Welcome to the North American Subaru Impreza Owners Club Friday July 31, 2015
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Gauges & Electronics
Closed Thread
Old 02-21-2011, 01:29 PM   #1
AJW Performance
Vendor Sales Rating: (38)
Member#: 219896
Default Defi gauges, STRI, AEM, Zenesis remotes, ATI pods + Many more. Great deals always!
Defi Advance CR series 52mm or 60mm Gauges
Defi-Link Advance CR 52mm gauges utilize Defi's next generation, Defi-Link Advance control unit for ultra precise monitoring and interaction. A built in warning light will illuminate if any short, sensor failure, or connection failure is detected. Defi also built in a user-determined "peak" and "warning" setting that will illuminate a light to indicate that one of these value has been reached. The Advance CR system is able to record and play back any gauge display for up to three minutes. Note that Defi-Link Advance gauges and control unit are not compatible with the standard Defi-Link system.
Features:
Driving data can be stored and can be replayed up to 3 minutes.
Warning by buzzer sound (defeatable) when the warning LED is on.
Records peak values and warning values during driving.
The illumination at night can be switched between 2 different colors. (White dial: amber red / blue; Black dial: white / amber red)
Self-diagnosis system turns the warning LED on to indicate any wire disconnection, short circuit or serial communication error.
Available in White dial/Amber Red/Blue or Black dial/White/Amber Red
(Defi-Link Advance control unit required for these gauges )
2.0 Bar boost gauge
Intake Manifold Pressure Gauge
Oil Pressure Gauge
Fuel Pressure
EGT Gauge
Water Temp
Defi's Racer series
Defi's Racer series gauges will reward you with their great response and reliable readings. The gauge faces are a stealthy tinted black when the power is off. Fire up your car and enjoy Defi's signature sweeping ceremony as the gauges light up bright. Defi Racer gauges are standalone gauges as they do not require a Defi-Link Control Unit for use. The temperature gauge can be used for water or oil and the pressure gauge for fuel or oil. The Racer series are smaller, less expensive, and don't require a control unit but still have the aggressive styling and accuracy that Defi is known for. These gauges are 52mm and display in US measurement units.
Features:
The outer bezel contains a red triangle and can be rotated to be used as a visual indicator.
Enjoy Defi's signature flashing and sweeping ceremony on power on / off.
Self-diagnostics function monitors both sensor disconnection and short-circuiting during startup.
Red Racer, White Racer, or Blue Racer 52mm
Boost
Temp gauge
Pressure
Voltage
EGT
AEM Digital display gauges
AEM's digital display gauges feature a standard 52mm gauge housing that fits in most gauge pods and can be remotely mounted virtually anywhere. Each gauge includes interchangeable silver and black bezels & black and white faceplates to personalize the look of your gauge; it's like having four designs in one! Each gauge includes 24 color-coded LED lights that change from green to yellow to red for immediate reference to the measured parameter as well as an integrated three-digit display that reveals real-time operating conditions.
Boost
Oil Pressure
Transmission, Water or Oil Temperature gauge
Volt
Wideband UEGO and AEM Analog
AEM Tru-Boost Gauge and booster controller
The AEM Tru-Boost Boost Gauge/Controller combination is a multi-featured system for simplified, comprehensive boost control. Packaged within a 52mm gauge are a 29psi capable boost controller, peak-memory boost gauge, and many other great features. This unit includes black and silver bezels and black and white faceplates for simple color selection and easy matching to other AEM gauges (i.e. serial gauge, UEGO, etc.)
