Old 02-24-2011, 09:55 PM   #1
haze89
Member#: 275036
Default Car wont start some times.
I buy a 1998 subaru impreza L 1.8 awd. I was having a problem with engine hesitation when the car was at low revs. I replaced spark plugs and wired, the ignition seems to be working fine. Some times the car wont start. It cranks strong, I havent figured if it sparks when this problem happens but Im sure there is spark inside the chamber because plugs and wires are new and ignition works ok. After a couple of tries it will start. Sometimes I think it may be fuel not reaching the chamber. When i put my ignition in ON I barely hear the fuel pump and it only buzzes for like 1 second and turns off. I have a Nissan 300zx and I used to have this issue and it was the fuel pump relay but I couldn't hear the fuel pump. In my subaru I can hear the fuel pump but weak. Does somebody have an idea about what this could be?
haze89 is offline   Reply With Quote
Old 02-25-2011, 11:53 AM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
mileage? mods? all maintenence up to date? The reason the fuel pump stops after a second is that it's priming itself, it's supposed to stop and wait for you to turn the key just a tad further. Make sure that all electrical connections and grounds are clean in the engine bay. It's definitely possible that your fuel pump is on its way out, but I have no experience with symptoms.
Old 02-25-2011, 01:13 PM   #3
Jessekrs123
Member#: 236927
2015 BRZ, 93 Legacy,
1984 BRAT
Hesistation at low revs and inability to start at times sounds like a coolant temp sensor or an IACV problem.
When it doesn't start check for:
-Spark
-Fuel
-Timing (this should be fine if it runs)
-Compession
Also check your vacuum hoses for tears/disconnection.
Jessekrs123 is offline   Reply With Quote
Old 02-25-2011, 05:14 PM   #4
renyo
Member#: 93577
98 Impreza
I'm going to throw MAF sensor into the ring... If you unplug it and it starts right up, there's your problem. There's probably a few more likely causes though.
Afterthought: Have you replaced your fuel filter recently?
renyo is offline   Reply With Quote
car wont start after timing belt install jobxiii Normally Aspirated Powertrain 16 01-17-2011 08:55 PM
for some reason my car wont start (pics inside) quicksubie General Community 9 07-20-2010 06:25 PM
Alarm wont stop going off, car wont start!! felixk Car Audio, Video & Security 3 08-20-2009 05:10 PM
Parking lights wont work now car wont start inevitable_101 Electrical & Lighting 0 07-21-2009 04:51 PM
02 wrx wont start after timing please help ej20wagon02 Service & Maintenance 6 04-03-2009 02:05 PM
