Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 04-25-2013, 06:49 PM   #26
bkruelle
Member#: 279027
2011 WRX
I have an 11 wrx with spt catback, invidia catless dp, aem CAI, perrin ebcs, cobb ap and turbotek tune to 20psi.. I also have the flutter..
Ive been reading up and if u have an adjustable wg actuater arm u can tighten it between 1.5-3 turns and it will actuallt make the spring preload a bit stiffer to keep the wG shut. People say it takes almost all the flutter away and ull actuall build boost faster. I'm not sure if we have an adj arm on our year models but i will b looking at that tomorrow to see if i can fix the flutter.if it gets rid of the noise i will check back in here to let everyone knw if there was success or if it's jst bs...
bkruelle is offline   Reply With Quote
Old 04-25-2013, 07:00 PM   #27
RoadKillDMD
Member#: 284792
2011 STI
Blurple
Do not touch your WG actuator arm! This fix is only true on older models. It won't fix anything on your car. Besides, WG flutter is totally, completely, 100% NORMAL. If you want there to be no flutter, you'll need to run a MBC setup.
RoadKillDMD is offline   Reply With Quote
Old 04-25-2013, 08:32 PM   #28
bkruelle
Member#: 279027
2011 WRX
Damn ok.. Thanks for the knowledge and reply.. I will not be doing this then.
I am hitting my target boost of 20 psi at 3500-5000 then it holds 19psi till 6k and tapers to 15 at redline.. Nothing seems to be wrong in the data logs either.
So if all those things r cool i guess there isn't a problem with the flutter besides an annoying sound
Old 04-25-2013, 10:46 PM   #29
eronenris
Member#: 262992
2009 WRX - Stage 2
Satin White Pearl
https://www.youtube.com/watch?featur...&v=zFHFcYpuPrk
is this the noise you are hearing?
according to cobb and my tuner buddy, this is wastegate flutter and is completely normal at higher elevations. i can be solved by installing a lower wastegate duty cycle map.
eronenris is offline   Reply With Quote
Old 04-26-2013, 09:28 AM   #30
ScoobyTed
Member#: 313317
2012 WRX Hatch
First video is the wastegate opening and closing.
Second video is that throttle body - intercooler hose whistle that a bunch of the 12's and 13's have. Just have to tighten the hose or change to better clamps.
ScoobyTed is offline   Reply With Quote
Old 04-26-2013, 10:21 AM   #31
ringlander
Member#: 336100
2011 sti
How do you like your amr tune? Did you bring it to them or is it an e tune?
ringlander is offline   Reply With Quote
Old 04-26-2013, 11:47 AM   #32
Shayhan27
Member#: 205906
05 WRX
CGM
I had this same problem on my 05 WRX.
This may not fit but mine was more like a surge. like the wastegate was opening slightly at WOT in the upper RPM range.
The culprit for me was running a K&N typhoon on a cobb OTS stage 2 map. It did not like the intake. When I went back to stock intake it fixed the problem.
Try going back to stock and resetting. See if that fixes ya. I always try to cover the ABC's before I get into doing crazy stuff.
Shayhan27 is offline   Reply With Quote
Old 04-27-2013, 08:59 PM   #33
hutch959
Member#: 267463
the cha, cha, cha.... under heavy load around 3500 is compressor surge...
for what its worth, my etune did it.
my protune does not.
its not good for the turbo.
hutch959 is offline   Reply With Quote
Old 04-28-2013, 11:27 PM   #34
SlimJim8804
Member#: 241943
2065 Magic Carpet
Swirl Rally Bleu
^^^ This
SlimJim8804 is offline   Reply With Quote
Old 04-29-2013, 03:11 PM   #35
colby1321
Member#: 267408
08 WRX Sedan
VF 52'd Satin White Pearl
Originally Posted by revin9k View Post
i'm having the same problem so i captured this video. its tough to hear but around 7sec is WOT in 3rd and 10seconds is a WOT in 4th gear.
2011 STI weird spool sound - YouTube
normal?
I have the same sound on my 08. I have vf 52 stage 2 with full exhaust and high flow cat, GS EBCS. I hear the same sound while under heavy acceleration, or WOT and have talked to eric minehart of TP, since I have his tune, and he said everything in the log looked great. I've just grown to accept the noise since I cannot find out the cause of it. I dont quite remember when it started happening. I would love to find out the noise and stop it from happening again.
colby1321 is offline   Reply With Quote
Old 04-29-2013, 09:00 PM   #36
hutch959
Member#: 267463
i dont think you would see it in the logs... but i may be wrong.
i know the data from my aem failsafe showed the boost rising and then 3 little hiccups in the boost (the surge).
Old 04-29-2013, 09:08 PM   #37
jpatt006
Member#: 289470
2010 Forester XT
Compressor surge occurs off throttle.
The cha cha cha sound you are hearing under heavy load is most likely wastegate flutter and is normal.
jpatt006 is offline   Reply With Quote
Old 04-29-2013, 09:33 PM   #38
McKenzie83
Member#: 207896
11 STi limited
Default assuming that we're talking about WOT and not after you let off the throttle...
The flutter is the 3 port EBCS helping the car to build boost...it is also more importantly the IWG's lack of ability to hold boost much over stock PSI so the 3 port pulses in order to hold it shut... I also read that you are running a catless DP which invites boost spiking...I would be more fearful of not hearing this flutter than I would of hearing it. Anyone who even begins to assume that this condition is bad is filling your head with nonsense... An EWG will hold boost more solidly but will still crack open to control boost from going beyond target PSI (unless something is wrong)
McKenzie83 is offline   Reply With Quote
Old 05-01-2013, 09:36 PM   #39
colby1321
Member#: 267408
08 WRX Sedan
Thank you! I believe I started to hear it on mine during wot after i installed the 3 port ebcs.
Old 12-22-2014, 06:06 PM   #40
Panda915
Member#: 409141
2013 Imprezza STI
Orange
Default Same noise
I have a 13 STI and I noticed the same noise, this is my first Turbo, and I recently started getting the CEL P0171. I took it to the dealership and they said the noise was normal for the Turbo and had nothing to do with my CEL. I am still waiting on a new intake manifold for the CEL.
Panda915 is offline   Reply With Quote
Cure for wastegate flutter? Equilibrium Tuning Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 406 05-06-2016 09:28 AM
help 05 sti wastegate flutter with downpipe Burtonscustom Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 06-14-2006 01:38 AM
wastegate flutter or bov flutter-help!?!? odin1 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 02-08-2004 06:25 PM
sti wastegate flutter turbobuick Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 23 01-12-2004 09:23 AM
Is this wastegate flutter??? UGotBoost? Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 36 11-16-2003 05:27 PM
