Old 07-12-2002, 04:16 PM   #1
Reflex-Arc
Lord of the Gilf
Member#: 1703
2012 Fiat 500 Sport
Copper
Default What could be causing my "ping"?
First of all, I'm only assuming that's what I'm hearing. It sounds a bit like gravel in an empty coffee can.
It's only happens under load (like when going up hill) and it seems to happen almost exactly at 2500 rpm. Is this normal? Should I just be in a lower gear?
I've got fairly basic engine mods; ganflow intake, K&N filter, and a brullen 2.25 catback. I've also switched plugs to the NGKs that are so popularly reccomended here, if that makes a difference. Could any of these mods cause this?
I typically run 89 octane gas. The sound seems worse on the 87 and the car seems to idle rough on the 92 octane. Though I do have to say that the sound is less noticable on the 92, still there but not as often.
So what do you think? Am I just being an automotive hypochondriac n00b, or does it sound like I have a mechanical issue here.
Reflex-Arc is offline   Reply With Quote
Old 07-12-2002, 04:40 PM   #2
grubaru
Member#: 5788
What I can't pay for
my own shrimp?
The sound is different with different octanes? I would think that it's engine knock. Are all of your upgrades fastened securely? Where exectly are you hearing this ping? Under the hood? Under you? Towards the back of the car?
grubaru is offline   Reply With Quote
Old 07-12-2002, 04:48 PM   #3
Reflex-Arc
Lord of the Gilf
Member#: 1703
2012 Fiat 500 Sport
Copper
I'm assuming that it's coming from under the hood, but honestly I cant be 100% positive on that because I can't duplicate the sound while the car is parked. That's kind of why I don't think its any of my mods vibrating.
Edit: It kind of sounds like a spray paint can being shaken.
Old 07-12-2002, 04:49 PM   #4
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Maybe you have alot of carbon crap built up that is causing preignition.
Old 07-12-2002, 04:52 PM   #5
Reflex-Arc
Lord of the Gilf
Member#: 1703
2012 Fiat 500 Sport
Copper
Could be.
But I recently ran a bottle of Chevron's FI cleaner through. Should I give that another shot?
Old 07-12-2002, 07:06 PM   #6
HudsoN456
Member#: 11462
1999 Integra GS-R
Super Sonic Blue Pearl
Don't worry, it's normal. I get it too, and I've tested other RS's who have the same thing. Octane doesn't make a difference for me, it will happen like clockwork if I'm going up a hill in too high of a gear. Don't sweat it, just downshift.
HudsoN456 is offline   Reply With Quote
Old 07-12-2002, 07:19 PM   #7
Reflex-Arc
Lord of the Gilf
Member#: 1703
2012 Fiat 500 Sport
Copper
Fair enough! Thanks for the info.
Old 07-12-2002, 10:21 PM   #8
Jademonkey
Member#: 9213
2000 RS
Red
Damn, I though I was the only one. I was going nutts over trying to get this fixed. I de modded my car, ran 91 gas for 2 weeks, and still the same noise.
My brother listened to it, and he said it's not "engine ping."
I also had a ****load of pebbles between my cat and shielding. That cut the noise down a lot...but my symptoms are the same...this rattling/buzzing noise at a specific RPM. I imagine there is something on our cars, which loves to vibrate at a certain frequency...
Jademonkey is offline   Reply With Quote
Old 07-13-2002, 03:26 AM   #9
djinn1973
Member#: 18596
1995 Impreza
That strange blue colour.
I would atleast get it checked out, also if it happens going only up hill maybe have the axel shafts checked?
djinn1973 is offline   Reply With Quote
What could be causing my engine stalling? anthonywrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 12-05-2007 05:47 PM
what could be causing this? gizmodude311 Transmission (AT/MT) & Driveline 18 01-05-2007 10:46 PM
Hmm, so what could be causing this? JayD707 Brakes, Steering & Suspension 5 07-28-2006 05:27 PM
CEL? stock WRX with 300 miles, what could be causing it? Louros Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-29-2004 12:14 PM
flashing cel with utec, what could be causing it? datdudedennis Engine Management & Tuning 7 04-07-2003 05:16 PM
