Old 02-22-2011, 12:56 PM   #1
JT99
Member#: 177036
1999 OBS
Green
Question Intake Manifold Interchangibility Question...
I have a phase II EJ22 car that is MAF. I'm working on a drop-in motor and need to pick up an extra IM to simplify the switch. Phase II EJ22 intake manifolds aren't the most plentiful, but some places list SOHC phase II EJ25 IMs as fitting my car too. Is that a typo or will a SOHC EJ25 IM fit phase II EJ22 heads?
I know DOHC IM is a completely different animal, but I have never had any parts from a SOHC 2.5 in my hands.
Anybody know for a fact that a SOHC EJ25 IM will or will not work with EJ22 heads?
JT99 is offline   Reply With Quote
Old 02-22-2011, 03:44 PM   #2
grafton
Member#: 187936
97 Legacy w12:1CR
05 LL Bean outback
useless post/answer:
they should match, but I don't have a sohc 2.5 to look at to double check though
grafton is offline   Reply With Quote
Old 02-22-2011, 07:49 PM   #3
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
All the phase II NA manifolds are compatible.
BAN SUVS is offline   Reply With Quote
Old 02-22-2011, 08:36 PM   #4
RaceFaceXC
Member#: 165749
2007 No YELLING
on the bus!
05+ are superior design, but might be harder to come by.
RaceFaceXC is offline   Reply With Quote
Old 02-22-2011, 09:55 PM   #5
JT99
Member#: 177036
1999 OBS
Green
Well that is certainly helpful information. Being MAF doesn't matter?
So what's the deal with the plastic IM? Is it an option as well for me?
Thanks for the replies.
Old 02-22-2011, 10:19 PM   #6
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
You'll want to find a '99 RS manifold to keep things simple.
Old 02-23-2011, 06:21 AM   #7
Storm
Member#: 5218
96L Most Over-
Developed Beater
As said earlier, the phase II stuff will interchange. The plastic piece will bolt on, but needs modded for cable throttle body. The 05+ manifold is the same way but needs some other work too.
I've got a manifold that'll work for ya hangin in the garage if you're interested.
Jay
Old 02-23-2011, 10:23 PM   #8
JT99
Member#: 177036
1999 OBS
Green
Yeah, I just want a straight bolt-on that requires no modding.
Does your IM still have the fuel rails on it? What are you asking for it? Are you needing any misc. parts yourself?
Jay
Old 02-24-2011, 07:09 PM   #9
Storm
Member#: 5218
96L Most Over-
Developed Beater
Still has the rails but the injectors are not in. I could use a rust free rear subframe or a phase II EJ25 crankshaft that doesn't need machined.....
Old 02-25-2011, 09:13 AM   #10
JT99
Member#: 177036
1999 OBS
Green
I have a 2000 OBS shell from South Carolina waiting to have the underneath pulled off...but I won't be getting to that any time before July. You're more than welcome to come to KY with a wrench and a can of PB Blaster.
Old 02-25-2011, 06:24 PM   #11
Storm
Member#: 5218
96L Most Over-
Developed Beater
Tempting....but nah.
PM me if you'd like to talk price and contact info. I'm not out to screw anyone price wise.
Jay
Old 05-21-2011, 03:30 PM   #12
ryden
Member#: 201489
1997 OBS
Metalic Matt Black
i have a 97 obs and have a ej25 intake manifold laying around. i dont what year or phase but i see you guys said that if its phase II like my obs that it would bolt up. but would it actually do anything performace wise or just a waste of time?
ryden is offline   Reply With Quote
Old 05-23-2011, 01:26 PM   #13
ryden
Member#: 201489
1997 OBS
Metalic Matt Black
anyone have any ansers for this?
Old 05-24-2011, 12:34 AM   #14
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
It will not make any difference whatsoever to performance. Really, nothing will other than cams, header, headwork, and higher compression plus tuning. Nothing on the intake side is necessary until you really start building.
Old 05-24-2011, 02:10 AM   #15
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD) / 87 GL
how will getting a new intake manifold simplify the swap?
it takes minutes (~10 of them) to swap intake manifolds between motors. Leave everything on it (coil, wires, vacuum lines, fuel stuff) and just undo the 8 bolts. Replace the gaskets, away you go.
then you won't have to worry about a plug being different or anything like that.
<<<--- swapped 99 ej22 with 2003 ej25 using original manifold/wiring.
Zefy is offline   Reply With Quote
Will EJ22 and EJ25 Intake Manifolds Interchange??? JT99 Subaru Conversions 6 07-04-2008 01:33 PM
04 STI Intake Manifold Interchangable? jayfressh Subaru Conversions 2 04-02-2006 10:11 PM
Intake Manifold compatibility question. Unsung Boxer Normally Aspirated with bolt-on Forced Induction Powertrain 9 01-18-2004 01:25 AM
WRX intake manifold/TB question black knight Factory 2.0L Turbo Powertrain 1 04-20-2003 10:58 AM
Intake Manifold Reversal Question WRX34 Factory 2.0L Turbo Powertrain 6 02-14-2003 01:50 PM
Message Board Statistics All times are GMT -4. The time now is 09:35 PM.
