan NYCshopper Non-Subaru News & Rumors 13 03-06-2006 12:45 PM
New Mazda 3 MPS = 256 HP mhoward1 Off-Topic 32 04-22-2005 09:18 AM
