Old 02-24-2011, 02:03 PM   #1
nwisti
Member#: 266472
2005 Sti
blackkk
Default OEM head stud and cam cap torque specs?
Ive searched and searched, all i get is a bunch of fs ads etc.
ej257 oem head stud torque specs/sequence
AND
all the cam cap bolt torque specs/sequence
anyone?
Thanks in advance.
nwisti is offline   Reply With Quote
Old 02-25-2011, 08:54 AM   #2
nwisti
Member#: 266472
2005 Sti
blackkk
I guess this isn't an FAQ section. what was i thinking? .....
Old 02-25-2011, 09:58 AM   #3
CHwrx
Member#: 69764
01,2 2.5 rs, WRX
baleeted
CHwrx is offline   Reply With Quote
Old 02-25-2011, 01:58 PM   #4
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
ok, assuming this is for your 05 STI, the order goes as follows according to Mitchell:
10, 6, 2, 3, 7
9, 5, 1, 4, 8
<- front of vehicle
according to alldata:
Cylinder head bolts:
1) Apply a coat of engine oil to washers and bolt threads.
2) Tighten all bolts in sequence to 29 Nm (3.0 kgf-m, 22 ft. lbs.)
3) Retighten all bolts in sequence to 69 Nm (7.0 kgf-m, 51 ft. lbs.)
4) Back off all bolts by 180first, then back them off a further 180, in the reverse sequence they were tightened.
5) Tighten all bolts in sequence to 49 Nm (5.0 kgf-m, 36 ft. lbs.)
6) Tighten all bolts in sequence to 80 - 90
7) Tighten all bolts in sequence a further 40 - 45
NOTE: Do not tighten bolts for more than 45.
alldata is showing only 6 bolts though, i think those are for the camshaft...can anyone confirm?
drewvdw is offline   Reply With Quote
Old 02-27-2011, 11:02 AM   #5
nwisti
Member#: 266472
2005 Sti
blackkk
drewvdw, much appreciated! 34 ft lbs sounds like a lot for cam cap bolts doesn't it?
Old 03-04-2011, 08:58 AM   #6
CHwrx
Member#: 69764
01,2 2.5 rs, WRX
yea cam cap bolts only tighten to 10 lbs you go to 34 and you'll have huge issues. be very careful as cam cap bolts don't need alot of torque. to much and you'll snap it. That means you have to get a easy out to get base of screw out of head. Then you have to tap and helicoil it. i had to do this because the 02 service manual had all the caps on 14 pounds and snapped one of the back bolts. The manual was printed wrong and I didn't find correct torque spec till after. the aluminum is really soft so go easy. tighten a little and check then tighten more. I tightened my front caps to 10-12 and the back 2 to 7. tighten and see how the cam moves. if to tight back off a little. cam should move back and forth very smooth not binding or the cam should not require much force to move. and remember to put oil on the cam where the cam sits over it.
Old 03-04-2011, 09:06 AM   #7
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
From what i remember the front cam cap bolts (the "different" front most bolts) are 14ft-lbs while the other 8 are 21-lbs
Bad Noodle is offline   Reply With Quote
Old 03-04-2011, 10:14 AM   #8
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
Why is everyone guessing at this? The FSM has all of this info and is widely available from multiple sources all of which are illegal except from http://techinfo.subaru.com/
Old 04-16-2011, 05:30 PM   #9
cartoonlife
Member#: 204291
07 UGM STi Ltd
2012 Prius
Default EJ257 OEM headstuds and cam cap torque specs
FWIW here you go
OEM head studs
INSTALLATION
1) Install the cylinder head and gaskets on cylinder
block.
NOTE:
Use new cylinder head gaskets.
Be careful not to scratch the mating surface of
cylinder head and cylinder block.
2) Tighten the cylinder head bolts.
(1) Apply a coat of engine oil to the washers and
bolt threads.
(2) Tighten all bolts to 29 Nm (3.0 kgf-m, 22 ftlb)
in alphabetical sequence.
(3) Tighten all bolts to 69 Nm (7.0 kgf-m, 51 ftlb)
in alphabetical sequence again.
(4) Back off all bolts by 180 first; back them off
by 180 again in reverse order of installation.
(5) Tighten all bolts to 49 Nm (5.0 kgf-m, 36 ftlb)
(6) Tighten all bolts 80 to 90 in alphabetical sequence.
(7) Tighten all bolts by 40 to 45 in alphabetical
sequence again.
NOTE:
Do not tighten the bolts by more than 45.
(8) Further tighten all bolts (A) and (B) by 40 to
45.
