Old 02-23-2011, 01:41 AM   #1
normc
Member#: 274213
2011 Impreza 2.5 AT
Default Question on New Car - engine idle/rough? - what can I expect from 2.5L new engine?
Hi I purchased a new 2011 Subarau Impreza 2011 2.5L automatic, and I'm new to the subaru's does the engine idle rough? (but they drove it 2 hours delivered to my local dealer) so it had 180 miles already -- plus whatever test drive miles were already put into it. (where it came from it snows occasionally don't know if they warmed up car..learned after)
Example this evening 52 deg .. start engine, while waiting for the little BLUE TEMP indicator to disappear the engine idled really rough, shakes-some point sounds as though engine starts to choke/die ..just slighly tho, ... then after warm up less rough, but still idles rough - my old 2000 jetta VR6 idles rough but after warm up sounds more smooth? This one idles just less rough.. . Could be engine design of subie I don't know?
What can I expect from a new Subaru engine?
I'm quite new to the forum and subaru's ... probably should goto another dealership test drive another car to check? But off hand just wondering.
Thanks
normc is offline   Reply With Quote
Old 02-23-2011, 06:21 AM   #2
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
They do tend to shake a little bit more than many other engine types. However, any uneven-ness (I guess) in the the pattern of the engine is probably not right. I mean if it constantly does the same thing without any variation but it's just a lot of vibration, you're probably good. However, if you get shake-shake-shake-pause-SHAKE-shake-shake or something like that, that's no good.
Old 02-23-2011, 08:27 AM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
take it back to the dealer and tell them that you are having this issue
it may be as simple as bad gas
Old 02-24-2011, 11:15 AM   #4
kero
Member#: 94299
2000 2.5 RS Sedan
SRP
Hmm, I always found the 2.5 NA engines to idle smooth as a babys ass, after my uel exhaust setup, she idles rough but before that, it was hard to tell the car was even running most of the times.
kero is offline   Reply With Quote
Old 02-24-2011, 12:57 PM   #5
Rudgers73
Member#: 141433
2006 Impreza 2.5i
Obsidian Black
I have noticed with my last 2 Subarus that after a highway run if you are at a light the idle will be a little rough. I actually recall reading a review about the Impreza when I was first shopping for one that mentioned rough idle.
Rudgers73 is offline   Reply With Quote
Old 02-24-2011, 01:24 PM   #6
bradyarz
Member#: 272381
2008 Impreza OBS
Originally Posted by normc View Post
...but they drove it 2 hours delivered to my local dealer) so it had 180 miles already ...
that's some fast driving on a brand new engine.
bradyarz is offline   Reply With Quote
Old 02-24-2011, 01:54 PM   #7
Rudgers73
Member#: 141433
2006 Impreza 2.5i
Obsidian Black
4200 RPMS for 2 hrs! poor car...
Old 02-27-2011, 03:15 AM   #8
cbigbie191
Member#: 275192
My last two Subaru's would idle a bit rough, but after 2k miles or so and especially after the first oil change they both smoothed out nicely.
cbigbie191 is offline   Reply With Quote
Old 03-01-2011, 01:17 PM   #9
connorlug
Member#: 275276
2007 FXT
CGM
I would either say its bad gas or maybe a faulty 02 sensor? I need a new 02 sensor and it makes the car idle rough
connorlug is offline   Reply With Quote
Old 03-01-2011, 01:59 PM   #10
T Wrex--OH
Member#: 179478
2000 Impreza 2.5 RS
Sedona Red Pearl
IMO it's most likley in your head and there is no problem at all.
Boxers idle lumpy compared to straight or v-engines. At least every boxer that I've seen idling.
T Wrex--OH is offline   Reply With Quote
Old 03-02-2011, 03:55 AM   #11
LonelyHiker
Member#: 253173
2010 Impreza
A 4 cylinder boxer is a balanced engine (like a straight 6) but the firing pulses are quite noticeable. 4-cyl boxers come with a somewhat heavy flywheel to offset this, but there will still be a bit of a pulsation that you might not notice with other engine types. As long as the pulses are smooth and consistent, it's probably normal. If they are rough or the engine is shaking, that might not be good. Keep an eye on it. My 2010 didn't have any roughness when new.
LonelyHiker is offline   Reply With Quote
Old 03-02-2011, 10:30 PM   #12
T Wrex--OH
Member#: 179478
2000 Impreza 2.5 RS
Sedona Red Pearl
Not to nit-pick, but the H4 doesn't have the same, one piston goes up as another goes down, balance as the straight six's. Now, on the other hand, the H6 Subaru engines do.
Old 03-03-2011, 12:27 AM   #13
renyo
Member#: 93577
98 Impreza
Yes it does.
It isn't balanced in a sense it wants to vibrate around an axis going through the top of the engine...
renyo is offline   Reply With Quote
Old 03-03-2011, 01:20 AM   #14
T Wrex--OH
Member#: 179478
2000 Impreza 2.5 RS
Sedona Red Pearl
Last edited by T Wrex--OH; 03-03-2011 at 01:34 AM. Reason: Not trying to start a pissing match
Old 03-05-2011, 12:50 PM   #15
impreza25i
Member#: 275887
Yea, it always shakes =/
impreza25i is offline   Reply With Quote
Old 03-05-2011, 11:23 PM   #16
djinn
Member#: 212818
2010 Impreza 2.5i
Satin White Pearl
Does it Idle rough then smooth after warming up?
djinn is offline   Reply With Quote
What can i expect from these mods???? nutzkicker617 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-16-2006 11:06 PM
what can i expect from ss line? newbie sewbie Brakes, Steering & Suspension 1 08-08-2002 01:12 AM
What can I expect from the snorkus removal, and... gtguy Normally Aspirated Powertrain 8 04-18-2001 10:08 AM
OK, Scoobie fans, what can I expect from the WRX? (long) droideka General Forum Archive 8 02-18-2001 04:36 PM
so what can i expect from my 20mm rear sway bar install? kid22 Technical Forum Archive 20 07-25-2000 09:16 AM
