Old 02-21-2011, 09:24 PM   #1
can'tread503
Member#: 187181
93 maroon impreza
maroon
Default rer main seal problem
ok so i recently just put a 22e in my 93 impreza and put my buddies act lightweight flywheel in my car that he had in his 07 impreza 2.5i to get to the point i have replace 2 rear main seals in the past 2 weeks cuz they keep leaking oil could the flywheel be doing this cuz i never had this problem unil i put the flywheel in and my clutch keeps slipping i bought a new clutch and had the flywheel resurfaced.
can'tread503 is offline   Reply With Quote
Old 02-21-2011, 10:18 PM   #2
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
chief your clutch is probably slipping because the main seal is leaking oil on it
olsen726 is offline   Reply With Quote
Old 02-21-2011, 11:42 PM   #3
Wrencher86
Member#: 250463
2010 Impreza 2.5i
Did you build the engine? What's your end play on the crankshaft? Did you put the right thrust bearing in?
If the crankshaft is moving back and forth more than it should it can roll the seal out.
Wrencher86 is offline   Reply With Quote
Old 02-22-2011, 09:24 AM   #4
Storm
Member#: 5218
96L Most Over-
Developed Beater
I'd be more concerned with the condition of the crank and/or installation method.
If the crank has a burr on it, it'll just tear a perfectly good seal in no time. If you drive the seal in too far, it can (will) leak. A deep groove worn in the crank will also fail to seal.
Jay
Old 02-22-2011, 01:21 PM   #5
renob123
Member#: 41986
'06 STI/'85 Brat
I was thinking this as well. I'm not sure if you do your work yourself, but a friend of mine in West Linn does this sort of thing all the time in his shop. PM me if you want to give him a try.
Jacob
renob123 is offline   Reply With Quote
Possible problems with rear main seal install cdigerlando Service & Maintenance 5 01-13-2011 02:53 PM
Rear Main Seal problem rivman05 Service & Maintenance 2 12-01-2007 08:02 AM
Replaced front main seal and oil pump o-ring archer Normally Aspirated Powertrain 4 12-28-2001 03:28 AM
('93-'01) Rear main seal gone - 650kms? Help! JNaubur Impreza Forum 6 05-25-2001 12:29 AM
Front main seal, timing belts -oil pump&water pump? immortal_suby SVX Forum Archive 3 06-25-2000 07:15 PM
