Old 02-21-2011, 08:05 PM   #1
me_and_my_wrx
Member#: 45198
'07 Outback
Default Easiest way to remove engine?
I have a 2000 Outback with a SOHC EJ25 and an auto transmission with 165k miles on the clock. It has started leaking oil at the headgaskets and is dripping on my exhaust manifold causing a horrible smell.
I'm going to pull the engine and reseal everything but have never pulled the engine on these cars. I have removed the engine on other cars, and have done timing belts and clutches on subarus before.
Does anyone have a write up or a quick FAQ for me to follow?
Do I pull it out the bottom, or raise from the top? I'm just looking for the high points on how to make it easy.
Thanks,
me_and_my_wrx is offline   Reply With Quote
Old 02-21-2011, 08:32 PM   #2
Wrencher86
Member#: 250463
2010 Impreza 2.5i
Torch.
Should come out like any other engine. Unplug and unbolt everything attached to the car or the transmission (leave the A/C compressor and the power steering pump in the car), support the trans and yank forward and up. The only real difference between pulling engines in manual cars and automatics is a little more wiring and having to unbolt the torque converter from the flexplate.
Wrencher86 is offline   Reply With Quote
Old 02-21-2011, 08:40 PM   #3
Jessekrs123
Member#: 236927
2015 BRZ, 93 Legacy,
1984 BRAT
Drain the ATF first.
Jessekrs123 is offline   Reply With Quote
Old 02-22-2011, 06:52 PM   #4
T Wrex--OH
Member#: 179478
2000 Impreza 2.5 RS
Sedona Red Pearl
Originally Posted by Wrencher86 View Post
Torch.
Why in the world would you need a torch??
Anyways, O.P., I got just what you're looking for:
http://www.rs25.com/forums/f105/t632...e-removal.html
If you can't remove the engine using that thread, then you suck.
T Wrex--OH is offline   Reply With Quote
Old 02-22-2011, 07:05 PM   #5
Wrencher86
Member#: 250463
2010 Impreza 2.5i
He asked for the easiest way to remove an engine. Not the best way.
It was a smartass comment meant as a joke. Hence my, hopefully, useful information below it.
Old 02-22-2011, 07:42 PM   #6
T Wrex--OH
Member#: 179478
2000 Impreza 2.5 RS
Sedona Red Pearl
Oh, sorry my sarcasm meter went whack for a minute. Haha
Definetely about the Torque converter. Don't know if the thread I posted mentions that as it's done on a manual car.
Old 02-23-2011, 05:27 AM   #7
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Torch.
Friggen noobs, both of you
Dynamite is WAY faster than a torch. There's even a little access cover right on top of the bellhousing for you to drop it into.
Real answer? It's pretty easy on a Subaru. The only thing that typically is a bitch is getting the engine to let go of the tranny if they've been mated more than a couple of years. You'll need to start pounding razor blades, then putty knives, then screwdrivers between the tranny bellhousing and the engine. Try to keep the gap even left to right by where you jam the tools and try to keep it even top to bottom by how much you're lifting it with the hoist (lifting higher will close the top and open the bottom). A 3 foot long flathead screwdriver will help immensely because you can stick it through the gap and use it to directly force open the bottom of join by hitting it with a hammer chisel-style.
Old 02-24-2011, 11:33 AM   #8
me_and_my_wrx
Member#: 45198
'07 Outback
Thanks for the answers, even the smart ass ones.
T Wrex- that FAQ is just what I was looking for.
Thanks all.
Old 02-24-2011, 09:33 PM   #9
haze89
Member#: 275036
best way is from the bottom
haze89 is offline   Reply With Quote
Old 02-24-2011, 10:09 PM   #10
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Not even close. Not on a Subaru unless you're planning on taking the engine, transmission, entire front suspension, and front crossmember out as one big chunk.
Old 02-24-2011, 11:06 PM   #11
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
thats what she said
Old 02-24-2011, 11:59 PM   #12
Back Road Runner
Member#: 60082
2004 Forester STI
I was thinking explosives but whatever...
Why the heck would you want to go out the bottom?! Haha!
Old 02-25-2011, 12:06 AM   #13
Wrencher86
Member#: 250463
2010 Impreza 2.5i
What the hell?
Old 02-25-2011, 05:42 PM   #14
ocei77
Member#: 119726
easiest way to separate block from tranny is to use a bottle jac. 2x4 on firewall and jack against block. Pump and it'll break free w/o a lot of abusive language .
O.
ocei77 is offline   Reply With Quote
Old 02-25-2011, 06:56 PM   #15
wrxsubaru
Member#: 65133
I usually just pull the engine and transmission at the same time. It can be a huge pain in the ass to separate the two and get them back together when its in the car, much easier out of the car.
wrxsubaru is offline   Reply With Quote
Easiest way to remove rear axles from R180? 2005 Transmission (AT/MT) & Driveline 8 03-13-2007 05:27 PM
easiest way to remove tint? citra Interior & Exterior Modification 4 05-10-2005 03:43 PM
Quickest Easiest Way to remove all PINK! austin25 Interior & Exterior Modification 33 07-01-2004 08:49 AM
Easiest way to remove 3rd brake light WRooster Bay Area Impreza Club Forum -- BAIC 4 06-03-2003 11:13 PM
Easiest way to remove lighter socket? mmm3587 Car Audio, Video & Security 3 04-11-2002 12:55 AM
