Welcome to the North American Subaru Impreza Owners Club Tuesday September 1, 2015
Old 05-17-2013, 02:07 PM   #1
RavensFan7
Member#: 346388
2001 Ej205 Impreza L
SRP
I've got a loud "womp womp womp" noise as I drive. It gets louder the faster you go. It's not the wheel bearings, they were all replaced recently.
If I run my hand along the tires, I can almost feel a jagged-ness to them? I'm not sure if that's the right word but I have pictures to explain.
Here is my tire. Obviously my iPhone pics won't show the wear (see next picture):
Here is the same angle of a tire, but a (bad) drawing of what it feels like.
It's a little exaggerated but you get the point.
All 4 tires are like this, but one is especially bad.
Is this something I should take care of soon? It just seems like bad wear, and it'll just be noisy until I get new tires.
....unless its a broken tire belt?
Although it wouldn't make sense that all 4 tires have random broken belts.
RavensFan7 is offline   Reply With Quote
Old 05-17-2013, 03:51 PM   #2
JonnyV2889
Member#: 197384
2006 WRX Ltd
Feathering. If you did all 4 wheel bearings it's probably a worn bushing or bad struts with that age.
JonnyV2889 is offline   Reply With Quote
Old 05-17-2013, 05:08 PM   #3
RavensFan7
Member#: 346388
SRP
Struts seem fine although old, and there are still some bushings I haven't replaced/upgraded yet....so I guess that's possible.
...but the tires on my steelies from before I got my new wheels, are fine. Same with my winter tires I just took off. No "feathering".
Could it have been an alignment issue that over time made them wear like that?
I started hearing the noise when these (summer) tires were put back on a couple weeks ago. The noise could have been present last summer/fall but I wouldn't have noticed it, due to the loud dying wheel bearings.
They still have a decent amount of tread left too.
-_-
Old 05-17-2013, 05:28 PM   #4
iforgettopee
Member#: 329139
2013 WRX
i say get your alignment checked - its free to check at most shops
my tires ended up like that on my last car because i couldnt get toe alignment within spec
camber usually doesnt cause feathering... my guess is your toe alignment
iforgettopee is offline   Reply With Quote
Old 05-17-2013, 05:51 PM   #5
RavensFan7
Member#: 346388
SRP
Just had an alignment last week after the rear wheel bearings were replaced.
Obviously no way of knowing if it was a previous alignment now. A toe issue would make sense too....
It's gonna be a loooonnngg summer/fall with these noisy tires
Old 05-17-2013, 07:48 PM   #6
iforgettopee
Member#: 329139
2013 WRX
just do some donuts!
Old 05-17-2013, 07:58 PM   #7
RavensFan7
Member#: 346388
SRP
Edit: no?