Features:
On-board pressure sensor included for boost levels up to 29 PSI
Peak boost memory
Selectable over boost alarm with overboost shutdown
Scaleable bar graph display
Selectable waste gate delay for quick turbo spool
Simple install harness allows for quick and easy installation
Boost hose and fittings included for easy hookup to on-board pressure sensor
Edge Insight CTS
Edge Products brings you the latest and greatest in performance electronics with the all new Edge Insight CS & CTS automotive monitoring system. Compatible with any OBD-II equipped car from 1996-present, the Insight connects directly to your vehicles ECU, allowing you to customize your Insight to display up to 8 simultaneous engine parameters at once, in full color and high resolution. View engine parameters such as oil/water temperature, boost pressure, intake air temperature, wastegate/fuel injector duty cycle & fuel pressure (parameters available vary depending on make and model). In addition to a full color gauge system, the Insight is also an ECU scanner with the ability to display Check Engine codes in full text and clear them if necessary. Also featured is a full on-board performance meter, able to measure and graph 0-60 times and 1/4 mile times. Insight CTS models feature an external video input, allowing you to view a standard RCA video source such as back up cameras, DVD players and camcorders. Get rid of those bulky and expensive analog gauge setups. The Edge Products Insight CS & CTS are the cutting edge gauge solutions for the next generation of performance cars.
Features:
Easy installation via included OBDII cable. No wiring!!
Full-Color, High-Resolution, 4.3 (CTS) or 2.4-inch Screen (CS)
Displays available SAE data from your vehicle’s computer
Touch screen or push button user interface.
View parameters in numeric or analog style gauge display
User-defined visual and audible alerts
Digital gauge display/scan tool (does not reprogram/tune the vehicle or add power)
Aux video in (CTS only) for use with back-up cameras or other video devices
Customizable background color and wallpaper using the included MyStyle software
On-board performance calculator (0-60 & 1/4 mile)
Got some STRI Gauges and pod options too.
PM for pricing!
X Line Series
Boost:
52mm and 60mm
Black Dial- Amber LED
White Dial- Amber LED
Smoke Lens- White LED
Smoke Lens- Amber LED
Vacuum:
52mm and 60mm
Water Temp:
52mm and 60mm
Oil Temp:
52mm and 60mm
Oil Pressure:
52mm and 60mm
Exhaust Temp:
52mm and 60mm
Tachometer:
52mm and 60mm
Voltmeter:
52mm and 60mm
Fuel Pressure:
52mm and 60mm
Digital Stepper Drive (DSD) Series:
Boost:
52mm and 60mm
Vacuum:
52mm and 60mm
Water temp:
52mm and 60mm
Oil Temp:
52mm and 60mm
Oil Pressure:
52mm and 60mm
Exhaust Temp:
52mm and 60mm
Tachometer:
52mm and 60mm
Volt:
52mm and 60mm
Fuel Pressure:
52mm and 60mm
  • Can also do combos like stri boost/oil pressure and innovate db red wideband!
  • ATI Pods, Autometer, Defi pods and Perrin cluster pods in stock!!
  • + More!
Zenesis Alarms:
We offer the best pricing possible on all Zenesis products. We will match or beat any price. ZN502's and ZN302's are always in stock so there is no down time. Shipping is always free.
Zenesis ZN502 Alarm/ Remote Start/ Turbo Timer w/ Zpass touch- 2xx.xx Shipped.
__________________
Best Pricing and Customer Service in the Business!
Shop Line: 603-715-9076
Hours:
Monday- Friday Closed weekends
9:00 AM to 5:00 PM at shop
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Open until midnight via website/email/internet
Your Forum Reps are Allen, and Jorel!
facebook us: "AJW Performance"
Follow some of our work-
AJW Performance is offline
Old 02-23-2011, 11:26 AM   #2
AJW Performance
Member#: 219896
In stock!
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 02-24-2011, 10:22 AM   #3
AJW Performance
Member#: 219896
Bump! Specials on Zenesis alarms through the day. PM for details
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 02-24-2011, 07:55 PM   #4
02bugeyerex
Member Sales Rating: (1)
Member#: 273893
how much are the red racer boost gauges and how much do they sell used
02bugeyerex is offline
Old 02-28-2011, 10:34 AM   #5
AJW Performance
Member#: 219896
Sending PM!
