Old 02-24-2011, 05:01 PM   #1
scOOtNsOOby
Member#: 211094
03 WRX Wagon
rotated holset Hx35!!!
Default 04 STI driveline into 03 wrx wagon rear subframe question
ok i searched and i only found half my answer. I will be doing a full STI drive line swap form trans and rear diff to hubs and axles the whole works. Now my question is will the full rear STI subframe from a 04 bolt right up to my 03 wagon. I read that someone had to swap out the lateral links cuz the STI ones are too long, but if i used the whole STI subframe i shouldnt have to swap them out correct? So basically asking can i remove the 03 wrx rear subframe assembly and bolt up the 04 STI subframe assembly, and if not what will i need to swap to make it correct.
Thanks
Travis
scOOtNsOOby is offline   Reply With Quote
Old 03-03-2011, 04:09 AM   #2
jisnis
Member#: 275548
Anyone?
jisnis is offline   Reply With Quote
Old 03-03-2011, 01:16 PM   #3
X Mon
Member#: 156443
2006 WRX Wagon WRB
2001 Forester S, EJ205/5m
NO. STI track width is a good bit WIDER. If you want to maintain the same track and camber, you'll want to swap lat links.
X Mon is offline   Reply With Quote
Old 03-06-2011, 03:45 PM   #4
CatchMyDrift
Member#: 54523
Driveline:
Drivetrain:
CatchMyDrift is offline   Reply With Quote
Swapping a 04 sti trans into 03 wrx riderdude125 Transmission (AT/MT) & Driveline 4 06-25-2010 04:35 PM
04 sti cluster into 03 wrx D Money Interior & Exterior Modification 37 09-27-2008 09:00 PM
OEM 04 STI suspension into 05 WRX wagon javi-sti Newbies & FAQs 3 11-05-2007 01:17 PM
Swapping 04 sti engine into 03 wrx? Spooled Subaru Conversions 2 09-04-2005 05:58 AM
what are the exact parts needed to swap 04 STi trans into 03 WRX? M32WRXin3seconds Transmission (AT/MT) & Driveline 7 01-29-2004 01:25 PM
