Old 02-22-2011, 07:00 PM   #1
silverongold
Member#: 132599
02 impreza wrx
Default help with misfire!
so i am getting a misfire code for all four cylinders. i thought it was bad e 85 over the winter fowling my plugs. they did not look bad but i changed the plugs any way. now it came on again and i have put fuel system cleaner in my tank to see if that would fix a clog or some thing. if that does not do any thing in the next twenty miles or so what would it most likely be? bad coil pack?
thanks
silverongold is offline   Reply With Quote
Old 02-23-2011, 01:20 AM   #2
silverongold
Member#: 132599
02 impreza wrx
any help?
Old 02-23-2011, 01:56 AM   #3
tomtom84
Member#: 167794
08 STI 6266 e85 DD
91 miata and 71 porsche
that wouldn't make it misfire on all 4 cylinders.
does it knock?
do you have a good line to your fuel pressure regulator?
what are you doing when it misfires? are you at idle or WOT?
I suggest a compression test just for fun since you are pulling all the plugs.
tomtom84 is offline   Reply With Quote
Old 02-23-2011, 02:31 AM   #4
silverongold
Member#: 132599
02 impreza wrx
it is missing under regular driving or idle i have been taking it easy cause i dont' know what is up. no knock that i can tell. line should be good to regulator every thing in the bay has been replaces with the aps fuel kit. before the engine bay is stock lines though
Old 02-23-2011, 11:57 AM   #5
tomtom84
Member#: 167794
08 STI 6266 e85 DD
confirm that.
and check with your tuner.
Help with a nasty squeak gregsatt Texas Impreza Club Forum -- TXIC 6 02-23-2011 12:57 PM
help with misfires near Plattsburgh NY? foxboroxt Tri-State Area Forum 7 06-07-2009 01:54 AM
Help with misfires beauhawk Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 04-09-2007 08:18 PM
HELP!! Problems with misfires... Greenracer6 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-10-2003 05:47 PM
Help me with misfires at idle rak328 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-29-2002 08:38 PM