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 03-01-2011, 12:05 PM   #6
AJW Performance
Member#: 219896
Here for the day!
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 03-02-2011, 09:52 AM   #7
AJW Performance
Member#: 219896
Thanks for the orders!
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 03-03-2011, 11:22 AM   #8
AJW Performance
Member#: 219896
Defis here in stock!
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 03-04-2011, 11:09 AM   #9
AJW Performance
Member#: 219896
over 15 brands of gauges to choose from!
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 03-05-2011, 01:05 PM   #10
AJW Performance
Member#: 219896
Here Saturday in the shop! Let us know what youre looking for!
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 03-07-2011, 10:06 AM   #11
AJW Performance
Member#: 219896
Gauges in stock. Zenesis ZN202, 302 and 502 all in stock as well
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 03-08-2011, 11:30 AM   #12
AJW Performance
Member#: 219896
gauges in stock!
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 03-09-2011, 09:52 AM   #13
AJW Performance
Member#: 219896
Defi gauges in stock!
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 03-10-2011, 10:58 AM   #14
AJW Performance
Member#: 219896
Here for the day to help customers!
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 03-10-2011, 10:29 PM   #15
Anti Trust
Member#: 170256
2000 002.5rst-07wrx
blue
do you know exatly what the Edge Insight CTS
can read out on an 07 subaru wrx?
Anti Trust is offline
Old 03-11-2011, 11:05 AM   #16
AJW Performance
Member#: 219896
I havent seen one installed yet. Seeing that it uses the OBII port, where all of your cars data is accessed, I'm sure it can read quite a lot; Boost pressure, oil and water temps, EGT etc. Plus you can read any Check engine lights and clear them.
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 03-14-2011, 11:18 AM   #17
AJW Performance
Member#: 219896
Here for the day! Tons in stock, Zenesis remotes/alarms, Defi, STRI and ATI products in stock
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 03-15-2011, 11:00 AM   #18
AJW Performance
Member#: 219896
Lots of products here in stock! Let us know what youre looking for and well be sure to hook you up!!
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 03-16-2011, 10:02 AM   #19
AJW Performance
Member#: 219896
Defi, Autometer, STRI, Prosport, Greddy, AEM and so much more!
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 03-17-2011, 01:18 PM   #20
AJW Performance
Member#: 219896
Widebands in stock!
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 03-18-2011, 01:48 PM   #21
AJW Performance
Member#: 219896
replying to PM's now!
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 03-23-2011, 10:12 AM   #22
AJW Performance
Member#: 219896
Many items in stock, PM us for combo pricing for a package deal!
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 03-23-2011, 08:35 PM   #23
cessna152
Member Sales Rating: (5)
Member#: 7523
1999 Impreza 2.5 RS
Sent ya a PM
cessna152 is offline
Old 03-24-2011, 09:45 AM   #24
AJW Performance
Member#: 219896
ok checking now
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 03-25-2011, 10:53 AM   #25
AJW Performance
Member#: 219896
Here all day helping customers online while we do several strut/ coilover installations today. PM for pricing!
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Closed Thread
Zenesis Alarms, ati pods, stri electronics and a whole bunch of other cool items! IMPORTIMAGE Interior/Dressup/Audio & Security 703 08-20-2011 10:02 AM
FS : Zerosports gauge pod / 2 defi gauges / 1 aem gauge Blee Interior/Dressup/Audio & Security 33 10-25-2010 03:11 PM
New Year, More great deals on Cobb/AEM/Perrin/APS/DBA/Invidia and more @ Slowboy! Built Industries Engine/Power/Exhaust 151 04-29-2009 08:24 PM
Zenesis alarms, Defi, STRI, Aem, Navman, Autometer, and so much more! IMPORTIMAGE Interior/Dressup/Audio & Security 96 08-06-2008 06:01 PM
