Old 02-21-2011, 01:33 PM   #1
subadrew99
Member#: 204755
Default Coolant Leak Help Please
Hey,
I woke up to a nice pool of coolant underneath my 1998 Impreza 2.5 RS. I can't quite tell what is leaking but it's seems to be near the closer to the driver's side of the water pump and not the hose that goes to the engine but the little elbow peice that's in there. Not exactly sure what that is so i'm hoping possible the gasket in there and not something more major. Seems to be wet above this as well... hoping it's not the head gasket...
See the attached photo.
Any suggestions would be greatly appreciated.
subadrew99 is offline   Reply With Quote
Old 02-21-2011, 01:34 PM   #2
subadrew99
Member#: 204755
Since the attachment didn't work
http://s1232.photobucket.com/albums/ff364/Subadrew98/?action=view&current=IMG_0428.jpg
Old 02-21-2011, 02:10 PM   #3
Jessekrs123
Member#: 236927
2015 BRZ, 93 Legacy,
1984 BRAT
How many miles on the car?
Perhaps it's time to replace the water pump and the gasket.
Jessekrs123 is offline   Reply With Quote
Old 02-21-2011, 02:16 PM   #4
subadrew99
Member#: 204755
i'm hoping it isn't that. They were replaced 50000 km (31000 miles) ago. Around the base of the water pump seems dry but to the side seems a bit wet. I can't tell if it may just be the gasket in that elbow and it's spraying out and up and making a huge mess or if the leak come from higher. Is the elbow simply an elbow or does it have some higher purpose?
Old 02-21-2011, 02:21 PM   #5
Jessekrs123
Member#: 236927
1984 BRAT
It just connects to the lower rad hose. Maybe your hose is cracked, I would inspect the hose around the elbow there.
Old 02-21-2011, 02:29 PM   #6
subadrew99
Member#: 204755
Hose was the first thing i checked and unfortunately the hose is dry, except from some leak from above. I wiped it dry and came back and the hose didn't having any drip just that elbow. Do you know if there is a gasket in the elbow that can go?
Old 02-21-2011, 04:26 PM   #7
subadrew99
Member#: 204755
so i've determined it was definitely leaking from where the plastic elbow and the water pump meet. is there anyway to test and see if my water pump has failed?
Old 02-21-2011, 04:50 PM   #8
subadrew99
Member#: 204755
just made the lovely discovery that the gasket is firmly integrated into the water pump... anyway to replace it? or is this a sure sign the water pump is pooched?
Old 02-21-2011, 05:27 PM   #9
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
With luck it's just the thermostat gasket, but it looks to me more like your water pump is leaking externally.
BAN SUVS is offline   Reply With Quote
Old 02-21-2011, 09:46 PM   #10
subadrew99
Member#: 204755
Yeah i replaced the thermostat gasket and i've run it a bunch and drove it around and it seems fine. They guys at the dealer seemed sure that it would do the trick. We'll see if i get any surprises tomorrow morning. Thanks for the suggestions.
Old 02-23-2011, 08:47 AM   #11
scramble1028
Member#: 270856
2000 Impreza 2.5 RS
Default cracked raiditor
hey guys, i belive i have a hairline crack in my raditor on the bottom i was looking for any hits, tips or tricks to a nice easy problemless swap for my new raiditor on my 2000 2.5 rs. thank for the help any is appricated.
scramble1028 is offline   Reply With Quote
Old 02-23-2011, 07:16 PM   #12
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
So you have a new radiator ready to go in or ?? If you do, its pretty straight forward.
No Boost & Coolant Leak - HELP kyoung05 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 07-07-2008 01:26 PM
Hidden 2002 coolant leak, help! larslarsen Newbies & FAQs 17 01-03-2008 07:14 PM
coolant leak help Chuck H Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-27-2005 10:25 AM
Coolant leak help Stanley Service & Maintenance 1 08-08-2005 07:14 PM
turbo coolant leak...HELP! (pictures inside) nottheliving Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 11-04-2004 05:18 PM
