Old 02-24-2011, 08:23 PM   #1
2ez4me
Member#: 237228
Default Ej251 00 Forester...weird lurch/crossover point
Little background....Its a 00 5 spd forester, it has a weird powerband....like 3500-3700 area feels like it hits a powerband....almost like it wasnt firing perfect then it goes....Does it most of the time...
It isnt in the engine as i have also changed out the engine, spark plugs, coils, wires and pretty much everthing....Still does it. It has had a p0420 for cat eff. since i also have a UEL Header...But does it as well after i reset ecu or erase the code.....
Kinda weird but its diff feelable and kinda annoying....anyone else expeirence this or could this be ecu related.
Thanks people
2ez4me is offline   Reply With Quote
Old 02-24-2011, 11:57 PM   #2
Back Road Runner
Member#: 60082
2004 Forester STI
ECU tune. There's an odd dip in the midrange. The fix is an I-Speed reflash, basically because the stock tune sucks. Grab a SRS-10 flash and go hurray! ...or mod the engine and make some more power.
Why the heck did you change the engine?
Old 02-25-2011, 11:48 PM   #3
kgeezy
Member#: 241559
1999 impreza 2.5rs
Rbp
check your knock sensor. my car had the same symptoms
kgeezy is offline   Reply With Quote
Old 02-26-2011, 09:50 AM   #4
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
A bad front O2 sensor can royaly screw closed loop fueling and make CL performance suck but once it transitions to Open Loop, BAM torque and power. If the high range trims are off (from bad O2), even high rpm/load ranges can suffer. Chking fuel trims with an OBD scan tool should be able to rule out O2 sensor issues.
This is just another possibility
Old 02-28-2011, 12:38 PM   #5
motohippy
Member#: 225882
2000 OBS
'88 BMW K75S
About that checking fuel trims thing. . .What should I/we be looking for? I've been thinking my O2 sensor has been bad for a while, but in the last week or so I've been feeling a surging around 3-3.4K, and I'm thinking that may be at the OL/CL transition. . .(Phase 2 EJ22, MY00)
motohippy is offline   Reply With Quote
Old 02-28-2011, 06:20 PM   #6
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
I'm not sure, but I think anything before 02 will not work with a tactrix or equivalent cable and romraider software on laptop, so you will need an obd scanner. You might be able to talk the guys at your local autozone store into looking at your furl trims with their scanner. they pull trouble codes for free and this should take them the same amount of time.
There is typically 4 long term fuel trim ranges usually designated "A" to "D". A being idle, B being low load, C being cruise area and D being above cruise/high load. If any, especially the C and D are more than a cpl points away from zero then the O2 could be the reason. An exhaust leak before the O2 or an intake leak after the MAF and some less common things can cause weird trims, too.
I'm not very familiar with pre 05 subarus, so if this does not apply to yours I apologize. But I think most obd based EFI systems work on a similar program design.
You are correct about the CL/OL transition being around 3.5-4k rpm in most gears
Old 02-28-2011, 07:25 PM   #7
motohippy
Member#: 225882
2000 OBS
'88 BMW K75S
Thanks for the ideas. FWIW, I can watch my trims in (near) real time with my Actron scanner. . .so this might be a decent option for others who can't use the Tactrix scanner. I'm just curious as to what I want to be looking for. Either way, at 116K I'm probably overdue for the sensor anyway. . .New sensor is in the mail, hopefully the weather will clear and I'll be able to get under the car this week
Old 02-28-2011, 07:34 PM   #8
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
I havea feeling that the trims you see in real time are short term and they won't be as useful unless your sensor is getting worse while you are looking at them or if you have just rest your ecu. If you can find the long term trims, anything more than 5% is far enough off that something is up IMO. That's as long as everything intake wise is stock and in good working order.
Old 03-01-2011, 06:09 PM   #9
2ez4me
Member#: 237228
super super bad piston slap, pulled it to rebuild with the SOA replacement piston set... nice to have an extra rebuilt in case i want to do 2.5 turbo like my buddies.
Old 03-01-2011, 06:13 PM   #10
2ez4me
Member#: 237228
Did it throw Cel for knock sensor?
Ill throw my scanner on tomorrow as i drive up to R/C night and do some live data recording and see what trims look like.
Been a bit, but was alot easier on my wrx to datalog and do with an system i could use my tactrix cable with
im thinkin its also open/closed loop related the way it seems
Old 03-02-2011, 08:55 PM   #11
motohippy
Member#: 225882
2000 OBS
'88 BMW K75S
My long-term fuel trim was at -3.4%. New O2 sensor went in today, no issues, no CEL . After an ECU reset (pulled off the negative), how long should I expect it to take to learn the new one, and see if it was money well spent?
As far as the knock sensor---when mine went you could actually feel the car pull timing (like getting gut-punched) as the CEL went on. Seemed like it made way more of a difference at higher RPM, rather than lower.
Thanks for the all the help so far
weird lurch WRXminion Service & Maintenance 2 12-25-2005 02:54 AM
20G installed... OLF Crossover point SUPER RICH (UTEC) GMTarkin Engine Management & Tuning 17 06-21-2005 03:12 PM
UTEC v4.2 ECU to OLF crossover point Division By Zero Engine Management & Tuning 3 04-02-2004 01:04 PM
Recomendations of Focal Tweeter Levels and High Pass Crossover Points... sean_w_smith Car Audio, Video & Security 0 02-14-2004 03:47 PM
Crossover points Keenan Car Audio, Video & Security 5 02-07-2001 10:53 AM