NOTE:
Ensure that the total re-tightening angle in the
previous two steps do not exceed 90.
pattern:
Camshaft Caps
Tightening torque:
T1: 10 Nm (1.0 kgf-m, 7 ft-lb)
T2: 20 Nm (2.0 kgf-m, 14.5 ft-lb)
pattern:
cartoonlife is offline   Reply With Quote
Old 07-10-2011, 05:32 PM   #10
ravenlunatic
Member#: 180601
2003 PSM WRX
(>")>==HADOKEN==<(o)
sorry to dig this one up.
does anyone know how much torque for the head studs them selves? (when instaling on block)
ravenlunatic is offline   Reply With Quote
Old 07-10-2011, 09:24 PM   #11
Member#: 51961
2005 STi
2012 WRX
OEM doesn't use studs and nuts, it uses bolts
Old 07-11-2011, 02:09 AM   #12
ravenlunatic
Member#: 180601
2003 PSM WRX
Ok, anyone running APR head studs know the specs?
Old 07-11-2011, 07:35 AM   #13
RP31
Member#: 123574
2005 2.6L 9:1 425WHP
CGM STi
It depends on the actual studs you bought, and the spec is (or should have been) included in the box with the studs. Last I did was 90 ft. lbs in 3 increments (30, 60, 90) using the provided lube on the nuts and washers.
RP31 is offline   Reply With Quote
Old 07-11-2011, 11:35 AM   #14
Member#: 51961
2005 STi
2012 WRX
He's referring to the torque spec of the studs into the block, not the nuts onto the studs.
There is no torque spec for the studs. It's supposed to be "finger tight", but I found that small imperfections in the threads or dirt in the block kept them from threading in all the way just doing it by hand, so I used a hex key to thread them all the way until they bottomed out, then backed them off just a hair, then went finger tight from there.
Old 07-18-2011, 03:18 PM   #15
ravenlunatic
Member#: 180601
2003 PSM WRX
awsome! thanks for the help guys! the ARP's came with the car, i'm rebuilding the engine from the bottom up and with lilltle to no experience at all. I'm looking up al the info I can and reading as many manuals about the ej20 and ej257 as i can.
I've got a new short block with forgerd internals and a gasket kit, both from Outfront Motorsports on the way. It was a pretty penny so I'd hate to do something stupid on the rebuild and mess it all up. Anymore info or site sugestions to get mor info would be appreciated.
again, thanks for your help
Old 07-18-2011, 03:27 PM   #16
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
I think the regular ARP and ARP L19 studs have different torque specs. If in doubt which ones you have, call ARP up. Their tech line is really helpful.
btw, for regular ARP studs, tighten in 3 increments. 30ft/lbs, 60, 90. And use a generous amount of the ARP molly lube.
fastnoypi is offline   Reply With Quote
Old 06-08-2013, 11:35 PM   #17
vicky_808
Member#: 254699
2011 STi, 05 FXT
Red, Sliver
That's correct I just done mine today.
vicky_808 is offline   Reply With Quote
Old 08-12-2013, 03:04 PM   #18
NC_2.5gt
Member#: 364653
Originally Posted by cartoonlife View Post
Camshaft Caps
Tightening torque:
pattern:
Does anyone have the part number for the camshaft cap bolts? The ones listed in this diagram as T2??
NC_2.5gt is offline   Reply With Quote
Old 08-12-2013, 09:38 PM   #19
vicky_808
Member#: 254699
2011 STi, 05 FXT
Red, Sliver
When I did mine back a few months ago we did the same..
Old 12-24-2013, 08:22 PM   #20
Fat Black Pig Sac
Member#: 247911
2006 CGM WRX TR
soon Cyber Grey
does anyone have tq specs for 2005 WRX EJ20 engine?
Fat Black Pig Sac is offline   Reply With Quote
Old 12-24-2013, 08:52 PM   #21
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
They're the same. Bloody hell I didn't even use a torque wrench on mine.
i_c_the_light is offline   Reply With Quote
STI Heads - 4x Lost cam caps and 1x damaged AVCS Bracket / font cam cap dexterous Built Motor Discussion 18 07-11-2010 05:45 PM
wtb sti oem head studs, main bolts and more [email protected] Private 'Wanted' Classifieds 3 09-05-2008 12:00 PM
Ver8 Heads /w head studs and WRX head castings subydude Private 'For Sale' Classifieds 10 04-28-2006 04:27 PM
Camshaft cap torque specs? FSM discrepancy? jblaine Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-14-2005 10:01 PM
Head Bolts & Cams Bolts Torque Specs Imprezd Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-20-2003 07:30 AM
