Old 02-21-2011, 12:05 PM   #1
CGMDan
Member#: 127883
'09 C63 AMG '99RSTi
'05 CGM STi - RIP
Default STI >99RS; Anything I'm missing?
So this weekend I'm swapping my old '05 STi drivetrain into my new 99RS. It's already got the motor swapped, just need to do the rest. I want to make sure I've got everything lined up so there's no suprizes. The STi drivetrain is already pulled. I'll be running it with RCE T2's.
The suspension components were pulled whole. Meaning everything is still connected. Uprights, hubs, lower control arms, brake calipers, etc.
Here's what I've got...
STI transmission
T2's with GTWorx front camberplates
Rear Cusco RS camberplates
Front suspension
Rear suspension
STI axles
New motor/trans mounts
Trans fluid
Brake fluid
New clutch
Drive shaft
Rear diff
Is there anything else I should be looking at? anything I'm missing? Is there any wiring I need to be concerned with? Every thing is being done in an actual shop so we've got car lifts, tranny lifts etc.
thanks
Dan
CGMDan is offline   Reply With Quote
Old 02-21-2011, 09:24 PM   #2
sense of nature
Member#: 112759
2018 STi Mikey Tuned
SexyRP
Driveshaft?,Rear diff?Speedo sensors need to be swapped( rewired).....
sense of nature is offline   Reply With Quote
Old 02-22-2011, 12:41 AM   #3
CGMDan
Member#: 127883
'09 C63 AMG '99RSTi
'05 CGM STi - RIP
Got those. Forgot to put them up. Thanks
So what about brake/clutch master cylinders? The RS has ABS now if it matters. Do I need to transfer those over also? And what about the brake booster?
Old 02-24-2011, 06:29 AM   #4
spintheground
Member#: 239638
2007 WRX TR UGM
02 MR2 EGM
Do you want to keep ABS? Don't think the RS has the same pump as the STi.. I'm pretty sure if that's everything you're doing you're going to have issues with ABS and speed sensors.
http://forums.nasioc.com/forums/show....php?t=1672474
Originally Posted by Cyclops View Post
Here is what you need for a complete swap into a 2000 2.5rs. The 98 is different because it has a different style clutch but this list should hold true for any 99-01 2.5rs. I haven't completed the swap yet, but I'll add on if I missed anything. Also, STI wheels will fit but with 225s you'll probably rub. Your best bet is either different tires, coil overs or a lot of rolling, cutting, and pulling. ALSO NOTE: you can use STI lower control arms up front but from what I'm told STI lateral links in the rear won't work, they make your camber go crazy. You can get adjustable lateral links or you can get the STI pink lateral links for the RS or just stay with stock. Stock style means stock rear sway and the biggest I can find is like a 22mm, which sucks. I really wanted 27mm again on the RS so I'm going with the adjustable Whiteline lateral links.
ALSO: You'll have to do something in the back for the top hats. The front top hats are all the same from 93-07 AFAIK, but the rear STI tophats are bigger. Two of the holes will fit great, the third you either have to move the stud on the top hat or oval out the hole in the perch to make it fit. The best solution is coil overs. You can get coil overs that will fit the STI knuckle but have the top hats for an RS. I'm still researching this so I'll update later.
What you need:
5x114.3 wheels - $700 /w crappy tires
STI Springs - $200 for Cobb springs /w struts
STI Struts - came with springs
STI 6 speed - $3000
STI 6 speed clutch fork - included with tranny
STI hubs /w knuckles - $100
STI drive shaft - $35
STI tranny mount - included with tranny
STI axles - $200
STI rear diff - $200
STI clutch, flywheel, and pressure plate - included with tranny
STI 6mt shift linkage - $100 for a brand new short linkage
STI 6mt shift knob - $25
STI 6mt shift lever - $80 for Kartboy SS
STI 6mt shifter bushings - $40 for Kartboy front and rear
STI Brembos /w pads and rotors - $1200 with rotors and pads
STI rear subframe that the diff and axles mount to - freebie
STI or 02-05 clutch slave cylinder (pull style) - $30
What you'll reuse:
ABS sensors
Brake lines
All the nuts and bolts to mount stuff
Clutch master cylinder
Optional stuff:
STI Lower control arms (need STI FSB and endlinks also) - Paid $150 for the LCAs and another $140 for a Whiteline 27mm FSB and $50 for Whiteline endlinks
Aftermarket DCCD controller - Paid $340 for a Spiider
Coilovers! - definitely recommended to make it work perfect
Adjustable or stock rear lateral links
spintheground is offline   Reply With Quote
Old 02-25-2011, 12:04 AM   #5
CGMDan
Member#: 127883
'09 C63 AMG '99RSTi
'05 CGM STi - RIP
http://forums.nasioc.com/forums/showthread.php?t=1672474
The timing for your post couldn't have been better. I was just looking up some final things and the link answered alot.
Thanks!!
is there anything im missing for my vf43/sti tmic swap? vhalin Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 01-13-2008 06:07 PM
Anything I'm missing on my 20g Upgrade? Henryk Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 32 09-11-2006 10:29 PM
help me spot anything ive missed djviper Motorsports 19 04-13-2006 09:56 PM
I'm missing a joke right? UncleMeat Off-Topic 10 08-10-2004 10:25 AM
Typical NE NJ meets? I'm missing out! amp5 Tri-State Area Forum 12 12-03-2001 06:00 PM
