Old 02-25-2011, 01:52 PM   #1
detpilot
Member#: 260446
2006 Impreza 2.5i
Default Wheels frozen to the ground?
So, interesting problem today. I'm in michigan, and of course we've been pounded with snow. My apartment parking lot never gets plowed, and when they do, they plow the cars into the spots. This has never been a problem for my Impreza, until today.
I think my rearwheels are actually frozen to the ground/snow. When I try to back up or even pull forward, I have to rev quite a bit to get anything to happen (At least, without stalling out), which is already hard on my clutch. But when I finally did break something free, only my front wheels spin. My parking brake is off, and the light is off as well, so I don't think it's a frozen parking brake. I tried for a little bit, then gave up as I was worried about my differential being damaged by the front wheels spinning, without the rear.
Any tips?
detpilot is offline   Reply With Quote
Old 02-25-2011, 02:02 PM   #2
neverrain
Member#: 268460
2011 WRX Limited
World Rally Blue
Any tips?
That's crazy. I don't have much experience in snow, but maybe get a bucket of hot water, pour it on/around the tires and immediately move it?
neverrain is offline   Reply With Quote
Old 02-25-2011, 03:15 PM   #3
skidplatez
Member#: 1575
2011 WRX Premium
Blackest Black
Are they snow tires?
skidplatez is offline   Reply With Quote
Old 02-25-2011, 03:19 PM   #4
littlewhitewagon
Member#: 103068
11 STI sedan
Use deicer and sprinkle some around your tires, then put some gravel down in the travel path. THEN use warm (not hot) water if you have access. This way, once you get unstuck you can drive up on the gravel which will keep you above the puddle.
I'm sure you know that in cold weather you never use your parking brake... chocks and in gear my friend.
littlewhitewagon is offline   Reply With Quote
Old 02-25-2011, 03:30 PM   #5
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
I really doubt your tires are THAT frozen to the ground. unfortunately you probably have bigger problems. Brakes may be frozen/seized. E-brake seized. Diff shot.
Old 02-26-2011, 02:00 AM   #6
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
pee on them
Old 02-26-2011, 08:08 AM   #7
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
Your brakes could be frozen. That happens to me a lot, especially after doing donuts or ice racing. Snow gets on the hot brakes, then as things cool down it all freezes. Sometimes I've had to launch pretty damn hard to break it loose.
Alternatively, a pot of hot water if available does wonders.
sniper1rfa is offline   Reply With Quote
Old 02-26-2011, 02:17 PM   #8
littlewhitewagon
Member#: 103068
11 STI sedan
Put a couple jacks and stands under the car. Once it's off the ground, should be much easier to figure out what the issue is.
Old 02-27-2011, 01:04 PM   #9
Sk8er
Member#: 129045
2004 Subaru WRX Sti
WOW that is crazy how did you finally break loose???
Sk8er is offline   Reply With Quote
Old 02-27-2011, 02:44 PM   #10
ZeroDrift
Member#: 184324
1999 Impreza 2.5RS
I've had this happen recently as well. It does seem like the tires freeze to the ground as well as the brakes sticking slightly. Only had the issue when temps were anywhere from -35f to -5f with snow on the ground. Never had an issue getting unstuck though. Just rev the engine up and disengage the clutch somewhat quickly (allowing it to slip just a bit).
ZeroDrift is offline   Reply With Quote
1 Year Since the Bug Eye burned to the ground (New Car Inside) EVO LOL Member's Car Gallery 73 11-27-2007 03:24 AM
My hat is frozen to the window incorporeal Off-Topic 16 12-07-2005 08:47 PM
Sad day - The Oasis in ATX burned to the ground 6/1/05 hellonwrxwheels Texas Impreza Club Forum -- TXIC 21 06-02-2005 01:20 PM
300hp to the ground? lag Legacy Forum 17 12-11-2003 01:08 PM
